GeomData_Point Class Reference
Attribute that contains 3D point. More...
#include <GeomData_Point.h>
Inheritance diagram for GeomData_Point:
enum  PointComponent { C_X = 0 , C_Y = 1 , C_Z = 2 }
 Point component (x,y,z) More...
virtual void setValue (const double theX, const double theY, const double theZ)
 Defines the double value. More...
virtual void setValue (const std::shared_ptr< GeomAPI_Pnt > &thePoint)
 Defines the point. More...
virtual double x () const
 Returns the X double value. More...
virtual double y () const
 Returns the Y double value. More...
virtual double z () const
 Returns the Z double value. More...
void setX (const double theX)
 Defines the X coordinate value. More...
void setY (const double theY)
 Defines the Y coordinate value. More...
void setZ (const double theZ)
 Defines the Z coordinate value. More...
virtual std::shared_ptr< GeomAPI_Pnt > pnt ()
 Returns the 3D point. More...
virtual void setCalculatedValue (const double theX, const double theY, const double theZ)
 Defines the calculated double value. More...
virtual void setText (const std::wstring &theX, const std::wstring &theY, const std::wstring &theZ)
 Defines the text values. More...
virtual void setTextX (const std::wstring &theX)
 Defines the X text value. More...
virtual void setTextY (const std::wstring &theY)
 Defines the Y text value. More...
virtual void setTextZ (const std::wstring &theZ)
 Defines the Z text value. More...
virtual std::wstring textX ()
 Returns the X text value. More...
virtual std::wstring textY ()
 Returns the Y text value. More...
virtual std::wstring textZ ()
 Returns the Z text value. More...
virtual void setExpressionInvalid (int, const bool theFlag)
 Allows to set expression (text) as invalid (by the parameters listener) More...
virtual bool expressionInvalid (int)
 Returns true if text is invalid. More...
virtual void setExpressionError (int theComponent, const std::string &theError)
 Allows to set expression (text) error (by the parameters listener) More...
virtual std::string expressionError (int theComponent)
 Returns an expression error. More...
virtual void setUsedParameters (int theComponent, const std::set< std::wstring > &theUsedParameters)
 Defines the used parameters. More...
virtual std::set< std::wstring > usedParameters (int theComponent) const
 Returns the used parameters. More...
virtual std::string attributeType ()
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 GeomData_Point ()
 Initializes attributes. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
Friends
class Model_Data
◆ PointComponent
◆ GeomData_Point()
GeomData_Point::GeomData_Point ( )
◆ setValue() [1/2]
void GeomData_Point::setValue ( const double  theX,
const double  theY,
const double  theZ
Implements GeomDataAPI_Point.
◆ setValue() [2/2]
void GeomData_Point::setValue ( const std::shared_ptr< GeomAPI_Pnt > &  thePoint)
Defines the point.
◆ x()
double GeomData_Point::x ( ) const
◆ y()
double GeomData_Point::y ( ) const
◆ z()
double GeomData_Point::z ( ) const
◆ setX()
void GeomData_Point::setX ( const double  theX)
◆ setY()
void GeomData_Point::setY ( const double  theY)
◆ setZ()
void GeomData_Point::setZ ( const double  theZ)
◆ pnt()
std::shared_ptr< GeomAPI_Pnt > GeomData_Point::pnt ( )
◆ setCalculatedValue()
void GeomData_Point::setCalculatedValue ( const double  theX,
const double  theY,
const double  theZ
◆ setText()
void GeomData_Point::setText ( const std::wstring &  theX,
const std::wstring &  theY,
const std::wstring &  theZ
◆ setTextX()
void GeomData_Point::setTextX ( const std::wstring &  theX)
◆ setTextY()
void GeomData_Point::setTextY ( const std::wstring &  theY)
◆ setTextZ()
void GeomData_Point::setTextZ ( const std::wstring &  theZ)
◆ textX()
std::wstring GeomData_Point::textX ( )
◆ textY()
std::wstring GeomData_Point::textY ( )
◆ textZ()
std::wstring GeomData_Point::textZ ( )
◆ setExpressionInvalid()
void GeomData_Point::setExpressionInvalid ( int  theComponent,
const bool  theFlag
◆ expressionInvalid()
bool GeomData_Point::expressionInvalid ( int  theComponent)
◆ setExpressionError()
void GeomData_Point::setExpressionError ( int  theComponent,
const std::string &  theError
◆ expressionError()
std::string GeomData_Point::expressionError ( int  theComponent)
◆ setUsedParameters()
void GeomData_Point::setUsedParameters ( int  theComponent,
const std::set< std::wstring > &  theUsedParameters
◆ usedParameters()
std::set< std::wstring > GeomData_Point::usedParameters ( int  theComponent) const
◆ reinit()
void GeomData_Point::reinit ( )
Reimplemented from ModelAPI_Attribute.
◆ typeId()
static std::string GeomDataAPI_Point::typeId ( )
inlinestaticinherited
◆ attributeType()
std::string GeomDataAPI_Point::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
