GeomDataAPI_Point2DArray Class Referenceabstract
Attribute that contains array of 2D point coordinates. More...
#include <GeomDataAPI_Point2DArray.h>
Inheritance diagram for GeomDataAPI_Point2DArray:
virtual GEOMDATAAPI_EXPORT bool assign (std::shared_ptr< GeomDataAPI_Point2DArray > theOther)=0
 Copy values from another array. More...
virtual GEOMDATAAPI_EXPORT int size ()=0
 Returns the size of the array (zero means that it is empty) More...
virtual GEOMDATAAPI_EXPORT void setSize (const int theSize)=0
 Sets the new size of the array. The previous data is erased. More...
virtual GEOMDATAAPI_EXPORT void setPnt (const int theIndex, const double theX, const double theY)=0
 Defines the value of the array by index [0; size-1]. More...
virtual GEOMDATAAPI_EXPORT void setPnt (const int theIndex, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint)=0
virtual GEOMDATAAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > pnt (const int theIndex)=0
 Returns the value by the index. More...
virtual GEOMDATAAPI_EXPORT std::string attributeType ()
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
GEOMDATAAPI_EXPORT GeomDataAPI_Point2DArray ()
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
◆ GeomDataAPI_Point2DArray()
GeomDataAPI_Point2DArray::GeomDataAPI_Point2DArray ( )
◆ assign()
virtual GEOMDATAAPI_EXPORT bool GeomDataAPI_Point2DArray::assign ( std::shared_ptr< GeomDataAPI_Point2DArray >  theOther)
pure virtual
true if the copy was successful
Implemented in GeomData_Point2DArray.
◆ size()
virtual GEOMDATAAPI_EXPORT int GeomDataAPI_Point2DArray::size ( )
pure virtual
◆ setSize()
virtual GEOMDATAAPI_EXPORT void GeomDataAPI_Point2DArray::setSize ( const int  theSize)
pure virtual
◆ setPnt() [1/2]
virtual GEOMDATAAPI_EXPORT void GeomDataAPI_Point2DArray::setPnt ( const int  theIndex,
const double  theX,
const double  theY
pure virtual
◆ setPnt() [2/2]
const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint
pure virtual
◆ pnt()
virtual GEOMDATAAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > GeomDataAPI_Point2DArray::pnt ( const int  theIndex)
pure virtual
◆ typeId()
static std::string GeomDataAPI_Point2DArray::typeId ( )
inlinestatic
◆ attributeType()
std::string GeomDataAPI_Point2DArray::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
