Model_AttributeInteger.h
20#ifndef MODEL_ATTRIBUTEINTEGER_H_
21#define MODEL_ATTRIBUTEINTEGER_H_
23#include <Model.h>
24#include <ModelAPI_AttributeInteger.h>
26#include <TDF_Label.hxx>
27
36{
37 public:
39 MODEL_EXPORT virtual void setValue(const int theValue);
40
42 MODEL_EXPORT virtual int value();
43
45 MODEL_EXPORT virtual void setCalculatedValue(const int theValue);
46
48 MODEL_EXPORT virtual void setText(const std::wstring& theText);
49
51 MODEL_EXPORT virtual std::wstring text();
52
54 MODEL_EXPORT virtual void setExpressionInvalid(const bool theFlag);
55
57 MODEL_EXPORT virtual bool expressionInvalid();
58
60 MODEL_EXPORT virtual void setExpressionError(const std::string& theError);
61
63 MODEL_EXPORT virtual std::string expressionError();
64
66 MODEL_EXPORT virtual void setUsedParameters(const std::set<std::wstring>& theUsedParameters);
67
69 MODEL_EXPORT virtual std::set<std::wstring> usedParameters() const;
70
71 protected:
73 Model_AttributeInteger(TDF_Label& theLabel);
75 virtual void reinit();
76
77 friend class Model_Data;
78
79 private:
80 std::shared_ptr<ModelAPI_ExpressionInteger> myExpression;
81};
82
83#endif
API for the attribute that contains integer (int).
Definition: ModelAPI_AttributeInteger.h:34
Expression for calculated integer values.
Definition: ModelAPI_Expression.h:122
Attribute that contains integer.
Definition: Model_AttributeInteger.h:36
virtual MODEL_EXPORT std::set< std::wstring > usedParameters() const
Returns the used parameters.
Definition: Model_AttributeInteger.cpp:99
virtual MODEL_EXPORT void setExpressionError(const std::string &theError)
Allows to set expression (text) error (by the parameters listener)
Definition: Model_AttributeInteger.cpp:83
virtual MODEL_EXPORT void setValue(const int theValue)
Defines the integer value.
Definition: Model_AttributeInteger.cpp:48
virtual MODEL_EXPORT int value()
Returns the integer value.
Definition: Model_AttributeInteger.cpp:53
virtual MODEL_EXPORT void setCalculatedValue(const int theValue)
Defines the calculated value.
Definition: Model_AttributeInteger.cpp:40
virtual MODEL_EXPORT void setUsedParameters(const std::set< std::wstring > &theUsedParameters)
Defines the used parameters.
Definition: Model_AttributeInteger.cpp:94
virtual MODEL_EXPORT bool expressionInvalid()
Returns true if text is invalid.
Definition: Model_AttributeInteger.cpp:78
virtual MODEL_EXPORT std::wstring text()
Returns the text value.
Definition: Model_AttributeInteger.cpp:68
Model_AttributeInteger(TDF_Label &theLabel)
Initializes attributes.
Definition: Model_AttributeInteger.cpp:27
virtual MODEL_EXPORT void setExpressionInvalid(const bool theFlag)
Allows to set expression (text) as invalid (by the parameters listener)
Definition: Model_AttributeInteger.cpp:73
virtual MODEL_EXPORT void setText(const std::wstring &theText)
Defines the text value.
Definition: Model_AttributeInteger.cpp:58
Reinitializes the internal state of the attribute (may be needed on undo/redo, abort,...
Definition: Model_AttributeInteger.cpp:34
virtual MODEL_EXPORT std::string expressionError()
Returns an expression error.
Definition: Model_AttributeInteger.cpp:89
General object of the application that allows to get/set attributes from the document and compute res...
Definition: Model_Data.h:62
