GeomAPI_Cone Class Reference
Conical surface in 3D. More...
#include <GeomAPI_Cone.h>
Inheritance diagram for GeomAPI_Cone:
GEOMAPI_EXPORT GeomAPI_Cone (const std::shared_ptr< GeomAPI_Pnt > &theApex, const std::shared_ptr< GeomAPI_Dir > &theAxis, const double theSemiAngle)
 Creation of infinite cone defined by apex, axis and semi-angle. More...
GEOMAPI_EXPORT GeomAPI_Cone (const std::shared_ptr< GeomAPI_Pnt > &theLocation, const std::shared_ptr< GeomAPI_Dir > &theAxis, const double theSemiAngle, const double theRadius)
 Creation of semi-infinite cone by location and radius of reference circle, axis, semi-angle. More...
GEOMAPI_EXPORT GeomAPI_Cone (const std::shared_ptr< GeomAPI_Pnt > &theLocation, const std::shared_ptr< GeomAPI_Dir > &theAxis, const double theSemiAngle, const double theRadius1, const double theRadius2)
 Creating of cone by location of reference circle, axis, semi-angle and radii of boundary circles. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > apex () const
 Return apex of the cone. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > location () const
 Return location of the cone (center of the circle nearest to the apex) More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Dir > axis () const
 Return axis of the cone. More...
GEOMAPI_EXPORT double semiAngle () const
 Return semi-angle of the cone. More...
GEOMAPI_EXPORT double radius1 () const
 Return first radius of the cone or Precision::Infinite() if the cone is infinite. More...
GEOMAPI_EXPORT double radius2 () const
 Return second radius of the cone or Precision::Infinite() if the cone is infinite. More...
GEOMAPI_EXPORT double height () const
 Return height of the cone. More...
GEOMAPI_EXPORT bool isSemiInfinite () const
 Return true is the cone is semi-infinite. More...
GEOMAPI_EXPORT bool isInfinite () const
 Return true is the cone is infinite. More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
◆ GeomAPI_Cone() [1/3]
GeomAPI_Cone::GeomAPI_Cone ( const std::shared_ptr< GeomAPI_Pnt > &  theApex,
const std::shared_ptr< GeomAPI_Dir > &  theAxis,
◆ GeomAPI_Cone() [2/3]
GeomAPI_Cone::GeomAPI_Cone ( const std::shared_ptr< GeomAPI_Pnt > &  theLocation,
◆ GeomAPI_Cone() [3/3]
◆ apex()
std::shared_ptr< GeomAPI_Pnt > GeomAPI_Cone::apex ( ) const
◆ location()
std::shared_ptr< GeomAPI_Pnt > GeomAPI_Cone::location ( ) const
◆ axis()
std::shared_ptr< GeomAPI_Dir > GeomAPI_Cone::axis ( ) const
◆ semiAngle()
double GeomAPI_Cone::semiAngle ( ) const
◆ radius1()
double GeomAPI_Cone::radius1 ( ) const
◆ radius2()
double GeomAPI_Cone::radius2 ( ) const
◆ height()
double GeomAPI_Cone::height ( ) const
◆ isSemiInfinite()
bool GeomAPI_Cone::isSemiInfinite ( ) const
◆ isInfinite()
bool GeomAPI_Cone::isInfinite ( ) const
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
