Model_AttributeBoolean.h
20#ifndef Model_AttributeBoolean_H_
21#define Model_AttributeBoolean_H_
23#include "Model.h"
24#include "ModelAPI_AttributeBoolean.h"
25#include <TDataStd_Integer.hxx>
26#include <TDF_Label.hxx>
27
34{
35 Handle_TDataStd_Integer myBool;
36 TDF_Label myLab;
37 public:
39 MODEL_EXPORT virtual void setValue(bool theValue);
40
42 MODEL_EXPORT virtual bool value();
43
44 protected:
46 Model_AttributeBoolean(TDF_Label& theLabel);
47
49 virtual void reinit();
50
51 friend class Model_Data;
52};
53
54#endif
Definition: Model_AttributeBoolean.h:34
Reinitializes the internal state of the attribute (may be needed on undo/redo, abort,...
Definition: Model_AttributeBoolean.cpp:46
Returns the double value.
Definition: Model_AttributeBoolean.cpp:35
Model_AttributeBoolean(TDF_Label &theLabel)
Initializes attributes.
Definition: Model_AttributeBoolean.cpp:40
Defines the double value.
Definition: Model_AttributeBoolean.cpp:24
General object of the application that allows to get/set attributes from the document and compute res...
Definition: Model_Data.h:62
