ModelAPI_Expression Class Referenceabstract
Expression for calculated values. More...
#include <ModelAPI_Expression.h>
Inheritance diagram for ModelAPI_Expression:
virtual ~ModelAPI_Expression ()
 To virtually destroy the fields of successors. More...
virtual bool isInitialized ()
virtual void setInitialized ()
virtual void setText (const std::wstring &theText)=0
 Sets the text of this Expression. More...
virtual std::wstring text () const =0
 Returns the text of this Expression. More...
virtual void setInvalid (const bool theFlag)=0
 Allows to set expression (text) as invalid (by the parameters listener) More...
virtual bool isInvalid ()=0
 Returns true if text is invalid. More...
virtual void setError (const std::string &theError)=0
 Allows to set expression (text) error (by the parameters listener) More...
virtual std::string error ()=0
 Returns an expression error. More...
virtual void setUsedParameters (const std::set< std::wstring > &theUsedParameters)=0
 Defines the used parameters (by the parameters listener) More...
virtual std::set< std::wstring > usedParameters () const =0
 Returns the used parameters. More...
static bool isVariable (const std::string &theString)
 Returns True if the given string can be defined as a name of an expression variable. More...
static bool isVariable (const std::wstring &theString)
 Objects are created for features automatically. More...
virtual void reinit ()=0
virtual void reset ()
bool myIsInitialized
Friends
class Model_Data
class Model_AttributeDouble
class Model_AttributeInteger
class GeomData_Point
class GeomData_Point2D
◆ ~ModelAPI_Expression()
ModelAPI_Expression::~ModelAPI_Expression ( )
◆ ModelAPI_Expression()
ModelAPI_Expression::ModelAPI_Expression ( )
◆ isInitialized()
bool ModelAPI_Expression::isInitialized ( )
◆ setInitialized()
void ModelAPI_Expression::setInitialized ( )
◆ setText()
virtual void ModelAPI_Expression::setText ( const std::wstring &  theText)
pure virtual
Implemented in Model_Expression, Model_ExpressionDouble, and Model_ExpressionInteger.
◆ text()
virtual std::wstring ModelAPI_Expression::text ( ) const
pure virtual
◆ setInvalid()
virtual void ModelAPI_Expression::setInvalid ( const bool  theFlag)
pure virtual
Implemented in Model_ExpressionDouble, and Model_ExpressionInteger.
◆ isInvalid()
virtual bool ModelAPI_Expression::isInvalid ( )
pure virtual
◆ setError()
virtual void ModelAPI_Expression::setError ( const std::string &  theError)
pure virtual
◆ error()
virtual std::string ModelAPI_Expression::error ( )
pure virtual
◆ setUsedParameters()
virtual void ModelAPI_Expression::setUsedParameters ( const std::set< std::wstring > &  theUsedParameters)
pure virtual
◆ usedParameters()
virtual std::set< std::wstring > ModelAPI_Expression::usedParameters ( ) const
pure virtual
◆ isVariable() [1/2]
bool ModelAPI_Expression::isVariable ( const std::string &  theString)
◆ isVariable() [2/2]
bool ModelAPI_Expression::isVariable ( const std::wstring &  theString)
◆ reinit()
virtual void ModelAPI_Expression::reinit ( )
protectedpure virtual
◆ reset()
virtual void ModelAPI_Expression::reset ( )
inlineprotectedvirtual
◆ myIsInitialized
bool ModelAPI_Expression::myIsInitialized
