API for the attribute that contains tables of some values type. More...
#include <Model_AttributeTables.h>
Public Types | |
| enum | ValueType { BOOLEAN , INTEGER , DOUBLE , STRING } |
| Type of the value in the table. More... | |
| virtual int | rows () |
| Returns the number of rows in the table. More... | |
| virtual int | columns () |
| Returns the number of columns in the table. More... | |
| virtual int | tables () |
| Returns the number of tables. More... | |
| virtual void | setSize (const int theRows, const int theColumns, const int theTables=1) |
| Sets the new size of the tables set. More... | |
| virtual void | setType (ValueType theType) |
| Defines the tyoe of values in the table. If it differs from the current, erases the content. More... | |
| virtual const ValueType & | type () const |
| virtual void | setValue (const Value theValue, const int theRow, const int theColumn, const int theTable=0) |
| Defines the value by the index in the tables set (indexes are zero-based). More... | |
| virtual Value | value (const int theRow, const int theColumn, const int theTable=0) |
| Returns the value by the index (indexes are zero-based). More... | |
| virtual std::string | valueStr (const int theRow, const int theColumn, const int theTable=0) |
| Returns the value in the format of string (useful for the python connection) More... | |
| virtual MODELAPI_EXPORT std::string | attributeType () |
| Returns the type of this class of attributes, not static method. More... | |
| virtual void | setObject (const std::shared_ptr< ModelAPI_Object > &theObject) |
| Sets the owner of this attribute. More... | |
| const std::shared_ptr< ModelAPI_Object > & | owner () const |
| Returns the owner of this attribute. More... | |
| virtual bool | isInitialized () |
| Returns true if attribute was initialized by some value. More... | |
| void | setInitialized () |
| Makes attribute initialized. More... | |
| bool | blockSetInitialized (const bool theBlock) |
| Blocks sending "attribute updated" if theBlock is true. More... | |
| void | setIsArgument (const bool theFlag) |
| Set this attribute is argument for result (change of this attribute requires update of result). More... | |
| bool | isArgument () |
| Returns true if attribute causes the result change. More... | |
| bool | setImmutable (const bool theFlag) |
| Immutable argument can not be changed programmatically (e.g. More... | |
| bool | isImmutable () |
| Returns true if can not be changed programmatically. More... | |
| const std::string & | id () const |
| ID of the attribute in Data. More... | |
| virtual void | reset () |
| Resets attribute to default state. More... | |
| static MODELAPI_EXPORT std::string | typeId () |
| Returns the type of this class of attributes. More... | |
| Model_AttributeTables (TDF_Label &theLabel) | |
| Objects are created for features automatically. More... | |
| virtual void | reinit () |
| Reinitializes the internal state of the attribute (may be needed on undo/redo, abort, etc) More... | |
| virtual void | setID (const std::string theID) |
| Sets the ID of the attribute in Data (called from Data) More... | |
Protected Attributes | |
| bool | myIsInitialized |
| is some value assigned to this attribute More... | |
| bool | mySetInitializedBlocked |
| is initialized blocked More... | |
| bool | myIsArgument |
| is this attribute used as an argument for execution More... | |
| bool | myIsImmutable |
| is this attribute can be changed programmatically (e.g. by constraint) More... | |
Friends | |
| class | Model_Data |
The type of values can be changed. But all the values in the tables must have the same one type. The currently allowed types now are: Boolean, Integer, Double, String. By default there is only one table, but it may be increased/decreased by adding/removing tables one by one. The number of rows and columns are equal in all tables. If table, row or column is added, the previous values are kept unchanged. New cells are filled by zero, false or empty strings.
protected |
Implements ModelAPI_AttributeTables.
This method tries to keep old values if number of rows, columns or tables is increased.
protectedvirtual |
Reimplemented from ModelAPI_Attribute.
inlinestaticinherited |
Reimplemented in GeomData_Dir, Model_AttributeRefAttr, Model_AttributeRefAttrList, Model_AttributeReference, Model_AttributeRefList, Model_AttributeSelection, and Model_AttributeSelectionList.
| theBlock | a block value |
By default it is true.
protectedvirtualinherited |
protectedinherited |
