GeomAPI_Face Class Reference
Interface to the face object. More...
#include <GeomAPI_Face.h>
Inheritance diagram for GeomAPI_Face:
enum  ShapeType {
  COMPOUND , COMPSOLID , SOLID , SHELL ,
  FACE , WIRE , EDGE , VERTEX ,
  SHAPE
 Shape type enum. More...
enum  Orientation { FORWARD , REVERSED , INTERNAL , EXTERNAL }
 Shape orientation. More...
GEOMAPI_EXPORT GeomAPI_Face ()
 Creation of empty (null) shape. More...
GEOMAPI_EXPORT GeomAPI_Face (const std::shared_ptr< GeomAPI_Shape > &theShape)
 Creation of face by the face-shape. More...
virtual GEOMAPI_EXPORT bool isEqual (const std::shared_ptr< GeomAPI_Shape > theFace) const
 Returns true if the current face is geometrically equal to the given face. More...
virtual GEOMAPI_EXPORT bool isSameGeometry (const std::shared_ptr< GeomAPI_Shape > theShape) const
 Returns true if faces have same underlying surface. More...
GEOMAPI_EXPORT bool isCylindrical () const
 Returns true if the face is a cylindrical face. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pln > getPlane () const
 Returns the base plane of the face (if it is planar) with location in the center of the face. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Sphere > getSphere () const
 Returns sphere if the face is based on the spherical surface. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Cylinder > getCylinder () const
 Returns cylinder if the face is based on the cylindrical surface. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Cone > getCone () const
 Returns cone if the face is based on the conical surface. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Torus > getTorus () const
 Returns torus if the face is based on the toroidal surface. More...
virtual GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > middlePoint () const
 Returns inner point in the face. More...
virtual GEOMAPI_EXPORT bool optimalBounds (double &theUMin, double &theUMax, double &theVMin, double &theVMax) const
 Returns bounding box in UV-space. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shape > emptyCopied () const
GEOMAPI_EXPORT bool isNull () const
 Returns true if the underlied shape is null. More...
virtual GEOMAPI_EXPORT bool isSame (const std::shared_ptr< GeomAPI_Shape > theShape) const
 Returns whether the shapes are same. More...
virtual GEOMAPI_EXPORT bool isVertex () const
 Returns whether the shape is a vertex. More...
virtual GEOMAPI_EXPORT bool isEdge () const
 Returns whether the shape is an edge. More...
virtual GEOMAPI_EXPORT bool isWire () const
 Returns whether the shape is a wire. More...
virtual GEOMAPI_EXPORT bool isFace () const
 Returns whether the shape is a face. More...
virtual GEOMAPI_EXPORT bool isShell () const
 Returns whether the shape is a shell. More...
virtual GEOMAPI_EXPORT bool isCompound () const
 Returns whether the shape is a compound. More...
virtual GEOMAPI_EXPORT bool isCompoundOfSolids () const
 Returns whether the shape is a compound of solids. More...
virtual GEOMAPI_EXPORT bool isCollectionOfSolids () const
 Returns true, if the shape contains only solids, compsolids and compounds of solids and compsolids of any nesting depth. More...
virtual GEOMAPI_EXPORT bool isConnectedTopology () const
 Returns whether the shape is a compound where all elements are topologically connected. More...
virtual GEOMAPI_EXPORT bool isSolid () const
 Returns whether the shape is a solid. More...
virtual GEOMAPI_EXPORT bool isCompSolid () const
 Returns whether the shape is a compsolid. More...
virtual GEOMAPI_EXPORT bool isPlanar () const
 Returns whether the shape is planar. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Vertex > vertex () const
 Returns vertex or empty shape. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Edge > edge () const
 Returns edge or empty shape. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Wire > wire () const
 Returns wire or empty shape. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Face > face () const
 Returns face or empty shape. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shell > shell () const
 Returns shell or empty shape. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Solid > solid () const
 Returns solid or empty shape. More...
GEOMAPI_EXPORT std::list< std::shared_ptr< GeomAPI_Shape > > subShapes (const ShapeType theSubShapeType, const bool theOnlyUnique=false) const
 Returns list of sub-shapes of the given type. More...
virtual GEOMAPI_EXPORT ShapeType shapeType () const
 Returns the shape type. More...
virtual GEOMAPI_EXPORT std::string shapeTypeStr () const
virtual GEOMAPI_EXPORT Orientation orientation () const
virtual GEOMAPI_EXPORT void setOrientation (const Orientation theOrientation)
 Sets the shape orientation. More...
virtual GEOMAPI_EXPORT void reverse ()
 Reverse shape. More...
virtual GEOMAPI_EXPORT bool isSubShape (const std::shared_ptr< GeomAPI_Shape > theShape, const bool theCheckOrientation=true) const
GEOMAPI_EXPORT bool computeSize (double &theXmin, double &theYmin, double &theZmin, double &theXmax, double &theYmax, double &theZmax) const
 Computes boundary dimensions of the shape Returns False if it is not possible. More...
