Attribute that contains 3D point coordinates. More...
#include <GeomDataAPI_Point.h>
Public Types | |
| enum | PointComponent { C_X = 0 , C_Y = 1 , C_Z = 2 } |
| Point component (x,y,z) More... | |
| virtual void | setValue (const double theX, const double theY, const double theZ)=0 |
| Defines the double value. More... | |
| virtual void | setValue (const std::shared_ptr< GeomAPI_Pnt > &thePoint)=0 |
| Defines the point. More... | |
| virtual double | x () const =0 |
| Returns the X double value. More... | |
| virtual double | y () const =0 |
| Returns the Y double value. More... | |
| virtual double | z () const =0 |
| Returns the Z double value. More... | |
| virtual std::shared_ptr< GeomAPI_Pnt > | pnt ()=0 |
| Returns the 3D point. More... | |
| virtual void | setCalculatedValue (const double theX, const double theY, const double theZ)=0 |
| Defines the calculated double value. More... | |
| virtual void | setX (const double theX)=0 |
| Defines the X coordinate value. More... | |
| virtual void | setY (const double theY)=0 |
| Defines the Y coordinate value. More... | |
| virtual void | setZ (const double theZ)=0 |
| Defines the Z coordinate value. More... | |
| virtual void | setText (const std::wstring &theX, const std::wstring &theY, const std::wstring &theZ)=0 |
| Defines the text values. More... | |
| virtual void | setTextX (const std::wstring &theX)=0 |
| Defines the X text value. More... | |
| virtual void | setTextY (const std::wstring &theY)=0 |
| Defines the Y text value. More... | |
| virtual void | setTextZ (const std::wstring &theZ)=0 |
| Defines the Z text value. More... | |
| virtual std::wstring | textX ()=0 |
| Returns the text value for X. More... | |
| virtual std::wstring | textY ()=0 |
| Returns the text value for Y. More... | |
| virtual std::wstring | textZ ()=0 |
| Returns the text value for Z. More... | |
| virtual void | setExpressionInvalid (int theComponent, const bool theFlag)=0 |
| Allows to set expression (text) as invalid (by the parameters listener) More... | |
| virtual bool | expressionInvalid (int theComponent)=0 |
| Returns true if text is invalid. More... | |
| virtual void | setExpressionError (int theComponent, const std::string &theError)=0 |
| Allows to set expression (text) error (by the parameters listener) More... | |
| virtual std::string | expressionError (int theComponent)=0 |
| Returns an expression error. More... | |
| virtual void | setUsedParameters (int theComponent, const std::set< std::wstring > &theUsedParameters)=0 |
| Defines the used parameters. More... | |
| virtual std::set< std::wstring > | usedParameters (int theComponent) const =0 |
| Returns the used parameters. More... | |
| virtual std::string | attributeType () |
| Returns the type of this class of attributes, not static method. More... | |
| virtual void | setObject (const std::shared_ptr< ModelAPI_Object > &theObject) |
| Sets the owner of this attribute. More... | |
| const std::shared_ptr< ModelAPI_Object > & | owner () const |
| Returns the owner of this attribute. More... | |
| virtual bool | isInitialized () |
| Returns true if attribute was initialized by some value. More... | |
| void | setInitialized () |
| Makes attribute initialized. More... | |
| bool | blockSetInitialized (const bool theBlock) |
| Blocks sending "attribute updated" if theBlock is true. More... | |
| void | setIsArgument (const bool theFlag) |
| Set this attribute is argument for result (change of this attribute requires update of result). More... | |
| bool | isArgument () |
| Returns true if attribute causes the result change. More... | |
| bool | setImmutable (const bool theFlag) |
| Immutable argument can not be changed programmatically (e.g. More... | |
| bool | isImmutable () |
| Returns true if can not be changed programmatically. More... | |
| const std::string & | id () const |
| ID of the attribute in Data. More... | |
| virtual void | reset () |
| Resets attribute to default state. More... | |
| static std::string | typeId () |
| Returns the type of this class of attributes. More... | |
| GeomDataAPI_Point () | |
| Objects are created for features automatically. More... | |
| virtual void | setID (const std::string theID) |
| Sets the ID of the attribute in Data (called from Data) More... | |
| virtual void | reinit () |
| Reinitializes the internal state of the attribute (may be needed on undo/redo, abort, etc) More... | |
Protected Attributes | |
| bool | myIsInitialized |
| is some value assigned to this attribute More... | |
| bool | mySetInitializedBlocked |
| is initialized blocked More... | |
| bool | myIsArgument |
| is this attribute used as an argument for execution More... | |
| bool | myIsImmutable |
| is this attribute can be changed programmatically (e.g. by constraint) More... | |
protected |
pure virtual |
Implemented in GeomData_Point.
pure virtual |
Defines the point.
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
inlinestatic |
Reimplemented in GeomData_Dir, Model_AttributeRefAttr, Model_AttributeRefAttrList, Model_AttributeReference, Model_AttributeRefList, Model_AttributeSelection, and Model_AttributeSelectionList.
| theBlock | a block value |
By default it is true.
protectedvirtualinherited |
Reimplemented in GeomData_Dir, GeomData_Point, GeomData_Point2D, GeomData_Point2DArray, Model_AttributeBoolean, Model_AttributeDocRef, Model_AttributeDouble, Model_AttributeDoubleArray, Model_AttributeImage, Model_AttributeIntArray, Model_AttributeInteger, Model_AttributeRefAttr, Model_AttributeRefAttrList, Model_AttributeReference, Model_AttributeRefList, Model_AttributeSelectionList, Model_AttributeString, and Model_AttributeTables.
protectedinherited |
