GeomAPI_PlanarEdges Class Reference
Interface to the set of edges located in one plane. More...
#include <GeomAPI_PlanarEdges.h>
Inheritance diagram for GeomAPI_PlanarEdges:
enum  ShapeType {
  COMPOUND , COMPSOLID , SOLID , SHELL ,
  FACE , WIRE , EDGE , VERTEX ,
  SHAPE
 Shape type enum. More...
enum  Orientation { FORWARD , REVERSED , INTERNAL , EXTERNAL }
 Shape orientation. More...
 GeomAPI_PlanarEdges ()
 Creation of empty (null) shape. More...
virtual bool isVertex () const
 Returns whether the shape is alone vertex. More...
virtual bool isEdge () const
 Returns whether the shape is alone edge. More...
void addEdge (std::shared_ptr< GeomAPI_Shape > theEdge)
 Appends the edge to the set. More...
std::list< std::shared_ptr< GeomAPI_Shape > > getEdges ()
 Returns the list of edges in this interface. More...
bool hasPlane () const
 Returns True if the wire is defined in a plane. More...
std::shared_ptr< GeomAPI_Pnt > origin () const
 Returns the plane origin point. More...
std::shared_ptr< GeomAPI_Dir > dirX () const
 Returns X direction vector. More...
std::shared_ptr< GeomAPI_Dir > dirY () const
 Returns Y direction vector. More...
std::shared_ptr< GeomAPI_Dir > norm () const
 Returns Z direction vector. More...
virtual bool isPlanar () const
 Returns whether the shape is planar. More...
void setPlane (const std::shared_ptr< GeomAPI_Pnt > &theOrigin, const std::shared_ptr< GeomAPI_Dir > &theDirX, const std::shared_ptr< GeomAPI_Dir > &theNorm)
 Set working plane. More...
virtual bool isEqual (const std::shared_ptr< GeomAPI_Shape > theShape) const
 Returns whether the shapes are equal. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shape > emptyCopied () const
GEOMAPI_EXPORT bool isNull () const
 Returns true if the underlied shape is null. More...
virtual GEOMAPI_EXPORT bool isSame (const std::shared_ptr< GeomAPI_Shape > theShape) const
 Returns whether the shapes are same. More...
virtual GEOMAPI_EXPORT bool isSameGeometry (const std::shared_ptr< GeomAPI_Shape > theShape) const
 Returns true if shapes have same underlying geometry. More...
virtual GEOMAPI_EXPORT bool isWire () const
 Returns whether the shape is a wire. More...
virtual GEOMAPI_EXPORT bool isFace () const
 Returns whether the shape is a face. More...
virtual GEOMAPI_EXPORT bool isShell () const
 Returns whether the shape is a shell. More...
virtual GEOMAPI_EXPORT bool isCompound () const
 Returns whether the shape is a compound. More...
virtual GEOMAPI_EXPORT bool isCompoundOfSolids () const
 Returns whether the shape is a compound of solids. More...
virtual GEOMAPI_EXPORT bool isCollectionOfSolids () const
 Returns true, if the shape contains only solids, compsolids and compounds of solids and compsolids of any nesting depth. More...
virtual GEOMAPI_EXPORT bool isConnectedTopology () const
 Returns whether the shape is a compound where all elements are topologically connected. More...
virtual GEOMAPI_EXPORT bool isSolid () const
 Returns whether the shape is a solid. More...
virtual GEOMAPI_EXPORT bool isCompSolid () const
 Returns whether the shape is a compsolid. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Vertex > vertex () const
 Returns vertex or empty shape. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Edge > edge () const
 Returns edge or empty shape. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Wire > wire () const
 Returns wire or empty shape. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Face > face () const
 Returns face or empty shape. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shell > shell () const
 Returns shell or empty shape. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Solid > solid () const
 Returns solid or empty shape. More...
GEOMAPI_EXPORT std::list< std::shared_ptr< GeomAPI_Shape > > subShapes (const ShapeType theSubShapeType, const bool theOnlyUnique=false) const
 Returns list of sub-shapes of the given type. More...
virtual GEOMAPI_EXPORT ShapeType shapeType () const
 Returns the shape type. More...
virtual GEOMAPI_EXPORT std::string shapeTypeStr () const
virtual GEOMAPI_EXPORT Orientation orientation () const
virtual GEOMAPI_EXPORT void setOrientation (const Orientation theOrientation)
 Sets the shape orientation. More...
virtual GEOMAPI_EXPORT void reverse ()
 Reverse shape. More...
virtual GEOMAPI_EXPORT bool isSubShape (const std::shared_ptr< GeomAPI_Shape > theShape, const bool theCheckOrientation=true) const
GEOMAPI_EXPORT bool computeSize (double &theXmin, double &theYmin, double &theZmin, double &theXmax, double &theYmax, double &theZmax) const
 Computes boundary dimensions of the shape Returns False if it is not possible. More...
virtual GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > middlePoint () const
 Return middle point on the shape. More...
