Implementation of ModelAPI_ExpressionInteger.
More...
#include <Model_Expression.h>
| virtual void | setText (const std::wstring &theText) |
| | Sets the text of this Expression. More...
| virtual std::wstring | text () const |
| | Returns the text of this Expression. More...
| virtual void | setError (const std::string &theError) |
| | Allows to set expression (text) error (by the parameters listener) More...
| virtual std::string | error () |
| | Returns an expression error. More...
| virtual void | setUsedParameters (const std::set< std::wstring > &theUsedParameters) |
| | Defines the used parameters (by the parameters listener) More...
| virtual std::set< std::wstring > | usedParameters () const |
| | Returns the used parameters. More...
| virtual void | setValue (const int theValue) |
| | Defines the integer value. More...
| virtual int | value () |
| | Returns the integer value. More...
| virtual void | setInvalid (const bool theFlag) |
| | Allows to set expression (text) as invalid (by the parameters listener) More...
| virtual bool | isInvalid () |
| | Returns true if text is invalid. More...
| virtual bool | isInitialized () |
| | Returns true if attribute was initialized by some value. More...
| virtual void | setInitialized () |
| | Makes attribute initialized. More...
| static bool | isVariable (const std::string &theString) |
| | Returns True if the given string can be defined as a name of an expression variable. More...
| static bool | isVariable (const std::wstring &theString) |
class | Model_AttributeInteger |
◆ Model_ExpressionInteger()
| Model_ExpressionInteger::Model_ExpressionInteger |
TDF_Label & |
theLabel | ) |
protected |
◆ setText()
| virtual void Model_ExpressionInteger::setText |
const std::wstring & |
theText | ) |
inlinevirtual |
◆ text()
| virtual std::wstring Model_ExpressionInteger::text |
const |
inlinevirtual |
◆ setError()
| virtual void Model_ExpressionInteger::setError |
const std::string & |
theError | ) |
inlinevirtual |
Reimplemented from Model_Expression.
◆ error()
| virtual std::string Model_ExpressionInteger::error |
inlinevirtual |
◆ setUsedParameters()
| virtual void Model_ExpressionInteger::setUsedParameters |
const std::set< std::wstring > & |
theUsedParameters | ) |
inlinevirtual |
◆ usedParameters()
| virtual std::set< std::wstring > Model_ExpressionInteger::usedParameters |
const |
inlinevirtual |
◆ setValue()
| void Model_ExpressionInteger::setValue |
const int |
theValue | ) |
◆ value()
| int Model_ExpressionInteger::value |
◆ setInvalid()
| void Model_ExpressionInteger::setInvalid |
const bool |
theFlag | ) |
Implements ModelAPI_Expression.
◆ isInvalid()
| bool Model_ExpressionInteger::isInvalid |
◆ reinit()
| void Model_ExpressionInteger::reinit |
protectedvirtual |
Reinitializes the internal state of the attribute (may be needed on undo/redo, abort, etc)
◆ isInitialized()
| bool ModelAPI_Expression::isInitialized |
◆ setInitialized()
| void ModelAPI_Expression::setInitialized |
◆ isVariable() [1/2]
| bool ModelAPI_Expression::isVariable |
theString | ) |
staticinherited |
◆ isVariable() [2/2]
theString | ) |
staticinherited |
◆ reset()
| virtual void ModelAPI_Expression::reset |
Resets attribute to default state.
◆ myText
| Handle_TDataStd_Name Model_Expression::myText |
protectedinherited |
Text representation of the attribute (may differ for parameters)
◆ myError
| Handle_TDataStd_Comment Model_Expression::myError |
Error of expression of the text attribute.
◆ myUsedParameters
| Handle_TDataStd_ExtStringList Model_Expression::myUsedParameters |
Parameters used in expression.
◆ myLab
| TDF_Label Model_Expression::myLab |
if attribute is not initialized, store label here
◆ myIsInitialized
| bool ModelAPI_Expression::myIsInitialized |
is some value assigned to this attribute
