GeomData_Point2DArray Class Reference
Attribute that contains an array of 2D points. More...
#include <GeomData_Point2DArray.h>
Inheritance diagram for GeomData_Point2DArray:
virtual bool assign (std::shared_ptr< GeomDataAPI_Point2DArray > theOther)
 Copy values from another array. More...
virtual int size ()
 Returns the size of the array (zero means that it is empty) More...
virtual void setSize (const int theSize)
 Sets the new size of the array. The previous data is erased. More...
virtual void setPnt (const int theIndex, const double theX, const double theY)
 Defines the value of the array by index [0; size-1]. More...
virtual void setPnt (const int theIndex, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint)
virtual std::shared_ptr< GeomAPI_Pnt2d > pnt (const int theIndex)
 Returns the value by the index. More...
virtual GEOMDATAAPI_EXPORT std::string attributeType ()
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 GeomData_Point2DArray (TDF_Label &theLabel)
 Initializes attributes. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
Friends
class Model_Data
◆ GeomData_Point2DArray()
GeomData_Point2DArray::GeomData_Point2DArray ( TDF_Label &  theLabel)
◆ assign()
bool GeomData_Point2DArray::assign ( std::shared_ptr< GeomDataAPI_Point2DArray >  theOther)
true if the copy was successful
Implements GeomDataAPI_Point2DArray.
◆ size()
int GeomData_Point2DArray::size ( )
◆ setSize()
void GeomData_Point2DArray::setSize ( const int  theSize)
◆ setPnt() [1/2]
void GeomData_Point2DArray::setPnt ( const int  theIndex,
const double  theX,
const double  theY
◆ setPnt() [2/2]
const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint
◆ pnt()
GeomPnt2dPtr GeomData_Point2DArray::pnt ( const int  theIndex)
◆ reinit()
void GeomData_Point2DArray::reinit ( )
Reimplemented from ModelAPI_Attribute.
◆ typeId()
static std::string GeomDataAPI_Point2DArray::typeId ( )
inlinestaticinherited
◆ attributeType()
std::string GeomDataAPI_Point2DArray::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