GEOMAPI_EXPORT std::string getShapeStream (const bool theWithTriangulation=true) const
 Returns the shape as BRep stream. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shape > intersect (const std::shared_ptr< GeomAPI_Shape > theShape) const
 Returns intersection of shapes. More...
GEOMAPI_EXPORT bool isIntersect (const std::shared_ptr< GeomAPI_Shape > theShape) const
 Returns true if min distance between shapes < tolerance. More...
GEOMAPI_EXPORT void translate (const std::shared_ptr< GeomAPI_Dir > theDir, const double theOffset)
 Translates the shape along the direction for the given offset. More...
GEOMAPI_EXPORT void move (const std::shared_ptr< GeomAPI_Trsf > theTransformation)
 Moves the shape with the given transformation matrix. More...
GEOMAPI_EXPORT ShapeType typeOfCompoundShapes () const
 Returns type of shapes in the compound. More...
GEOMAPI_EXPORT bool isSelfIntersected (const int theLevelOfCheck=9) const
 Returns true if shape have self-intersections. More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
static GEOMAPI_EXPORT ShapeType shapeTypeByStr (std::string theType)
 Returns the type enumeration by the string-type. More...
Normally this interface corresponds to the edges of the sketch
◆ ShapeType
enum GeomAPI_Shape::ShapeType
Shape type enum.
◆ Orientation
Shape orientation.
◆ GeomAPI_PlanarEdges()
GeomAPI_PlanarEdges::GeomAPI_PlanarEdges ( )
◆ isVertex()
bool GeomAPI_PlanarEdges::isVertex ( ) const
Reimplemented from GeomAPI_Shape.
◆ isEdge()
bool GeomAPI_PlanarEdges::isEdge ( ) const
◆ addEdge()
void GeomAPI_PlanarEdges::addEdge ( std::shared_ptr< GeomAPI_Shape >  theEdge)
◆ getEdges()
std::list< std::shared_ptr< GeomAPI_Shape > > GeomAPI_PlanarEdges::getEdges ( )
◆ hasPlane()
bool GeomAPI_PlanarEdges::hasPlane ( ) const
◆ origin()
std::shared_ptr< GeomAPI_Pnt > GeomAPI_PlanarEdges::origin ( ) const
◆ dirX()
std::shared_ptr< GeomAPI_Dir > GeomAPI_PlanarEdges::dirX ( ) const
◆ dirY()
std::shared_ptr< GeomAPI_Dir > GeomAPI_PlanarEdges::dirY ( ) const
◆ norm()
std::shared_ptr< GeomAPI_Dir > GeomAPI_PlanarEdges::norm ( ) const
◆ isPlanar()
bool GeomAPI_PlanarEdges::isPlanar ( ) const
◆ setPlane()
void GeomAPI_PlanarEdges::setPlane ( const std::shared_ptr< GeomAPI_Pnt > &  theOrigin,
const std::shared_ptr< GeomAPI_Dir > &  theDirX,
const std::shared_ptr< GeomAPI_Dir > &  theNorm
Set working plane.
theOriginorigin of the plane axis
theDirXX direction of the plane axis
theNormnormal direction of the plane axis
◆ isEqual()
bool GeomAPI_PlanarEdges::isEqual ( const std::shared_ptr< GeomAPI_Shape >  theShape) const
◆ emptyCopied()
std::shared_ptr< GeomAPI_Shape > GeomAPI_Shape::emptyCopied ( ) const
a new Shape with the same Orientation and Location and a new TShape with the same geometry and no sub-shapes.
◆ isNull()
bool GeomAPI_Shape::isNull ( ) const
◆ isSame()
bool GeomAPI_Shape::isSame ( const std::shared_ptr< GeomAPI_Shape >  theShape) const
◆ isSameGeometry()
bool GeomAPI_Shape::isSameGeometry ( const std::shared_ptr< GeomAPI_Shape >  theShape) const
Reimplemented in GeomAPI_Edge, and GeomAPI_Face.
