Model_AttributeString.h
20#ifndef MODEL_ATTRIBUTESTRING_H_
21#define MODEL_ATTRIBUTESTRING_H_
23#include <Model.h>
24#include <ModelAPI_AttributeString.h>
26#include <TDF_Label.hxx>
27#include <TDataStd_Name.hxx>
28
29#include <string>
30
37{
38 Handle_TDataStd_Name myString;
39 TDF_Label myLab;
40 public:
42 MODEL_EXPORT virtual void setValue(const std::string& theValue);
44 MODEL_EXPORT virtual void setValue(const std::wstring& theValue);
45
47 MODEL_EXPORT virtual std::string value();
49 MODEL_EXPORT virtual char16_t* valueU();
51 MODEL_EXPORT virtual bool isUValue() const;
52
53 protected:
55 Model_AttributeString(TDF_Label& theLabel);
57 virtual void reinit();
58
59 friend class Model_Data;
60};
61
62#endif
Attribute that contains std (null terminated) string.
Definition: Model_AttributeString.h:37
virtual MODEL_EXPORT std::string value()
Returns the std::string value.
Definition: Model_AttributeString.cpp:62
Model_AttributeString(TDF_Label &theLabel)
Initializes attributes.
Definition: Model_AttributeString.cpp:82
Reinitializes the internal state of the attribute (may be needed on undo/redo, abort,...
Definition: Model_AttributeString.cpp:88
virtual MODEL_EXPORT char16_t * valueU()
Returns a pointer to Unicode string.
Definition: Model_AttributeString.cpp:69
virtual MODEL_EXPORT void setValue(const std::string &theValue)
Defines the std::string value.
Definition: Model_AttributeString.cpp:36
virtual MODEL_EXPORT bool isUValue() const
Returns true if Unicode string was stored.
Definition: Model_AttributeString.cpp:78
General object of the application that allows to get/set attributes from the document and compute res...
Definition: Model_Data.h:62
