ModelAPI_AttributeString Class Referenceabstract
API for the attribute that contains std (null terminated) string. More...
#include <ModelAPI_AttributeString.h>
Inheritance diagram for ModelAPI_AttributeString:
virtual void setValue (const std::string &theValue)=0
 Defines the string value. More...
virtual void setValue (const std::wstring &theValue)=0
 Defines the wstring value. More...
virtual std::string value ()=0
 Returns the string value. More...
virtual char16_t * valueU ()=0
 Returns a pointer to Unicode string. More...
virtual bool isUValue () const =0
virtual std::string attributeType ()
virtual ~ModelAPI_AttributeString ()
 To virtually destroy the fields of successors. More...
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
◆ ~ModelAPI_AttributeString()
ModelAPI_AttributeString::~ModelAPI_AttributeString ( )
◆ ModelAPI_AttributeString()
ModelAPI_AttributeString::ModelAPI_AttributeString ( )
◆ setValue() [1/2]
virtual void ModelAPI_AttributeString::setValue ( const std::string &  theValue)
pure virtual
Implemented in Model_AttributeString.
◆ setValue() [2/2]
virtual void ModelAPI_AttributeString::setValue ( const std::wstring &  theValue)
pure virtual
◆ value()
virtual std::string ModelAPI_AttributeString::value ( )
pure virtual
◆ valueU()
virtual char16_t * ModelAPI_AttributeString::valueU ( )
pure virtual
◆ isUValue()
virtual bool ModelAPI_AttributeString::isUValue ( ) const
pure virtual
◆ typeId()
static std::string ModelAPI_AttributeString::typeId ( )
inlinestatic
◆ attributeType()
std::string ModelAPI_AttributeString::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
