Model_AttributeSelectionList Class Reference
Attribute that contains list of references to the sub-shapes with possibility to manage them. More...
#include <Model_AttributeSelectionList.h>
Inheritance diagram for Model_AttributeSelectionList:
virtual void append (const ObjectPtr &theContext, const std::shared_ptr< GeomAPI_Shape > &theSubShape, const bool theTemporarily=false)
 Adds the new reference to the end of the list. More...
virtual void append (const std::wstring &theNamingName, const std::string &theType="")
 Adds the new reference to the end of the list by the naming name of the selected shape The type of shape is taken from the current selection type if the given is empty. More...
virtual void append (const std::shared_ptr< GeomAPI_Pnt > &thePoint, const std::string &theType, const bool theIsIgnoreGroups=false)
 Adds the new reference to the end of the list by inner point on the selected shape. More...
virtual void append (const std::string &theType, const std::wstring &theContextName, const int theIndex)
 Adds the new reference to the end of the list by weak naming index. More...
virtual void copyTo (AttributeSelectionListPtr theTarget) const
 Copy the selection list to the destination attribute. More...
virtual void removeTemporaryValues ()
 Reset temporary stored values. More...
virtual void removeLast ()
 Removes the last element in the list. More...
virtual void remove (const std::set< int > &theIndices)
 Removes the elements from the list. More...
virtual int size ()
 Returns the number of selection attributes in the list. More...
virtual bool isInList (const ObjectPtr &theContext, const std::shared_ptr< GeomAPI_Shape > &theSubShape, const bool theTemporarily=false)
 Returns true if the object with the shape are in list. More...
virtual const std::string selectionType () const
 The type of all elements selection. More...
virtual void setSelectionType (const std::string &theType)
 Sets the type of all elements selection. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > value (const int theIndex)
 Returns the attribute selection by the index (zero based) More...
virtual void clear ()
 Returns all attributes. More...
virtual bool isInitialized ()
virtual void cashValues (const bool theEnabled)
 Starts or stops cashing of the values in the attribute (the cash may become invalid on modification of the attribute or sub-elements, so the cash must be enabled only during non-modification operations with this attribute) More...
virtual void setGeometricalSelection (const bool theIsGeometricalSelection) override
virtual bool isGeometricalSelection () const override
 Returns true if is geometrical selection. More...
virtual FiltersFeaturePtr filters () const
 Returns a selection filters feature if it is defined for this selection list. More...
virtual void setFilters (FiltersFeaturePtr theFeature)
 Sets a selection filters feature if it is defined for this selection list. More...
virtual void applyFilters ()
 Applies the filters to this selection list. More...
virtual void removeFilters ()
 Removes the filters of this selection list. More...
virtual std::string attributeType ()
virtual const bool isWholeResultAllowed () const
 Returns true if the whole result selection corresponds to selection of all sub-shapes. More...
virtual void setWholeResultAllowed (const bool theFlag)
 Sets whether the whole result selection corresponds to selection of all sub-shapes. More...
virtual const bool isMakeCopy () const
 Returns true if a copy features must be used in update in history. More...
virtual void setMakeCopy (const bool theFlag)
 Sets true if a copy features must be used in update in history. More...
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 Model_AttributeSelectionList (TDF_Label &theLabel)
 Objects are created for features automatically. More...
virtual void reinit ()
bool merge (Model_AttributeSelection *theStart)
 Tries to merge attributes in this list with the same result shape. More...
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
Friends
class Model_Data
class Model_AttributeSelection
◆ Model_AttributeSelectionList()
Model_AttributeSelectionList::Model_AttributeSelectionList ( TDF_Label &  theLabel)
◆ append() [1/4]
void Model_AttributeSelectionList::append ( const ObjectPtr &  theContext,
const std::shared_ptr< GeomAPI_Shape > &  theSubShape,
const bool  theTemporarily = false
theContextobject where the sub-shape was selected
theSubShapeselected sub-shape (if null, the whole context is selected)
theTemporarilyif it is true, do not store and name the added in the data framework (used to remove immediately, without the following updates)
Implements ModelAPI_AttributeSelectionList.
