Model_AttributeString Class Reference
Attribute that contains std (null terminated) string. More...
#include <Model_AttributeString.h>
Inheritance diagram for Model_AttributeString:
virtual MODEL_EXPORT void setValue (const std::string &theValue)
 Defines the std::string value. More...
virtual MODEL_EXPORT void setValue (const std::wstring &theValue)
 Defines the std::wstring value. More...
virtual MODEL_EXPORT std::string value ()
 Returns the std::string value. More...
virtual MODEL_EXPORT char16_t * valueU ()
 Returns a pointer to Unicode string. More...
virtual MODEL_EXPORT bool isUValue () const
 Returns true if Unicode string was stored. More...
virtual std::string attributeType ()
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 Model_AttributeString (TDF_Label &theLabel)
 Initializes attributes. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
Friends
class Model_Data
◆ Model_AttributeString()
Model_AttributeString::Model_AttributeString ( TDF_Label &  theLabel)
◆ setValue() [1/2]
void Model_AttributeString::setValue ( const std::string &  theValue)
Implements ModelAPI_AttributeString.
◆ setValue() [2/2]
void Model_AttributeString::setValue ( const std::wstring &  theValue)
◆ value()
std::string Model_AttributeString::value ( )
◆ valueU()
char16_t * Model_AttributeString::valueU ( )
◆ isUValue()
bool Model_AttributeString::isUValue ( ) const
◆ reinit()
void Model_AttributeString::reinit ( )
Reimplemented from ModelAPI_Attribute.
◆ typeId()
static std::string ModelAPI_AttributeString::typeId ( )
inlinestaticinherited
◆ attributeType()
std::string ModelAPI_AttributeString::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