◆ isWire()
bool GeomAPI_Shape::isWire ( ) const
◆ isFace()
bool GeomAPI_Shape::isFace ( ) const
◆ isShell()
bool GeomAPI_Shape::isShell ( ) const
◆ isCompound()
bool GeomAPI_Shape::isCompound ( ) const
◆ isCompoundOfSolids()
bool GeomAPI_Shape::isCompoundOfSolids ( ) const
◆ isCollectionOfSolids()
bool GeomAPI_Shape::isCollectionOfSolids ( ) const
◆ isConnectedTopology()
bool GeomAPI_Shape::isConnectedTopology ( ) const
◆ isSolid()
bool GeomAPI_Shape::isSolid ( ) const
◆ isCompSolid()
bool GeomAPI_Shape::isCompSolid ( ) const
◆ vertex()
std::shared_ptr< GeomAPI_Vertex > GeomAPI_Shape::vertex ( ) const
◆ edge()
std::shared_ptr< GeomAPI_Edge > GeomAPI_Shape::edge ( ) const
◆ wire()
std::shared_ptr< GeomAPI_Wire > GeomAPI_Shape::wire ( ) const
◆ face()
std::shared_ptr< GeomAPI_Face > GeomAPI_Shape::face ( ) const
◆ shell()
std::shared_ptr< GeomAPI_Shell > GeomAPI_Shape::shell ( ) const
◆ solid()
std::shared_ptr< GeomAPI_Solid > GeomAPI_Shape::solid ( ) const
◆ subShapes()
std::list< std::shared_ptr< GeomAPI_Shape > > GeomAPI_Shape::subShapes ( const ShapeType  theSubShapeType,
const bool  theOnlyUnique = false
theSubShapeTypetype of sub-shapes to search.
theOnlyUniqueset it to true to omit subsequent inclusions of the same sub-shape. By default it is false.
◆ shapeType()
GeomAPI_Shape::ShapeType GeomAPI_Shape::shapeType ( ) const
◆ shapeTypeByStr()
GeomAPI_Shape::ShapeType GeomAPI_Shape::shapeTypeByStr ( std::string  theType)
◆ shapeTypeStr()
std::string GeomAPI_Shape::shapeTypeStr ( ) const
the shape type as string.
◆ orientation()
GeomAPI_Shape::Orientation GeomAPI_Shape::orientation ( ) const
◆ setOrientation()
void GeomAPI_Shape::setOrientation ( const Orientation  theOrientation)
◆ reverse()
void GeomAPI_Shape::reverse ( )
Reverse shape.
◆ isSubShape()
bool GeomAPI_Shape::isSubShape ( const std::shared_ptr< GeomAPI_Shape >  theShape,
const bool  theCheckOrientation = true
true if passed shape is a sub-shape of this shape.
theShapeshape to search.
theCheckOrientationif false, returns true even if orientation of shape differs
◆ computeSize()
bool GeomAPI_Shape::computeSize ( double &  theXmin,
double &  theYmin,
double &  theZmin,
double &  theXmax,
double &  theYmax,
double &  theZmax
◆ middlePoint()
GeomPointPtr GeomAPI_Shape::middlePoint ( ) const
Reimplemented in GeomAPI_Edge, GeomAPI_Face, GeomAPI_Shell, GeomAPI_Solid, and GeomAPI_Wire.
◆ getShapeStream()
std::string GeomAPI_Shape::getShapeStream ( const bool  theWithTriangulation = true) const
◆ intersect()
GeomShapePtr GeomAPI_Shape::intersect ( const std::shared_ptr< GeomAPI_Shape >  theShape) const
◆ isIntersect()
bool GeomAPI_Shape::isIntersect ( const std::shared_ptr< GeomAPI_Shape >  theShape) const
◆ translate()
void GeomAPI_Shape::translate ( const std::shared_ptr< GeomAPI_Dir >  theDir,
◆ move()
void GeomAPI_Shape::move ( const std::shared_ptr< GeomAPI_Trsf >  theTransformation)
◆ typeOfCompoundShapes()
GeomAPI_Shape::ShapeType GeomAPI_Shape::typeOfCompoundShapes ( ) const
◆ isSelfIntersected()
bool GeomAPI_Shape::isSelfIntersected ( const int  theLevelOfCheck = 9) const
[in]theLevelOfCheckdefines which interferences will be checked:
0 - only V/V;
1 - V/V and V/E;
2 - V/V, V/E and E/E;
3 - V/V, V/E, E/E and V/F;
4 - V/V, V/E, E/E, V/F and E/F;
5 - V/V, V/E, E/E, V/F, E/F and F/F;
6 - V/V, V/E, E/E, V/F, E/F, F/F and V/S;
7 - V/V, V/E, E/E, V/F, E/F, F/F, V/S and E/S;
8 - V/V, V/E, E/E, V/F, E/F, F/F, V/S, E/S and F/S;
9 - V/V, V/E, E/E, V/F, E/F, F/F, V/S, E/S, F/S and S/S - all interferences (Default value)
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
