Expression for calculated integer values. More...
#include <ModelAPI_Expression.h>
| virtual void | setValue (const int theValue)=0 |
| Defines the integer value. More... | |
| virtual int | value ()=0 |
| Returns the integer value. More... | |
| virtual bool | isInitialized () |
| Returns true if attribute was initialized by some value. More... | |
| virtual void | setInitialized () |
| Makes attribute initialized. More... | |
| virtual void | setText (const std::wstring &theText)=0 |
| Sets the text of this Expression. More... | |
| virtual std::wstring | text () const =0 |
| Returns the text of this Expression. More... | |
| virtual void | setInvalid (const bool theFlag)=0 |
| Allows to set expression (text) as invalid (by the parameters listener) More... | |
| virtual bool | isInvalid ()=0 |
| Returns true if text is invalid. More... | |
| virtual void | setError (const std::string &theError)=0 |
| Allows to set expression (text) error (by the parameters listener) More... | |
| virtual std::string | error ()=0 |
| Returns an expression error. More... | |
| virtual void | setUsedParameters (const std::set< std::wstring > &theUsedParameters)=0 |
| Defines the used parameters (by the parameters listener) More... | |
| virtual std::set< std::wstring > | usedParameters () const =0 |
| Returns the used parameters. More... | |
| static bool | isVariable (const std::string &theString) |
| Returns True if the given string can be defined as a name of an expression variable. More... | |
| static bool | isVariable (const std::wstring &theString) |
| ModelAPI_ExpressionInteger () | |
| Objects are created for features automatically. More... | |
| virtual void | reinit ()=0 |
| Reinitializes the internal state of the attribute (may be needed on undo/redo, abort, etc) More... | |
| virtual void | reset () |
| Resets attribute to default state. More... | |
Protected Attributes | |
| bool | myIsInitialized |
| is some value assigned to this attribute More... | |
Friends | |
| class | Model_Data |
protected |
pure virtual |
Implemented in Model_ExpressionInteger.
pure virtual |
pure virtualinherited |
Implemented in Model_Expression, Model_ExpressionDouble, and Model_ExpressionInteger.
Implemented in Model_ExpressionDouble, and Model_ExpressionInteger.
staticinherited |
staticinherited |
protectedpure virtualinherited |
protectedinherited |
