Model_AttributeInteger Class Reference
Attribute that contains integer. More...
#include <Model_AttributeInteger.h>
Inheritance diagram for Model_AttributeInteger:
virtual MODEL_EXPORT void setValue (const int theValue)
 Defines the integer value. More...
virtual MODEL_EXPORT int value ()
 Returns the integer value. More...
virtual MODEL_EXPORT void setCalculatedValue (const int theValue)
 Defines the calculated value. More...
virtual MODEL_EXPORT void setText (const std::wstring &theText)
 Defines the text value. More...
virtual MODEL_EXPORT std::wstring text ()
 Returns the text value. More...
virtual MODEL_EXPORT void setExpressionInvalid (const bool theFlag)
 Allows to set expression (text) as invalid (by the parameters listener) More...
virtual MODEL_EXPORT bool expressionInvalid ()
 Returns true if text is invalid. More...
virtual MODEL_EXPORT void setExpressionError (const std::string &theError)
 Allows to set expression (text) error (by the parameters listener) More...
virtual MODEL_EXPORT std::string expressionError ()
 Returns an expression error. More...
virtual MODEL_EXPORT void setUsedParameters (const std::set< std::wstring > &theUsedParameters)
 Defines the used parameters. More...
virtual MODEL_EXPORT std::set< std::wstring > usedParameters () const
 Returns the used parameters. More...
virtual MODELAPI_EXPORT std::string attributeType ()
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static MODELAPI_EXPORT std::string typeId ()
 Model_AttributeInteger (TDF_Label &theLabel)
 Initializes attributes. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
Friends
class Model_Data
◆ Model_AttributeInteger()
Model_AttributeInteger::Model_AttributeInteger ( TDF_Label &  theLabel)
◆ setValue()
void Model_AttributeInteger::setValue ( const int  theValue)
Implements ModelAPI_AttributeInteger.
◆ value()
int Model_AttributeInteger::value ( )
◆ setCalculatedValue()
void Model_AttributeInteger::setCalculatedValue ( const int  theValue)
◆ setText()
void Model_AttributeInteger::setText ( const std::wstring &  theText)
◆ text()
std::wstring Model_AttributeInteger::text ( )
◆ setExpressionInvalid()
void Model_AttributeInteger::setExpressionInvalid ( const bool  theFlag)
◆ expressionInvalid()
bool Model_AttributeInteger::expressionInvalid ( )
◆ setExpressionError()
void Model_AttributeInteger::setExpressionError ( const std::string &  theError)
◆ expressionError()
std::string Model_AttributeInteger::expressionError ( )
◆ setUsedParameters()
void Model_AttributeInteger::setUsedParameters ( const std::set< std::wstring > &  theUsedParameters)
◆ usedParameters()
std::set< std::wstring > Model_AttributeInteger::usedParameters ( ) const
◆ reinit()
void Model_AttributeInteger::reinit ( )
Reimplemented from ModelAPI_Attribute.
◆ typeId()
static MODELAPI_EXPORT std::string ModelAPI_AttributeInteger::typeId ( )
inlinestaticinherited
◆ attributeType()
std::string ModelAPI_AttributeInteger::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
