GeomAPI_Pln Class Reference
\Plane in 3D place, defined by normal, center and x-direction. More...
#include <GeomAPI_Pln.h>
Inheritance diagram for GeomAPI_Pln:
GEOMAPI_EXPORT GeomAPI_Pln (const std::shared_ptr< GeomAPI_Ax3 > &theAxes)
 Creation of plane by the axis placement. More...
GEOMAPI_EXPORT GeomAPI_Pln (const std::shared_ptr< GeomAPI_Pnt > &thePoint, const std::shared_ptr< GeomAPI_Dir > &theNormal)
 Creation of plane by the point and normal. More...
GEOMAPI_EXPORT GeomAPI_Pln (const double theA, const double theB, const double theC, const double theD)
 Creation of plane by coefficients (Ax+By+Cz+D=0) More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > location () const
 Returns a point of this plane. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Dir > direction () const
 Returns a plane normal. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Dir > xDirection () const
 Returns a plane x direction. More...
GEOMAPI_EXPORT void coefficients (double &theA, double &theB, double &theC, double &theD)
 Returns the plane coefficients (Ax+By+Cz+D=0) More...
GEOMAPI_EXPORT bool isCoincident (const std::shared_ptr< GeomAPI_Pln > thePlane, const double theTolerance=1.e-7)
 Returns true if planes are coincident. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > intersect (const std::shared_ptr< GeomAPI_Lin > &theLine) const
 Returns intersection point or empty if no intersections. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > project (const std::shared_ptr< GeomAPI_Pnt > &thePoint) const
 Returns projection of the given point onto the plane. More...
GEOMAPI_EXPORT double distance (const std::shared_ptr< GeomAPI_Pln > thePlane) const
GEOMAPI_EXPORT double distance (const std::shared_ptr< GeomAPI_Pnt > thePoint) const
GEOMAPI_EXPORT void translate (const std::shared_ptr< GeomAPI_Dir > theDir, const double theDist)
 Translates the plane along direction theDir on distance theDist. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Lin > intersect (const std::shared_ptr< GeomAPI_Pln > thePlane) const
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
◆ GeomAPI_Pln() [1/3]
GeomAPI_Pln::GeomAPI_Pln ( const std::shared_ptr< GeomAPI_Ax3 > &  theAxes)
◆ GeomAPI_Pln() [2/3]
GeomAPI_Pln::GeomAPI_Pln ( const std::shared_ptr< GeomAPI_Pnt > &  thePoint,
const std::shared_ptr< GeomAPI_Dir > &  theNormal
◆ GeomAPI_Pln() [3/3]
GeomAPI_Pln::GeomAPI_Pln ( const double  theA,
const double  theB,
const double  theC,
const double  theD
◆ location()
std::shared_ptr< GeomAPI_Pnt > GeomAPI_Pln::location ( ) const
◆ direction()
std::shared_ptr< GeomAPI_Dir > GeomAPI_Pln::direction ( ) const
◆ xDirection()
std::shared_ptr< GeomAPI_Dir > GeomAPI_Pln::xDirection ( ) const
◆ coefficients()
void GeomAPI_Pln::coefficients ( double &  theA,
double &  theB,
double &  theC,
double &  theD
◆ isCoincident()
bool GeomAPI_Pln::isCoincident ( const std::shared_ptr< GeomAPI_Pln >  thePlane,
const double  theTolerance = 1.e-7
◆ intersect() [1/2]
std::shared_ptr< GeomAPI_Pnt > GeomAPI_Pln::intersect ( const std::shared_ptr< GeomAPI_Lin > &  theLine) const
◆ project()
std::shared_ptr< GeomAPI_Pnt > GeomAPI_Pln::project ( const std::shared_ptr< GeomAPI_Pnt > &  thePoint) const
◆ distance() [1/2]
double GeomAPI_Pln::distance ( const std::shared_ptr< GeomAPI_Pln >  thePlane) const
distance between planes.
◆ distance() [2/2]
double GeomAPI_Pln::distance ( const std::shared_ptr< GeomAPI_Pnt >  thePoint) const
distance from a point to this plane.
◆ translate()
void GeomAPI_Pln::translate ( const std::shared_ptr< GeomAPI_Dir >  theDir,
◆ intersect() [2/2]
std::shared_ptr< GeomAPI_Lin > GeomAPI_Pln::intersect ( const std::shared_ptr< GeomAPI_Pln >  thePlane) const
intersection line of two planes. Empty if they are parallel.
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
