GeomAPI_Ax3 Class Reference
The class represents a coordinate plane which is 2d plane with X and Y directions and origin. More...
#include <GeomAPI_Ax3.h>
Inheritance diagram for GeomAPI_Ax3:
 GeomAPI_Ax3 ()
 Default constructor. More...
 GeomAPI_Ax3 (std::shared_ptr< GeomAPI_Pnt > theOrigin, std::shared_ptr< GeomAPI_Dir > theDirX, std::shared_ptr< GeomAPI_Dir > theNorm)
void setOrigin (const std::shared_ptr< GeomAPI_Pnt > &theOrigin)
 Sets origin point. More...
std::shared_ptr< GeomAPI_Pnt > origin () const
 Returns the plane origin point. More...
void setDirX (const std::shared_ptr< GeomAPI_Dir > &theDirX)
 Sets X direction vector. More...
std::shared_ptr< GeomAPI_Dir > dirX () const
 Returns X direction vector. More...
void setDirY (const std::shared_ptr< GeomAPI_Dir > &theDirY)
 Sets Y direction vector. More...
std::shared_ptr< GeomAPI_Dir > dirY () const
 Returns Y direction vector. More...
void setNormal (const std::shared_ptr< GeomAPI_Dir > &theNorm)
 Sets Z direction vector. More...
std::shared_ptr< GeomAPI_Dir > normal () const
 Returns Z direction vector. More...
std::shared_ptr< GeomAPI_Pnt > to3D (double theX, double theY) const
 Converts 2d coordinates from the plane to 3d space point. More...
std::shared_ptr< GeomAPI_Pnt2d > to2D (double theX, double theY, double theZ) const
 Converts 3d to 2d coordinates of the plane. More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
◆ GeomAPI_Ax3() [1/2]
GeomAPI_Ax3::GeomAPI_Ax3 ( )
◆ GeomAPI_Ax3() [2/2]
GeomAPI_Ax3::GeomAPI_Ax3 ( std::shared_ptr< GeomAPI_Pnt >  theOrigin,
theOriginpoint of origin
theDirXdirection of X axis
theNormdirection of normal vector
◆ setOrigin()
void GeomAPI_Ax3::setOrigin ( const std::shared_ptr< GeomAPI_Pnt > &  theOrigin)
Sets origin point.
◆ origin()
std::shared_ptr< GeomAPI_Pnt > GeomAPI_Ax3::origin ( ) const
◆ setDirX()
void GeomAPI_Ax3::setDirX ( const std::shared_ptr< GeomAPI_Dir > &  theDirX)
◆ dirX()
std::shared_ptr< GeomAPI_Dir > GeomAPI_Ax3::dirX ( ) const
◆ setDirY()
void GeomAPI_Ax3::setDirY ( const std::shared_ptr< GeomAPI_Dir > &  theDirY)
◆ dirY()
std::shared_ptr< GeomAPI_Dir > GeomAPI_Ax3::dirY ( ) const
◆ setNormal()
void GeomAPI_Ax3::setNormal ( const std::shared_ptr< GeomAPI_Dir > &  theNorm)
◆ normal()
std::shared_ptr< GeomAPI_Dir > GeomAPI_Ax3::normal ( ) const
◆ to3D()
std::shared_ptr< GeomAPI_Pnt > GeomAPI_Ax3::to3D ( double  theX,
double  theY
theXX coordinate
theYY coordinate
◆ to2D()
std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Ax3::to2D ( double  theX,
double  theY,
double  theZ
theXX coordinate
theYY coordinate
theZZ coordinate
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
