ModelAPI_AttributeSelectionList Class Referenceabstract
Attribute that contains list of references to the sub-shapes with possibility to manage them. More...
#include <ModelAPI_AttributeSelectionList.h>
Inheritance diagram for ModelAPI_AttributeSelectionList:
virtual void append (const ObjectPtr &theContext, const std::shared_ptr< GeomAPI_Shape > &theSubShape, const bool theTemporarily=false)=0
 Adds the new reference to the end of the list. More...
virtual void append (const std::wstring &theNamingName, const std::string &theType="")=0
 Adds the new reference to the end of the list by the naming name of the selected shape The type of shape is taken from the current selection type if the given is empty. More...
virtual void append (const std::shared_ptr< GeomAPI_Pnt > &thePoint, const std::string &theType, const bool theIsIgnoreGroups=false)=0
 Adds the new reference to the end of the list by inner point on the selected shape. More...
virtual void append (const std::string &theType, const std::wstring &theContextName, const int theIndex)=0
 Adds the new reference to the end of the list by weak naming index. More...
virtual void copyTo (std::shared_ptr< ModelAPI_AttributeSelectionList > theTarget) const =0
 Copy the selection list to the destination attribute. More...
virtual void removeTemporaryValues ()=0
 Reset temporary stored values. More...
virtual void removeLast ()=0
 Removes the last element in the list. More...
virtual void remove (const std::set< int > &theIndices)=0
 Removes the elements from the list. More...
virtual int size ()=0
 Returns the number of selection attributes in the list. More...
virtual bool isInList (const ObjectPtr &theContext, const std::shared_ptr< GeomAPI_Shape > &theSubShape, const bool theTemporarily=false)=0
 Returns true if the object with the shape are in list. More...
virtual const std::string selectionType () const =0
 The type of all elements selection. More...
virtual void setSelectionType (const std::string &theType)=0
 Sets the type of all elements selection. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > value (const int theIndex)=0
 Returns the attribute selection by the index (zero based) More...
virtual void clear ()=0
 Removes all attributes of the list. More...
virtual void cashValues (const bool theEnabled)=0
 Starts or stops cashing of the values in the attribute (the cash may become invalid on modification of the attribute or sub-elements, so the cash must be enabled only during non-modification operations with this attribute) More...
virtual void setGeometricalSelection (const bool theIsGeometricalSelection)=0
virtual bool isGeometricalSelection () const =0
 Returns true if is geometrical selection. More...
virtual std::string attributeType ()
virtual ~ModelAPI_AttributeSelectionList ()
 To virtually destroy the fields of successors. More...
virtual FiltersFeaturePtr filters () const =0
 Returns a selection filters feature if it is defined for this selection list. More...
virtual void setFilters (FiltersFeaturePtr theFeature)=0
 Sets a selection filters feature if it is defined for this selection list. More...
virtual void applyFilters ()=0
 Applies the filters to this selection list. More...
virtual void removeFilters ()=0
 Removes the filters of this selection list. More...
virtual const bool isWholeResultAllowed () const
 Returns true if the whole result selection corresponds to selection of all sub-shapes. More...
virtual void setWholeResultAllowed (const bool theFlag)
 Sets whether the whole result selection corresponds to selection of all sub-shapes. More...
virtual const bool isMakeCopy () const
 Returns true if a copy features must be used in update in history. More...
virtual void setMakeCopy (const bool theFlag)
 Sets true if a copy features must be used in update in history. More...
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 Default constructor. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
◆ ~ModelAPI_AttributeSelectionList()
ModelAPI_AttributeSelectionList::~ModelAPI_AttributeSelectionList ( )
◆ ModelAPI_AttributeSelectionList()
ModelAPI_AttributeSelectionList::ModelAPI_AttributeSelectionList ( )
inlineprotected
◆ append() [1/4]
virtual void ModelAPI_AttributeSelectionList::append ( const ObjectPtr &  theContext,
const std::shared_ptr< GeomAPI_Shape > &  theSubShape,
const bool  theTemporarily = false
pure virtual
theContextobject where the sub-shape was selected
theSubShapeselected sub-shape (if null, the whole context is selected)
theTemporarilyif it is true, do not store and name the added in the data framework (used to remove immediately, without the following updates)
Implemented in Model_AttributeSelectionList.
