Interface to the topological shape object. More...
#include <GeomAPI_Shape.h>
Data Structures | |
| class | Comparator |
| Compare addresses of shapes. More... | |
| class | ComparatorWithOri |
| Compare addresses of shapes with respect to orientation of shapes. More... | |
| class | Equal |
| class | Hash |
| Hash code for the shape. More... | |
Public Types | |
| enum | ShapeType { COMPOUND , COMPSOLID , SOLID , SHELL , FACE , WIRE , EDGE , VERTEX , SHAPE } |
| Shape type enum. More... | |
| enum | Orientation { FORWARD , REVERSED , INTERNAL , EXTERNAL } |
| Shape orientation. More... | |
| GEOMAPI_EXPORT | GeomAPI_Shape () |
| Creation of empty (null) shape. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shape > | emptyCopied () const |
| GEOMAPI_EXPORT bool | isNull () const |
| Returns true if the underlied shape is null. More... | |
| virtual GEOMAPI_EXPORT bool | isEqual (const std::shared_ptr< GeomAPI_Shape > theShape) const |
| Returns whether the shapes are equal. More... | |
| virtual GEOMAPI_EXPORT bool | isSame (const std::shared_ptr< GeomAPI_Shape > theShape) const |
| Returns whether the shapes are same. More... | |
| virtual GEOMAPI_EXPORT bool | isSameGeometry (const std::shared_ptr< GeomAPI_Shape > theShape) const |
Returns true if shapes have same underlying geometry. More... | |
| virtual GEOMAPI_EXPORT bool | isVertex () const |
| Returns whether the shape is a vertex. More... | |
| virtual GEOMAPI_EXPORT bool | isEdge () const |
| Returns whether the shape is an edge. More... | |
| virtual GEOMAPI_EXPORT bool | isWire () const |
| Returns whether the shape is a wire. More... | |
| virtual GEOMAPI_EXPORT bool | isFace () const |
| Returns whether the shape is a face. More... | |
| virtual GEOMAPI_EXPORT bool | isShell () const |
| Returns whether the shape is a shell. More... | |
| virtual GEOMAPI_EXPORT bool | isCompound () const |
| Returns whether the shape is a compound. More... | |
| virtual GEOMAPI_EXPORT bool | isCompoundOfSolids () const |
| Returns whether the shape is a compound of solids. More... | |
| virtual GEOMAPI_EXPORT bool | isCollectionOfSolids () const |
| Returns true, if the shape contains only solids, compsolids and compounds of solids and compsolids of any nesting depth. More... | |
| virtual GEOMAPI_EXPORT bool | isConnectedTopology () const |
| Returns whether the shape is a compound where all elements are topologically connected. More... | |
| virtual GEOMAPI_EXPORT bool | isSolid () const |
| Returns whether the shape is a solid. More... | |
| virtual GEOMAPI_EXPORT bool | isCompSolid () const |
| Returns whether the shape is a compsolid. More... | |
| virtual GEOMAPI_EXPORT bool | isPlanar () const |
| Returns whether the shape is planar. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Vertex > | vertex () const |
| Returns vertex or empty shape. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Edge > | edge () const |
| Returns edge or empty shape. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Wire > | wire () const |
| Returns wire or empty shape. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Face > | face () const |
| Returns face or empty shape. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shell > | shell () const |
| Returns shell or empty shape. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Solid > | solid () const |
| Returns solid or empty shape. More... | |
| GEOMAPI_EXPORT std::list< std::shared_ptr< GeomAPI_Shape > > | subShapes (const ShapeType theSubShapeType, const bool theOnlyUnique=false) const |
| Returns list of sub-shapes of the given type. More... | |
| virtual GEOMAPI_EXPORT ShapeType | shapeType () const |
| Returns the shape type. More... | |
| virtual GEOMAPI_EXPORT std::string | shapeTypeStr () const |
| virtual GEOMAPI_EXPORT Orientation | orientation () const |
| virtual GEOMAPI_EXPORT void | setOrientation (const Orientation theOrientation) |
| Sets the shape orientation. More... | |
| virtual GEOMAPI_EXPORT void | reverse () |
| Reverse shape. More... | |
| virtual GEOMAPI_EXPORT bool | isSubShape (const std::shared_ptr< GeomAPI_Shape > theShape, const bool theCheckOrientation=true) const |
| GEOMAPI_EXPORT bool | computeSize (double &theXmin, double &theYmin, double &theZmin, double &theXmax, double &theYmax, double &theZmax) const |
| Computes boundary dimensions of the shape Returns False if it is not possible. More... | |
| virtual GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > | middlePoint () const |
| Return middle point on the shape. More... | |
| GEOMAPI_EXPORT std::string | getShapeStream (const bool theWithTriangulation=true) const |
| Returns the shape as BRep stream. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shape > | intersect (const std::shared_ptr< GeomAPI_Shape > theShape) const |
| Returns intersection of shapes. More... | |
| GEOMAPI_EXPORT bool | isIntersect (const std::shared_ptr< GeomAPI_Shape > theShape) const |
| Returns true if min distance between shapes < tolerance. More... | |
| GEOMAPI_EXPORT void | translate (const std::shared_ptr< GeomAPI_Dir > theDir, const double theOffset) |
| Translates the shape along the direction for the given offset. More... | |
| GEOMAPI_EXPORT void | move (const std::shared_ptr< GeomAPI_Trsf > theTransformation) |
| Moves the shape with the given transformation matrix. More... | |
| GEOMAPI_EXPORT ShapeType | typeOfCompoundShapes () const |
| Returns type of shapes in the compound. More... | |
| GEOMAPI_EXPORT bool | isSelfIntersected (const int theLevelOfCheck=9) const |
| Returns true if shape have self-intersections. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
| static GEOMAPI_EXPORT ShapeType | shapeTypeByStr (std::string theType) |
| Returns the type enumeration by the string-type. More... | |
Shape type enum.