GEOMAPI_EXPORT std::string getShapeStream (const bool theWithTriangulation=true) const
 Returns the shape as BRep stream. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shape > intersect (const std::shared_ptr< GeomAPI_Shape > theShape) const
 Returns intersection of shapes. More...
GEOMAPI_EXPORT bool isIntersect (const std::shared_ptr< GeomAPI_Shape > theShape) const
 Returns true if min distance between shapes < tolerance. More...
GEOMAPI_EXPORT void translate (const std::shared_ptr< GeomAPI_Dir > theDir, const double theOffset)
 Translates the shape along the direction for the given offset. More...
GEOMAPI_EXPORT void move (const std::shared_ptr< GeomAPI_Trsf > theTransformation)
 Moves the shape with the given transformation matrix. More...
GEOMAPI_EXPORT ShapeType typeOfCompoundShapes () const
 Returns type of shapes in the compound. More...
GEOMAPI_EXPORT bool isSelfIntersected (const int theLevelOfCheck=9) const
 Returns true if shape have self-intersections. More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
static GEOMAPI_EXPORT ShapeType shapeTypeByStr (std::string theType)
 Returns the type enumeration by the string-type. More...
◆ ShapeType
enum GeomAPI_Shape::ShapeType
Shape type enum.
◆ Orientation
Shape orientation.
◆ GeomAPI_Face() [1/2]
GeomAPI_Face::GeomAPI_Face ( )
◆ GeomAPI_Face() [2/2]
GeomAPI_Face::GeomAPI_Face ( const std::shared_ptr< GeomAPI_Shape > &  theShape)
◆ isEqual()
bool GeomAPI_Face::isEqual ( const std::shared_ptr< GeomAPI_Shape >  theFace) const
Reimplemented from GeomAPI_Shape.
◆ isSameGeometry()
bool GeomAPI_Face::isSameGeometry ( const std::shared_ptr< GeomAPI_Shape >  theShape) const
◆ isCylindrical()
bool GeomAPI_Face::isCylindrical ( ) const
◆ getPlane()
std::shared_ptr< GeomAPI_Pln > GeomAPI_Face::getPlane ( ) const
◆ getSphere()
std::shared_ptr< GeomAPI_Sphere > GeomAPI_Face::getSphere ( ) const
◆ getCylinder()
std::shared_ptr< GeomAPI_Cylinder > GeomAPI_Face::getCylinder ( ) const
◆ getCone()
std::shared_ptr< GeomAPI_Cone > GeomAPI_Face::getCone ( ) const
◆ getTorus()
std::shared_ptr< GeomAPI_Torus > GeomAPI_Face::getTorus ( ) const
◆ middlePoint()
GeomPointPtr GeomAPI_Face::middlePoint ( ) const
◆ optimalBounds()
bool GeomAPI_Face::optimalBounds ( double &  theUMin,
double &  theUMax,
double &  theVMin,
double &  theVMax
◆ emptyCopied()
std::shared_ptr< GeomAPI_Shape > GeomAPI_Shape::emptyCopied ( ) const
a new Shape with the same Orientation and Location and a new TShape with the same geometry and no sub-shapes.
◆ isNull()
bool GeomAPI_Shape::isNull ( ) const
◆ isSame()
bool GeomAPI_Shape::isSame ( const std::shared_ptr< GeomAPI_Shape >  theShape) const
◆ isVertex()
bool GeomAPI_Shape::isVertex ( ) const
Reimplemented in GeomAPI_PlanarEdges.
