GeomData_Point.h
20#ifndef GeomData_Point_H_
21#define GeomData_Point_H_
23#include "GeomData.h"
24#include "GeomDataAPI_Point.h"
26#include <TDF_Label.hxx>
27
35{
36 enum { NUM_COMPONENTS = 3 };
38 std::shared_ptr<ModelAPI_ExpressionDouble> myExpression[NUM_COMPONENTS];
39 public:
41 GEOMDATA_EXPORT virtual void setValue(const double theX, const double theY, const double theZ);
43 GEOMDATA_EXPORT virtual void setValue(const std::shared_ptr<GeomAPI_Pnt>& thePoint);
44
46 GEOMDATA_EXPORT virtual double x() const;
48 GEOMDATA_EXPORT virtual double y() const;
50 GEOMDATA_EXPORT virtual double z() const;
52 GEOMDATA_EXPORT void setX(const double theX);
54 GEOMDATA_EXPORT void setY(const double theY);
56 GEOMDATA_EXPORT void setZ(const double theZ);
57
59 GEOMDATA_EXPORT virtual std::shared_ptr<GeomAPI_Pnt> pnt();
60
62 GEOMDATA_EXPORT virtual
63 void setCalculatedValue(const double theX, const double theY, const double theZ);
64
66 GEOMDATA_EXPORT virtual void setText(const std::wstring& theX,
67 const std::wstring& theY,
68 const std::wstring& theZ);
70 GEOMDATA_EXPORT virtual void setTextX(const std::wstring& theX);
72 GEOMDATA_EXPORT virtual void setTextY(const std::wstring& theY);
74 GEOMDATA_EXPORT virtual void setTextZ(const std::wstring& theZ);
75
77 GEOMDATA_EXPORT virtual std::wstring textX();
79 GEOMDATA_EXPORT virtual std::wstring textY();
81 GEOMDATA_EXPORT virtual std::wstring textZ();
82
84 GEOMDATA_EXPORT virtual void setExpressionInvalid(int, const bool theFlag);
85
87 GEOMDATA_EXPORT virtual bool expressionInvalid(int);
88
90 GEOMDATA_EXPORT virtual void setExpressionError(int theComponent, const std::string& theError);
91
93 GEOMDATA_EXPORT virtual std::string expressionError(int theComponent);
94
96 GEOMDATA_EXPORT virtual void setUsedParameters(int theComponent,
97 const std::set<std::wstring>& theUsedParameters);
98
100 GEOMDATA_EXPORT virtual std::set<std::wstring> usedParameters(int theComponent) const;
101
102 protected:
104 GEOMDATA_EXPORT GeomData_Point();
106 virtual void reinit();
107
108 friend class Model_Data;
109};
110
111#endif
Attribute that contains 3D point coordinates.
Definition: GeomDataAPI_Point.h:36
Attribute that contains 3D point.
Definition: GeomData_Point.h:35
Returns the X text value.
Definition: GeomData_Point.cpp:179
Returns the Z text value.
Definition: GeomData_Point.cpp:187
Returns true if text is invalid.
Definition: GeomData_Point.cpp:199
Defines the X coordinate value.
Definition: GeomData_Point.cpp:82
virtual void setExpressionError(int theComponent, const std::string &theError)
Allows to set expression (text) error (by the parameters listener)
Definition: GeomData_Point.cpp:205
GeomData_Point()
Initializes attributes.
Definition: GeomData_Point.cpp:31
Returns the Y double value.
Definition: GeomData_Point.cpp:72
Returns the Y text value.
Definition: GeomData_Point.cpp:183
Reinitializes the internal state of the attribute (may be needed on undo/redo, abort,...
Definition: GeomData_Point.cpp:36
Allows to set expression (text) as invalid (by the parameters listener)
Definition: GeomData_Point.cpp:192
virtual void setTextY(const std::wstring &theY)
Defines the Y text value.
Definition: GeomData_Point.cpp:151
Returns an expression error.
Definition: GeomData_Point.cpp:212
virtual void setTextZ(const std::wstring &theZ)
Defines the Z text value.
Definition: GeomData_Point.cpp:165
Defines the Z coordinate value.
Definition: GeomData_Point.cpp:104
virtual std::set< std::wstring > usedParameters(int theComponent) const
Returns the used parameters.
Definition: GeomData_Point.cpp:225
virtual void setCalculatedValue(const double theX, const double theY, const double theZ)
Defines the calculated double value.
Definition: GeomData_Point.cpp:45
Returns the Z double value.
Definition: GeomData_Point.cpp:77
virtual std::shared_ptr< GeomAPI_Pnt > pnt()
Returns the 3D point.
Definition: GeomData_Point.cpp:117
virtual void setTextX(const std::wstring &theX)
Defines the X text value.
Definition: GeomData_Point.cpp:137
Defines the Y coordinate value.
Definition: GeomData_Point.cpp:93
virtual void setText(const std::wstring &theX, const std::wstring &theY, const std::wstring &theZ)
Defines the text values.
Definition: GeomData_Point.cpp:123
Defines the double value.
Definition: GeomData_Point.cpp:55
virtual void setUsedParameters(int theComponent, const std::set< std::wstring > &theUsedParameters)
Defines the used parameters.
Definition: GeomData_Point.cpp:218
Returns the X double value.
Definition: GeomData_Point.cpp:67
Expression for calculated double values.
Definition: ModelAPI_Expression.h:101
General object of the application that allows to get/set attributes from the document and compute res...
Definition: Model_Data.h:62