Shape orientation.
| GeomAPI_Shape::GeomAPI_Shape | ( | ) |
| std::shared_ptr< GeomAPI_Shape > GeomAPI_Shape::emptyCopied | ( | ) | const |
| bool GeomAPI_Shape::isNull | ( | ) | const |
Reimplemented in GeomAPI_Edge, GeomAPI_Face, GeomAPI_PlanarEdges, and GeomAPI_Vertex.
Reimplemented in GeomAPI_Edge, and GeomAPI_Face.
Reimplemented in GeomAPI_PlanarEdges.
| std::shared_ptr< GeomAPI_Vertex > GeomAPI_Shape::vertex | ( | ) | const |
| std::shared_ptr< GeomAPI_Edge > GeomAPI_Shape::edge | ( | ) | const |
| std::shared_ptr< GeomAPI_Wire > GeomAPI_Shape::wire | ( | ) | const |
| std::shared_ptr< GeomAPI_Face > GeomAPI_Shape::face | ( | ) | const |
| std::shared_ptr< GeomAPI_Shell > GeomAPI_Shape::shell | ( | ) | const |
| std::shared_ptr< GeomAPI_Solid > GeomAPI_Shape::solid | ( | ) | const |
| std::list< std::shared_ptr< GeomAPI_Shape > > GeomAPI_Shape::subShapes | ( | const ShapeType | theSubShapeType, |
| const bool | theOnlyUnique = false |
| ) | const |
| theSubShapeType | type of sub-shapes to search. |
| theOnlyUnique | set it to true to omit subsequent inclusions of the same sub-shape. By default it is false. |
static |
Reverse shape.
| theShape | shape to search. |
| theCheckOrientation | if false, returns true even if orientation of shape differs |
| bool GeomAPI_Shape::computeSize | ( | double & | theXmin, |
| double & | theYmin, | ||
| double & | theZmin, | ||
| double & | theXmax, | ||
| double & | theYmax, | ||
| double & | theZmax | ||
| ) | const |
Reimplemented in GeomAPI_Edge, GeomAPI_Face, GeomAPI_Shell, GeomAPI_Solid, and GeomAPI_Wire.
| std::string GeomAPI_Shape::getShapeStream | ( | const bool | theWithTriangulation = true | ) | const |
| GeomShapePtr GeomAPI_Shape::intersect | ( | const std::shared_ptr< GeomAPI_Shape > | theShape | ) | const |
| bool GeomAPI_Shape::isIntersect | ( | const std::shared_ptr< GeomAPI_Shape > | theShape | ) | const |
| void GeomAPI_Shape::translate | ( | const std::shared_ptr< GeomAPI_Dir > | theDir, |
| const double | theOffset | ||
| void GeomAPI_Shape::move | ( | const std::shared_ptr< GeomAPI_Trsf > | theTransformation | ) |
| GeomAPI_Shape::ShapeType GeomAPI_Shape::typeOfCompoundShapes | ( | ) | const |
| bool GeomAPI_Shape::isSelfIntersected | ( | const int | theLevelOfCheck = 9 | ) | const |
| [in] | theLevelOfCheck | defines which interferences will be checked: 0 - only V/V; 1 - V/V and V/E; 2 - V/V, V/E and E/E; 3 - V/V, V/E, E/E and V/F; 4 - V/V, V/E, E/E, V/F and E/F; 5 - V/V, V/E, E/E, V/F, E/F and F/F; 6 - V/V, V/E, E/E, V/F, E/F, F/F and V/S; 7 - V/V, V/E, E/E, V/F, E/F, F/F, V/S and E/S; 8 - V/V, V/E, E/E, V/F, E/F, F/F, V/S, E/S and F/S; 9 - V/V, V/E, E/E, V/F, E/F, F/F, V/S, E/S, F/S and S/S - all interferences (Default value) |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
