Model_ExpressionDouble Class Reference
Implementation of ModelAPI_ExpressionDouble. More...
#include <Model_Expression.h>
Inheritance diagram for Model_ExpressionDouble:
virtual void setText (const std::wstring &theText)
 Sets the text of this Expression. More...
virtual std::wstring text () const
 Returns the text of this Expression. More...
virtual void setError (const std::string &theError)
 Allows to set expression (text) error (by the parameters listener) More...
virtual std::string error ()
 Returns an expression error. More...
virtual void setUsedParameters (const std::set< std::wstring > &theUsedParameters)
 Defines the used parameters (by the parameters listener) More...
virtual std::set< std::wstring > usedParameters () const
 Returns the used parameters. More...
virtual void setValue (const double theValue)
 Defines the double value. More...
virtual double value ()
 Returns the double value. More...
virtual void setInvalid (const bool theFlag)
 Allows to set expression (text) as invalid (by the parameters listener) More...
virtual bool isInvalid ()
 Returns true if text is invalid. More...
virtual bool isInitialized ()
virtual void setInitialized ()
static bool isVariable (const std::string &theString)
 Returns True if the given string can be defined as a name of an expression variable. More...
static bool isVariable (const std::wstring &theString)
 Model_ExpressionDouble (TDF_Label &theLabel)
 Initializes attributes. More...
virtual void reinit ()
virtual void reset ()
Handle_TDataStd_Name myText
 Text representation of the attribute (may differ for parameters) More...
Handle_TDataStd_Comment myError
 Error of expression of the text attribute. More...
Handle_TDataStd_ExtStringList myUsedParameters
 Parameters used in expression. More...
TDF_Label myLab
 if attribute is not initialized, store label here More...
bool myIsInitialized
Friends
class Model_AttributeDouble
class Model_Data
◆ Model_ExpressionDouble()
Model_ExpressionDouble::Model_ExpressionDouble ( TDF_Label &  theLabel)
◆ setText()
virtual void Model_ExpressionDouble::setText ( const std::wstring &  theText)
Reimplemented from Model_Expression.
◆ text()
virtual std::wstring Model_ExpressionDouble::text ( ) const
◆ setError()
virtual void Model_ExpressionDouble::setError ( const std::string &  theError)
◆ error()
virtual std::string Model_ExpressionDouble::error ( )
◆ setUsedParameters()
virtual void Model_ExpressionDouble::setUsedParameters ( const std::set< std::wstring > &  theUsedParameters)
◆ usedParameters()
virtual std::set< std::wstring > Model_ExpressionDouble::usedParameters ( ) const
◆ setValue()
void Model_ExpressionDouble::setValue ( const double  theValue)
Implements ModelAPI_ExpressionDouble.
◆ value()
double Model_ExpressionDouble::value ( )
◆ setInvalid()
void Model_ExpressionDouble::setInvalid ( const bool  theFlag)
Implements ModelAPI_Expression.
◆ isInvalid()
bool Model_ExpressionDouble::isInvalid ( )
◆ reinit()
void Model_ExpressionDouble::reinit ( )
◆ isInitialized()
bool ModelAPI_Expression::isInitialized ( )
◆ setInitialized()
void ModelAPI_Expression::setInitialized ( )
◆ isVariable() [1/2]
bool ModelAPI_Expression::isVariable ( const std::string &  theString)
◆ isVariable() [2/2]
bool ModelAPI_Expression::isVariable ( const std::wstring &  theString)
◆ reset()
virtual void ModelAPI_Expression::reset ( )
◆ myText
Handle_TDataStd_Name Model_Expression::myText
◆ myError
Handle_TDataStd_Comment Model_Expression::myError
◆ myUsedParameters
Handle_TDataStd_ExtStringList Model_Expression::myUsedParameters
◆ myLab
TDF_Label Model_Expression::myLab
◆ myIsInitialized
bool ModelAPI_Expression::myIsInitialized
