Attribute that contains list of references to features, may be located in different documents. More...
#include <Model_AttributeRefList.h>
| virtual void | append (ObjectPtr theObject) |
| Appends the feature to the end of a list. More... | |
| virtual void | remove (ObjectPtr theObject) |
| Erases the first meet of the feature in the list. More... | |
| virtual int | size (const bool theWithEmpty=true) const |
| Returns number of features in the list. More... | |
| virtual void | clear () |
| Removes all references from the list. More... | |
| virtual std::list< ObjectPtr > | list () |
| Returns the list of features. More... | |
| virtual bool | isInList (const ObjectPtr &theObj) |
| Returns true if the object is in list. More... | |
| virtual ObjectPtr | object (const int theIndex, const bool theWithEmpty=true) |
| virtual void | substitute (const ObjectPtr &theCurrent, const ObjectPtr &theNew) |
| Substitutes the feature by another one. More... | |
| virtual void | removeLast () |
| Removes the last element in the list. More... | |
| virtual void | remove (const std::set< int > &theIndices) |
| Removes the elements from the list. More... | |
| virtual bool | isInitialized () |
| Returns true if attribute was initialized by some value. More... | |
| void | eraseHash () |
| Erases the hashed objects caused by complicated modifications in the list. More... | |
| virtual std::string | attributeType () |
| Returns the type of this class of attributes, not static method. More... | |
| virtual void | setObject (const std::shared_ptr< ModelAPI_Object > &theObject) |
| Sets the owner of this attribute. More... | |
| const std::shared_ptr< ModelAPI_Object > & | owner () const |
| Returns the owner of this attribute. More... | |
| void | setInitialized () |
| Makes attribute initialized. More... | |
| bool | blockSetInitialized (const bool theBlock) |
| Blocks sending "attribute updated" if theBlock is true. More... | |
| void | setIsArgument (const bool theFlag) |
| Set this attribute is argument for result (change of this attribute requires update of result). More... | |
| bool | isArgument () |
| Returns true if attribute causes the result change. More... | |
| bool | setImmutable (const bool theFlag) |
| Immutable argument can not be changed programmatically (e.g. More... | |
| bool | isImmutable () |
| Returns true if can not be changed programmatically. More... | |
| const std::string & | id () const |
| ID of the attribute in Data. More... | |
| virtual void | reset () |
| Resets attribute to default state. More... | |
| static std::string | typeId () |
| Returns the type of this class of attributes. More... | |
| Model_AttributeRefList (TDF_Label &theLabel) | |
| Objects are created for features automatically. More... | |
| virtual void | reinit () |
| Reinitializes the internal state of the attribute (may be needed on undo/redo, abort, etc) More... | |
| ObjectPtr | iteratedObject (TDF_ListIteratorOfLabelList &theLIter, TDataStd_ListIteratorOfListOfExtendedString &theExtIter, std::shared_ptr< Model_Document > theDoc) const |
| Returns the object by iterators (theExtIter is iterated if necessary) More... | |
| void | createHash () |
| Creates the hash-objects containers (does nothing if hash is already correct) More... | |
| virtual void | setID (const std::string theID) |
| Sets the ID of the attribute in Data (called from Data) More... | |
Protected Attributes | |
| bool | myIsInitialized |
| is some value assigned to this attribute More... | |
| bool | mySetInitializedBlocked |
| is initialized blocked More... | |
| bool | myIsArgument |
| is this attribute used as an argument for execution More... | |
| bool | myIsImmutable |
| is this attribute can be changed programmatically (e.g. by constraint) More... | |
Friends | |
| class | Model_Data |
protected |
Implements ModelAPI_AttributeRefList.
| theWithEmpty | if it is false, returns the number of not-empty referenced objects |
| theIndex | zero-based index in the list |
| theWithEmpty | if it is false, counts the not-empty referenced objects only |
Does nothing if such object is not found. Does not support the external documents objects yet.
| theIndices | a list of indices of elements to be removed |
Reimplemented from ModelAPI_Attribute.
| void Model_AttributeRefList::eraseHash | ( | ) |
protectedvirtual |
protected |
protected |
inlinestaticinherited |
| theBlock | a block value |
By default it is true.
protectedvirtualinherited |
protectedinherited |
