GeomAPI_Cylinder Class Reference
Cylindrical surface in 3D. More...
#include <GeomAPI_Cylinder.h>
Inheritance diagram for GeomAPI_Cylinder:
GEOMAPI_EXPORT GeomAPI_Cylinder (const std::shared_ptr< GeomAPI_Pnt > &theLocation, const std::shared_ptr< GeomAPI_Dir > &theAxis, const double theRadius)
 Creation of infinite cylinder defined by location, axis and radius. More...
GEOMAPI_EXPORT GeomAPI_Cylinder (const std::shared_ptr< GeomAPI_Pnt > &theLocation, const std::shared_ptr< GeomAPI_Dir > &theAxis, const double theRadius, const double theHeight)
 Creation of cylinder defined by location, axis, radius and height. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > location () const
 Return location of the cylinder. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Dir > axis () const
 Return axis of the cylinder. More...
GEOMAPI_EXPORT double radius () const
 Return radius of the cylinder. More...
GEOMAPI_EXPORT double height () const
 Return height of the cylinder or Precision::Infinite() if the cylinder is infinite. More...
GEOMAPI_EXPORT bool isInfinite () const
 Return true is the cylinder is infinite. More...
GEOMAPI_EXPORT bool isCoincident (const std::shared_ptr< GeomAPI_Cylinder > theCylinder, const double theTolerance=1.e-7)
 Returns true if cylinders have same axis and radii. More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
◆ GeomAPI_Cylinder() [1/2]
GeomAPI_Cylinder::GeomAPI_Cylinder ( const std::shared_ptr< GeomAPI_Pnt > &  theLocation,
const std::shared_ptr< GeomAPI_Dir > &  theAxis,
◆ GeomAPI_Cylinder() [2/2]
◆ location()
std::shared_ptr< GeomAPI_Pnt > GeomAPI_Cylinder::location ( ) const
◆ axis()
std::shared_ptr< GeomAPI_Dir > GeomAPI_Cylinder::axis ( ) const
◆ radius()
double GeomAPI_Cylinder::radius ( ) const
◆ height()
double GeomAPI_Cylinder::height ( ) const
◆ isInfinite()
bool GeomAPI_Cylinder::isInfinite ( ) const
◆ isCoincident()
bool GeomAPI_Cylinder::isCoincident ( const std::shared_ptr< GeomAPI_Cylinder >  theCylinder,
const double  theTolerance = 1.e-7
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
