GeomDataAPI_Point2DArray.h
1// Copyright (C) 2019-2026 CEA, EDF
20#ifndef GeomDataAPI_Point2DArray_H_
21#define GeomDataAPI_Point2DArray_H_
23#include <GeomDataAPI.h>
24#include <ModelAPI_Attribute.h>
26class GeomAPI_Pnt2d;
27
34{
35public:
38 GEOMDATAAPI_EXPORT virtual bool assign(std::shared_ptr<GeomDataAPI_Point2DArray> theOther) = 0;
39
41 GEOMDATAAPI_EXPORT virtual int size() = 0;
42
44 GEOMDATAAPI_EXPORT virtual void setSize(const int theSize) = 0;
45
47 GEOMDATAAPI_EXPORT virtual void setPnt(const int theIndex,
48 const double theX, const double theY) = 0;
49
51 GEOMDATAAPI_EXPORT virtual void setPnt(const int theIndex,
52 const std::shared_ptr<GeomAPI_Pnt2d>& thePoint) = 0;
53
55 GEOMDATAAPI_EXPORT virtual std::shared_ptr<GeomAPI_Pnt2d> pnt(const int theIndex) = 0;
56
58 static std::string typeId()
59 {
60 return std::string("Point2DArray");
61 }
62
64 GEOMDATAAPI_EXPORT virtual std::string attributeType();
65
66protected:
68 GEOMDATAAPI_EXPORT GeomDataAPI_Point2DArray();
69 GEOMDATAAPI_EXPORT virtual ~GeomDataAPI_Point2DArray();
70};
71
72typedef std::shared_ptr<GeomDataAPI_Point2DArray> AttributePoint2DArrayPtr;
73
74#endif
Attribute that contains array of 2D point coordinates.
Definition: GeomDataAPI_Point2DArray.h:34
virtual GEOMDATAAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > pnt(const int theIndex)=0
Returns the value by the index.
virtual GEOMDATAAPI_EXPORT int size()=0
Returns the size of the array (zero means that it is empty)
virtual GEOMDATAAPI_EXPORT void setSize(const int theSize)=0
Sets the new size of the array. The previous data is erased.
virtual GEOMDATAAPI_EXPORT std::string attributeType()
Returns the type of this class of attributes, not static method.
Definition: GeomDataAPI_Point2DArray.cpp:22
Returns the type of this class of attributes.
Definition: GeomDataAPI_Point2DArray.h:58
virtual GEOMDATAAPI_EXPORT bool assign(std::shared_ptr< GeomDataAPI_Point2DArray > theOther)=0
Copy values from another array.
virtual GEOMDATAAPI_EXPORT void setPnt(const int theIndex, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint)=0
Defines the value of the array by index [0; size-1].
virtual GEOMDATAAPI_EXPORT void setPnt(const int theIndex, const double theX, const double theY)=0
Definition: GeomDataAPI_Point2DArray.cpp:27
