Model_AttributeBoolean Class Reference
Attribute that contains real value with double precision. More...
#include <Model_AttributeBoolean.h>
Inheritance diagram for Model_AttributeBoolean:
virtual void setValue (bool theValue)
 Defines the double value. More...
virtual bool value ()
 Returns the double value. More...
virtual std::string attributeType ()
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 Model_AttributeBoolean (TDF_Label &theLabel)
 Initializes attributes. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
Friends
class Model_Data
◆ Model_AttributeBoolean()
Model_AttributeBoolean::Model_AttributeBoolean ( TDF_Label &  theLabel)
◆ setValue()
void Model_AttributeBoolean::setValue ( bool  theValue)
Implements ModelAPI_AttributeBoolean.
◆ value()
bool Model_AttributeBoolean::value ( )
◆ reinit()
void Model_AttributeBoolean::reinit ( )
Reimplemented from ModelAPI_Attribute.
◆ typeId()
static std::string ModelAPI_AttributeBoolean::typeId ( )
inlinestaticinherited
◆ attributeType()
std::string ModelAPI_AttributeBoolean::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