◆ isEdge()
bool GeomAPI_Shape::isEdge ( ) const
◆ isWire()
bool GeomAPI_Shape::isWire ( ) const
◆ isFace()
bool GeomAPI_Shape::isFace ( ) const
◆ isShell()
bool GeomAPI_Shape::isShell ( ) const
◆ isCompound()
bool GeomAPI_Shape::isCompound ( ) const
◆ isCompoundOfSolids()
bool GeomAPI_Shape::isCompoundOfSolids ( ) const
◆ isCollectionOfSolids()
bool GeomAPI_Shape::isCollectionOfSolids ( ) const
◆ isConnectedTopology()
bool GeomAPI_Shape::isConnectedTopology ( ) const
◆ isSolid()
bool GeomAPI_Shape::isSolid ( ) const
◆ isCompSolid()
bool GeomAPI_Shape::isCompSolid ( ) const
◆ isPlanar()
bool GeomAPI_Shape::isPlanar ( ) const
◆ vertex()
std::shared_ptr< GeomAPI_Vertex > GeomAPI_Shape::vertex ( ) const
◆ edge()
std::shared_ptr< GeomAPI_Edge > GeomAPI_Shape::edge ( ) const
◆ wire()
std::shared_ptr< GeomAPI_Wire > GeomAPI_Shape::wire ( ) const
◆ face()
std::shared_ptr< GeomAPI_Face > GeomAPI_Shape::face ( ) const
◆ shell()
std::shared_ptr< GeomAPI_Shell > GeomAPI_Shape::shell ( ) const
◆ solid()
std::shared_ptr< GeomAPI_Solid > GeomAPI_Shape::solid ( ) const
◆ subShapes()
std::list< std::shared_ptr< GeomAPI_Shape > > GeomAPI_Shape::subShapes ( const ShapeType  theSubShapeType,
const bool  theOnlyUnique = false
theSubShapeTypetype of sub-shapes to search.
theOnlyUniqueset it to true to omit subsequent inclusions of the same sub-shape. By default it is false.
◆ shapeType()
GeomAPI_Shape::ShapeType GeomAPI_Shape::shapeType ( ) const
◆ shapeTypeByStr()
GeomAPI_Shape::ShapeType GeomAPI_Shape::shapeTypeByStr ( std::string  theType)
◆ shapeTypeStr()
std::string GeomAPI_Shape::shapeTypeStr ( ) const
the shape type as string.
◆ orientation()
GeomAPI_Shape::Orientation GeomAPI_Shape::orientation ( ) const
◆ setOrientation()
void GeomAPI_Shape::setOrientation ( const Orientation  theOrientation)
◆ reverse()
void GeomAPI_Shape::reverse ( )
Reverse shape.
◆ isSubShape()
bool GeomAPI_Shape::isSubShape ( const std::shared_ptr< GeomAPI_Shape >  theShape,
const bool  theCheckOrientation = true
true if passed shape is a sub-shape of this shape.
theShapeshape to search.
theCheckOrientationif false, returns true even if orientation of shape differs
◆ computeSize()
bool GeomAPI_Shape::computeSize ( double &  theXmin,
double &  theYmin,
double &  theZmin,
double &  theXmax,
double &  theYmax,
double &  theZmax
◆ getShapeStream()
std::string GeomAPI_Shape::getShapeStream ( const bool  theWithTriangulation = true) const
◆ intersect()
GeomShapePtr GeomAPI_Shape::intersect ( const std::shared_ptr< GeomAPI_Shape >  theShape) const
◆ isIntersect()
bool GeomAPI_Shape::isIntersect ( const std::shared_ptr< GeomAPI_Shape >  theShape) const
◆ translate()
void GeomAPI_Shape::translate ( const std::shared_ptr< GeomAPI_Dir >  theDir,
◆ move()
void GeomAPI_Shape::move ( const std::shared_ptr< GeomAPI_Trsf >  theTransformation)
◆ typeOfCompoundShapes()
GeomAPI_Shape::ShapeType GeomAPI_Shape::typeOfCompoundShapes ( ) const
◆ isSelfIntersected()
bool GeomAPI_Shape::isSelfIntersected ( const int  theLevelOfCheck = 9) const
[in]theLevelOfCheckdefines which interferences will be checked:
0 - only V/V;
1 - V/V and V/E;
2 - V/V, V/E and E/E;
3 - V/V, V/E, E/E and V/F;
4 - V/V, V/E, E/E, V/F and E/F;
5 - V/V, V/E, E/E, V/F, E/F and F/F;
6 - V/V, V/E, E/E, V/F, E/F, F/F and V/S;
7 - V/V, V/E, E/E, V/F, E/F, F/F, V/S and E/S;
8 - V/V, V/E, E/E, V/F, E/F, F/F, V/S, E/S and F/S;
9 - V/V, V/E, E/E, V/F, E/F, F/F, V/S, E/S, F/S and S/S - all interferences (Default value)
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
