GeomAPI_Lin Class Reference
Line in 3D. More...
#include <GeomAPI_Lin.h>
Inheritance diagram for GeomAPI_Lin:
GEOMAPI_EXPORT GeomAPI_Lin (const double theStartX, const double theStartY, const double theStartZ, const double theEndX, const double theEndY, const double theEndZ)
 Creation of line defined by coordinates of start and end points. More...
GEOMAPI_EXPORT GeomAPI_Lin (const std::shared_ptr< GeomAPI_Pnt > &theStart, const std::shared_ptr< GeomAPI_Pnt > &theEnd)
 Creation of line defined by start and end points. More...
GEOMAPI_EXPORT GeomAPI_Lin (const std::shared_ptr< GeomAPI_Pnt > &theOrigin, const std::shared_ptr< GeomAPI_Dir > &theDirection)
 Creation of line defined by origin and direction. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > location ()
 Returns point on the line (first point) More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Dir > direction ()
 Returns a line direction. More...
GEOMAPI_EXPORT double distance (const std::shared_ptr< GeomAPI_Pnt > &thePoint) const
 Distance between two points. More...
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt > intersect (const std::shared_ptr< GeomAPI_Lin > &theLine) const
 Intersection of two lines. More...
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt > project (const std::shared_ptr< GeomAPI_Pnt > &thePoint) const
 Project point on line. More...
GEOMAPI_EXPORT double projParam (const std::shared_ptr< GeomAPI_Pnt > &thePoint) const
 Returns parameter of the point projection. More...
GEOMAPI_EXPORT bool contains (const std::shared_ptr< GeomAPI_Pnt > thePoint, const double theLinearTolerance=1.e-7) const
GEOMAPI_EXPORT bool isParallel (const std::shared_ptr< GeomAPI_Lin > theLin) const
GEOMAPI_EXPORT bool isCoplanar (const std::shared_ptr< GeomAPI_Lin > theLin) const
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
Line in 3D.
◆ GeomAPI_Lin() [1/3]
GeomAPI_Lin::GeomAPI_Lin ( const double  theStartX,
◆ GeomAPI_Lin() [2/3]
GeomAPI_Lin::GeomAPI_Lin ( const std::shared_ptr< GeomAPI_Pnt > &  theStart,
const std::shared_ptr< GeomAPI_Pnt > &  theEnd
◆ GeomAPI_Lin() [3/3]
GeomAPI_Lin::GeomAPI_Lin ( const std::shared_ptr< GeomAPI_Pnt > &  theOrigin,
const std::shared_ptr< GeomAPI_Dir > &  theDirection
◆ location()
std::shared_ptr< GeomAPI_Pnt > GeomAPI_Lin::location ( )
◆ direction()
std::shared_ptr< GeomAPI_Dir > GeomAPI_Lin::direction ( )
◆ distance()
double GeomAPI_Lin::distance ( const std::shared_ptr< GeomAPI_Pnt > &  thePoint) const
◆ intersect()
const std::shared_ptr< GeomAPI_Pnt > GeomAPI_Lin::intersect ( const std::shared_ptr< GeomAPI_Lin > &  theLine) const
◆ project()
const std::shared_ptr< GeomAPI_Pnt > GeomAPI_Lin::project ( const std::shared_ptr< GeomAPI_Pnt > &  thePoint) const
◆ projParam()
double GeomAPI_Lin::projParam ( const std::shared_ptr< GeomAPI_Pnt > &  thePoint) const
◆ contains()
bool GeomAPI_Lin::contains ( const std::shared_ptr< GeomAPI_Pnt >  thePoint,
const double  theLinearTolerance = 1.e-7
true if this line contains thePoint, that is, if the distance between thePoint and this line is less than or equal to theLinearTolerance.
◆ isParallel()
bool GeomAPI_Lin::isParallel ( const std::shared_ptr< GeomAPI_Lin >  theLin) const
true if lines are parallel.
◆ isCoplanar()
bool GeomAPI_Lin::isCoplanar ( const std::shared_ptr< GeomAPI_Lin >  theLin) const
true if lines are coplanar.
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