◆ append() [2/4]
virtual void ModelAPI_AttributeSelectionList::append ( const std::wstring &  theNamingName,
const std::string &  theType = ""
pure virtual
◆ append() [3/4]
virtual void ModelAPI_AttributeSelectionList::append ( const std::shared_ptr< GeomAPI_Pnt > &  thePoint,
const std::string &  theType,
const bool  theIsIgnoreGroups = false
pure virtual
◆ append() [4/4]
virtual void ModelAPI_AttributeSelectionList::append ( const std::string &  theType,
const std::wstring &  theContextName,
const int  theIndex
pure virtual
◆ copyTo()
virtual void ModelAPI_AttributeSelectionList::copyTo ( std::shared_ptr< ModelAPI_AttributeSelectionList >  theTarget) const
pure virtual
◆ removeTemporaryValues()
virtual void ModelAPI_AttributeSelectionList::removeTemporaryValues ( )
pure virtual
◆ removeLast()
virtual void ModelAPI_AttributeSelectionList::removeLast ( )
pure virtual
◆ remove()
virtual void ModelAPI_AttributeSelectionList::remove ( const std::set< int > &  theIndices)
pure virtual
theIndicesa list of indices of elements to be removed
◆ size()
virtual int ModelAPI_AttributeSelectionList::size ( )
pure virtual
◆ isInList()
virtual bool ModelAPI_AttributeSelectionList::isInList ( const ObjectPtr &  theContext,
pure virtual
theTemporarilyif it is true, it checks also the temporary added item
true if the pair is found in the attribute
◆ selectionType()
virtual const std::string ModelAPI_AttributeSelectionList::selectionType ( ) const
pure virtual
the index of the enumeration of the type of shape
◆ setSelectionType()
virtual void ModelAPI_AttributeSelectionList::setSelectionType ( const std::string &  theType)
pure virtual
theTypethe index of the enumeration of the type of shape
◆ value()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ModelAPI_AttributeSelectionList::value ( const int  theIndex)
pure virtual
◆ clear()
virtual void ModelAPI_AttributeSelectionList::clear ( )
pure virtual
◆ cashValues()
virtual void ModelAPI_AttributeSelectionList::cashValues ( const bool  theEnabled)
pure virtual
◆ isGeometricalSelection()
virtual bool ModelAPI_AttributeSelectionList::isGeometricalSelection ( ) const
pure virtual
◆ typeId()
static std::string ModelAPI_AttributeSelectionList::typeId ( )
inlinestatic
◆ attributeType()
std::string ModelAPI_AttributeSelectionList::attributeType ( )
◆ filters()
virtual FiltersFeaturePtr ModelAPI_AttributeSelectionList::filters ( ) const
pure virtual
◆ setFilters()
virtual void ModelAPI_AttributeSelectionList::setFilters ( FiltersFeaturePtr  theFeature)
pure virtual
◆ applyFilters()
virtual void ModelAPI_AttributeSelectionList::applyFilters ( )
pure virtual
◆ removeFilters()
virtual void ModelAPI_AttributeSelectionList::removeFilters ( )
pure virtual
◆ isWholeResultAllowed()
virtual const bool ModelAPI_AttributeSelectionList::isWholeResultAllowed ( ) const
◆ setWholeResultAllowed()
virtual void ModelAPI_AttributeSelectionList::setWholeResultAllowed ( const bool  theFlag)
◆ isMakeCopy()
virtual const bool ModelAPI_AttributeSelectionList::isMakeCopy ( ) const
◆ setMakeCopy()
virtual void ModelAPI_AttributeSelectionList::setMakeCopy ( const bool  theFlag)
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
