Attribute that contains reference to the sub-shape of some result, the selected shape. More...
#include <ModelAPI_AttributeSelection.h>
Public Types | |
| enum | CenterType { NOT_CENTER , CIRCLE_CENTER , ELLIPSE_FIRST_FOCUS , ELLIPSE_SECOND_FOCUS } |
| Type of the center of the circular of elliptic edge. More... | |
| virtual bool | setValue (const ObjectPtr &theContext, const std::shared_ptr< GeomAPI_Shape > &theSubShape, const bool theTemporarily=false)=0 |
| Defines the result and its selected sub-shape. More... | |
| virtual void | setValueCenter (const ObjectPtr &theContext, const std::shared_ptr< GeomAPI_Edge > &theEdge, const CenterType theCenterType, const bool theTemporarily=false)=0 |
| Same as SetValue, but it takes an edge (on circular or elliptic curve) and stores the vertex of the central point (for ellipse the first or the second focus point) More... | |
| virtual void | selectValue (const std::shared_ptr< ModelAPI_AttributeSelection > &theSource)=0 |
| Makes this selection attribute selects the same as in theSource selection. More... | |
| virtual void | removeTemporaryValues ()=0 |
| Reset temporary stored values. More... | |
| virtual std::shared_ptr< GeomAPI_Shape > | value ()=0 |
| Returns the selected subshape. More... | |
| virtual ResultPtr | context ()=0 |
| Returns the context of the selection (the whole shape owner) More... | |
| virtual std::shared_ptr< ModelAPI_Feature > | contextFeature ()=0 |
| Returns the context of the selection if the whole feature was selected. More... | |
| virtual std::shared_ptr< ModelAPI_Object > | contextObject ()=0 |
| Returns the context of the selection : result or feature. More... | |
| virtual bool | update ()=0 |
| Updates the selection due to the changes in the referenced objects. More... | |
| virtual std::string | attributeType () |
| Returns the type of this class of attributes, not static method. More... | |
| virtual std::wstring | namingName (const std::wstring &theDefaultValue=L"")=0 |
| Returns a textual string of the selection. More... | |
| virtual void | setId (int theID)=0 |
| Defines an id of the selection. More... | |
| virtual void | selectSubShape (const std::string &theType, const std::wstring &theSubShapeName)=0 |
| Selects sub-shape by the textual Name. More... | |
| virtual void | selectSubShape (const std::string &theType, const std::shared_ptr< GeomAPI_Pnt > &thePoint, const bool theIsIgnoreGroups=false)=0 |
| Selects sub-shape by its inner point. More... | |
| virtual void | selectSubShape (const std::string &theType, const std::wstring &theContextName, const int theIndex)=0 |
| Selects sub-shape by weak naming index. More... | |
| virtual bool | isInvalid ()=0 |
| Returns true if recompute of selection become impossible. More... | |
| virtual bool | isGeometricalSelection () const =0 |
| Returns true if is geometrical selection. More... | |
| virtual | ~ModelAPI_AttributeSelection () |
| To virtually destroy the fields of successors. More... | |
| virtual std::wstring | contextName (const ResultPtr &theContext) const =0 |
| Returns the name by context. Adds the part name if the context is located in other document. More... | |
| virtual void | combineGeometrical ()=0 |
| Makes the current local selection becomes all sub-shapes with same base geometry. More... | |
| virtual void | updateInHistory (bool &theRemove)=0 |
| Updates the arguments of selection if something was affected by creation or reorder of features upper in the history line. More... | |
| virtual void | setObject (const std::shared_ptr< ModelAPI_Object > &theObject) |
| Sets the owner of this attribute. More... | |
| const std::shared_ptr< ModelAPI_Object > & | owner () const |
| Returns the owner of this attribute. More... | |
| virtual bool | isInitialized () |
| Returns true if attribute was initialized by some value. More... | |
| void | setInitialized () |
| Makes attribute initialized. More... | |
| bool | blockSetInitialized (const bool theBlock) |
| Blocks sending "attribute updated" if theBlock is true. More... | |
| void | setIsArgument (const bool theFlag) |
| Set this attribute is argument for result (change of this attribute requires update of result). More... | |
| bool | isArgument () |
| Returns true if attribute causes the result change. More... | |
| bool | setImmutable (const bool theFlag) |
| Immutable argument can not be changed programmatically (e.g. More... | |
| bool | isImmutable () |
| Returns true if can not be changed programmatically. More... | |
| const std::string & | id () const |
| ID of the attribute in Data. More... | |
| virtual void | reset () |
| Resets attribute to default state. More... | |
| static std::string | typeId () |
| Returns the type of this class of attributes. More... | |
| ModelAPI_AttributeSelection () | |
| Objects are created for features automatically. More... | |
| virtual void | setID (const std::string theID) |
| Sets the ID of the attribute in Data (called from Data) More... | |
| virtual void | reinit () |
| Reinitializes the internal state of the attribute (may be needed on undo/redo, abort, etc) More... | |
Protected Attributes | |
| bool | myIsInitialized |
| is some value assigned to this attribute More... | |
| bool | mySetInitializedBlocked |
| is initialized blocked More... | |
| bool | myIsArgument |
| is this attribute used as an argument for execution More... | |
| bool | myIsImmutable |
| is this attribute can be changed programmatically (e.g. by constraint) More... | |
protected |
pure virtual |
| theContext | object where the sub-shape was selected |
| theSubShape | selected sub-shape (if null, the whole context is selected) |
| theTemporarily | if it is true, do not store and name the added in the data framework (used to remove immediately, without the following updates) |
Implemented in Model_AttributeSelection.
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
inlinestatic |
pure virtual |
| theDefaultValue | a value, which is used if the naming name can not be obtained |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
Returns theRemove true if this attribute must be removed (become deleted)
Reimplemented in GeomData_Dir, Model_AttributeRefAttr, Model_AttributeRefAttrList, Model_AttributeReference, Model_AttributeRefList, Model_AttributeSelection, and Model_AttributeSelectionList.
| theBlock | a block value |
By default it is true.
protectedvirtualinherited |
Reimplemented in GeomData_Dir, GeomData_Point, GeomData_Point2D, GeomData_Point2DArray, Model_AttributeBoolean, Model_AttributeDocRef, Model_AttributeDouble, Model_AttributeDoubleArray, Model_AttributeImage, Model_AttributeIntArray, Model_AttributeInteger, Model_AttributeRefAttr, Model_AttributeRefAttrList, Model_AttributeReference, Model_AttributeRefList, Model_AttributeSelectionList, Model_AttributeString, and Model_AttributeTables.
protectedinherited |