◆ append() [2/4]
void Model_AttributeSelectionList::append ( const std::wstring &  theNamingName,
const std::string &  theType = ""
◆ append() [3/4]
void Model_AttributeSelectionList::append ( const std::shared_ptr< GeomAPI_Pnt > &  thePoint,
const std::string &  theType,
const bool  theIsIgnoreGroups = false
◆ append() [4/4]
void Model_AttributeSelectionList::append ( const std::string &  theType,
const std::wstring &  theContextName,
const int  theIndex
◆ copyTo()
void Model_AttributeSelectionList::copyTo ( AttributeSelectionListPtr  theTarget) const
◆ removeTemporaryValues()
void Model_AttributeSelectionList::removeTemporaryValues ( )
◆ removeLast()
void Model_AttributeSelectionList::removeLast ( )
◆ remove()
void Model_AttributeSelectionList::remove ( const std::set< int > &  theIndices)
theIndicesa list of indices of elements to be removed
◆ size()
int Model_AttributeSelectionList::size ( )
◆ isInList()
bool Model_AttributeSelectionList::isInList ( const ObjectPtr &  theContext,
theTemporarilyif it is true, it checks also the temporary added item
true if the pair is found in the attribute
◆ selectionType()
const std::string Model_AttributeSelectionList::selectionType ( ) const
the index of the OCCT enumeration of the type of shape
◆ setSelectionType()
void Model_AttributeSelectionList::setSelectionType ( const std::string &  theType)
theTypethe index of the OCCT enumeration of the type of shape
◆ value()
std::shared_ptr< ModelAPI_AttributeSelection > Model_AttributeSelectionList::value ( const int  theIndex)
◆ clear()
void Model_AttributeSelectionList::clear ( )
◆ isInitialized()
bool Model_AttributeSelectionList::isInitialized ( )
Reimplemented from ModelAPI_Attribute.
◆ cashValues()
void Model_AttributeSelectionList::cashValues ( const bool  theEnabled)
◆ setGeometricalSelection()
void Model_AttributeSelectionList::setGeometricalSelection ( const bool  theIsGeometricalSelection)
overridevirtual
◆ isGeometricalSelection()
bool Model_AttributeSelectionList::isGeometricalSelection ( ) const
overridevirtual
◆ filters()
FiltersFeaturePtr Model_AttributeSelectionList::filters ( ) const
◆ setFilters()
void Model_AttributeSelectionList::setFilters ( FiltersFeaturePtr  theFeature)
◆ applyFilters()
void Model_AttributeSelectionList::applyFilters ( )
◆ removeFilters()
void Model_AttributeSelectionList::removeFilters ( )
◆ reinit()
void Model_AttributeSelectionList::reinit ( )
◆ merge()
bool Model_AttributeSelectionList::merge ( Model_AttributeSelection *  theStart)
Returns true if theStart matches with some later attribute and theStart is removed from the list.
◆ typeId()
static std::string ModelAPI_AttributeSelectionList::typeId ( )
inlinestaticinherited
◆ attributeType()
std::string ModelAPI_AttributeSelectionList::attributeType ( )
◆ isWholeResultAllowed()
virtual const bool ModelAPI_AttributeSelectionList::isWholeResultAllowed ( ) const
inlinevirtualinherited
◆ setWholeResultAllowed()
virtual void ModelAPI_AttributeSelectionList::setWholeResultAllowed ( const bool  theFlag)
◆ isMakeCopy()
virtual const bool ModelAPI_AttributeSelectionList::isMakeCopy ( ) const
◆ setMakeCopy()
virtual void ModelAPI_AttributeSelectionList::setMakeCopy ( const bool  theFlag)
◆ setObject()
◆ owner()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
