Feature for parameter. More...
#include <ParametersPlugin_Parameter.h>
| virtual bool | isPreviewNeeded () const |
| Pre-execution is not needed for parameter. More... | |
| virtual void | execute () |
| Creates a parameter in document. More... | |
| Reimplemented from ModelAPI_Feature::isInHistory(). Returns false. More... | |
| Reimplemented from ModelAPI_Feature::isInHistory(). More... | |
| ParametersPlugin_Parameter () | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | VARIABLE_ID () |
| attribute of parameter name More... | |
| static const std::string & | EXPRESSION_ID () |
| attribute of parameter expression More... | |
| static const std::string & | EXPRESSION_ERROR_ID () |
| attribute of parameter expression error More... | |
| static const std::string & | ARGUMENTS_ID () |
| list of references to the arguments of this expression More... | |
| static const std::string & | COMMENT_ID () |
| return comment attribute Id More... | |
| double | evaluate (const std::wstring &theExpression, std::string &theError) |
| Evaluates theExpression and returns its value. More... | |
| void | updateName () |
| Updates name of the parameter. More... | |
| bool | updateExpression () |
| Updates expression of the parameter. More... | |
| ParametersPlugin_Parameter::ParametersPlugin_Parameter | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
protected |
protected |
protected |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
