Model_Expression Class Referenceabstract
Implementation of ModelAPI_Expression. More...
#include <Model_Expression.h>
Inheritance diagram for Model_Expression:
virtual void setText (const std::wstring &theText)
 Sets the text of this Expression. More...
virtual std::wstring text () const
 Returns the text of this Expression. More...
virtual void setError (const std::string &theError)
 Allows to set expression (text) error (by the parameters listener) More...
virtual std::string error ()
 Returns an expression error. More...
virtual void setUsedParameters (const std::set< std::wstring > &theUsedParameters)
 Defines the used parameters (by the parameters listener) More...
virtual std::set< std::wstring > usedParameters () const
 Returns the used parameters. More...
virtual bool isInitialized ()
virtual void setInitialized ()
virtual void setInvalid (const bool theFlag)=0
 Allows to set expression (text) as invalid (by the parameters listener) More...
virtual bool isInvalid ()=0
 Returns true if text is invalid. More...
static bool isVariable (const std::string &theString)
 Returns True if the given string can be defined as a name of an expression variable. More...
static bool isVariable (const std::wstring &theString)
 Model_Expression (TDF_Label &theLabel)
 Initializes attributes. More...
virtual void reinit ()=0
virtual void reset ()
Handle_TDataStd_Name myText
 Text representation of the attribute (may differ for parameters) More...
Handle_TDataStd_Comment myError
 Error of expression of the text attribute. More...
Handle_TDataStd_ExtStringList myUsedParameters
 Parameters used in expression. More...
TDF_Label myLab
 if attribute is not initialized, store label here More...
bool myIsInitialized
◆ Model_Expression()
Model_Expression::Model_Expression ( TDF_Label &  theLabel)
◆ setText()
void Model_Expression::setText ( const std::wstring &  theText)
Implements ModelAPI_Expression.
Reimplemented in Model_ExpressionDouble, and Model_ExpressionInteger.
◆ text()
std::wstring Model_Expression::text ( ) const
◆ setError()
void Model_Expression::setError ( const std::string &  theError)
◆ error()
std::string Model_Expression::error ( )
◆ setUsedParameters()
void Model_Expression::setUsedParameters ( const std::set< std::wstring > &  theUsedParameters)
◆ usedParameters()
std::set< std::wstring > Model_Expression::usedParameters ( ) const
◆ isInitialized()
bool ModelAPI_Expression::isInitialized ( )
◆ setInitialized()
void ModelAPI_Expression::setInitialized ( )
◆ setInvalid()
virtual void ModelAPI_Expression::setInvalid ( const bool  theFlag)
pure virtualinherited
Implemented in Model_ExpressionDouble, and Model_ExpressionInteger.
◆ isInvalid()
virtual bool ModelAPI_Expression::isInvalid ( )
◆ isVariable() [1/2]
bool ModelAPI_Expression::isVariable ( const std::string &  theString)
◆ isVariable() [2/2]
bool ModelAPI_Expression::isVariable ( const std::wstring &  theString)
◆ reinit()
virtual void ModelAPI_Expression::reinit ( )
protectedpure virtualinherited
◆ reset()
virtual void ModelAPI_Expression::reset ( )
◆ myText
Handle_TDataStd_Name Model_Expression::myText
◆ myError
Handle_TDataStd_Comment Model_Expression::myError
◆ myUsedParameters
Handle_TDataStd_ExtStringList Model_Expression::myUsedParameters
◆ myLab
TDF_Label Model_Expression::myLab
◆ myIsInitialized
bool ModelAPI_Expression::myIsInitialized
