ModelAPI_AttributeTables Class Referenceabstract
API for the attribute that contains tables of some values type. More...
#include <ModelAPI_AttributeTables.h>
Inheritance diagram for ModelAPI_AttributeTables:
struct  Value
enum  ValueType { BOOLEAN , INTEGER , DOUBLE , STRING }
 Type of the value in the table. More...
virtual MODELAPI_EXPORT int rows ()=0
 Returns the number of rows in the table. More...
virtual MODELAPI_EXPORT int columns ()=0
 Returns the number of columns in the table. More...
virtual MODELAPI_EXPORT int tables ()=0
 Returns the number of tables. More...
virtual MODELAPI_EXPORT void setSize (const int theRows, const int theColumns, const int theTables=1)=0
 Sets the new size of the tables set. More...
virtual MODELAPI_EXPORT void setType (ValueType theType)=0
 Defines the tyoe of values in the table. If it differs from the current, erases the content. More...
virtual MODELAPI_EXPORT const ValueType & type () const =0
virtual MODELAPI_EXPORT void setValue (const Value theValue, const int theRow, const int theColumn, const int theTable=0)=0
 Defines the value by the index in the tables set (indexes are zero-based). More...
virtual MODELAPI_EXPORT Value value (const int theRow, const int theColumn, const int theTable=0)=0
 Returns the value by the index (indexes are zero-based). More...
virtual MODELAPI_EXPORT std::string valueStr (const int theRow, const int theColumn, const int theTable=0)=0
 Returns the value in the format of string (useful for the python connection) More...
virtual MODELAPI_EXPORT std::string attributeType ()
virtual MODELAPI_EXPORT ~ModelAPI_AttributeTables ()
 To virtually destroy the fields of successors. More...
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static MODELAPI_EXPORT std::string typeId ()
MODELAPI_EXPORT ModelAPI_AttributeTables ()
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
The type of values can be changed. But all the values in the tables must have the same one type. The currently allowed types now are: Boolean, Integer, Double, String. By default there is only one table, but it may be increased/decreased by adding/removing tables one by one. The number of rows and columns are equal in all tables. If table, row or column is added, the previous values are kept unchanged. New cells are filled by zero, false or empty strings.
◆ ValueType
◆ ~ModelAPI_AttributeTables()
ModelAPI_AttributeTables::~ModelAPI_AttributeTables ( )
◆ ModelAPI_AttributeTables()
ModelAPI_AttributeTables::ModelAPI_AttributeTables ( )
◆ rows()
virtual MODELAPI_EXPORT int ModelAPI_AttributeTables::rows ( )
pure virtual
Implemented in Model_AttributeTables.
◆ columns()
virtual MODELAPI_EXPORT int ModelAPI_AttributeTables::columns ( )
pure virtual
◆ tables()
virtual MODELAPI_EXPORT int ModelAPI_AttributeTables::tables ( )
pure virtual
◆ setSize()
virtual MODELAPI_EXPORT void ModelAPI_AttributeTables::setSize ( const int  theRows,
const int  theTables = 1
pure virtual
This method tries to keep old values if number of rows, columns or tables is increased.
◆ setType()
virtual MODELAPI_EXPORT void ModelAPI_AttributeTables::setType ( ValueType  theType)
pure virtual
◆ type()
virtual MODELAPI_EXPORT const ValueType & ModelAPI_AttributeTables::type ( ) const
pure virtual
◆ setValue()
virtual MODELAPI_EXPORT void ModelAPI_AttributeTables::setValue ( const Value  theValue,
const int  theRow,
const int  theTable = 0
pure virtual
◆ value()
virtual MODELAPI_EXPORT Value ModelAPI_AttributeTables::value ( const int  theRow,
pure virtual
◆ valueStr()
virtual MODELAPI_EXPORT std::string ModelAPI_AttributeTables::valueStr ( const int  theRow,
pure virtual
◆ typeId()
static MODELAPI_EXPORT std::string ModelAPI_AttributeTables::typeId ( )
inlinestatic
◆ attributeType()
std::string ModelAPI_AttributeTables::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
