Model_ResultGroup Class Reference
The groups result. More...
#include <Model_ResultGroup.h>
Inheritance diagram for Model_ResultGroup:
virtual void colorConfigInfo (std::string &theSection, std::string &theName, std::string &theDefault)
virtual std::shared_ptr< GeomAPI_Shape > shape ()
 Returns the compound of selected entities. More...
virtual void store (const GeomShapePtr &theShape)
 Stores the result of operation made on groups. More...
virtual ~Model_ResultGroup ()
 Removes the stored builders. More...
virtual bool isConcealed ()
 Returns true if the result is concealed from the data tree (referenced by other objects) More...
virtual void setIsConcealed (const bool theValue, const bool theForced=false)
 Sets the result as concealed in the data tree (referenced by other objects) More...
virtual bool setDisabled (std::shared_ptr< ModelAPI_Result > theThis, const bool theFlag)
 Enables/disables the result. More...
virtual bool isDisabled ()
 Returns the result is disabled or not. More...
 Request for initialization of data model of the result: adding all attributes. More...
 Returns all the vertices of this result. More...
 Returns all the edges of this result. More...
 Returns all the wires of this result. More...
 Returns all the faces of this result. More...
 Returns all the shells of this result. More...
 Returns all the solids of this result. More...
 On change of attribute of the result update presentation of this result: for the current moment there are only presentation attributes assigned to results. More...
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
static std::string group ()
static const std::string & DEFAULT_COLOR ()
 default color for a result body More...
static const std::string & COLOR_ID ()
 Reference to the color of the result. More...
static const std::string & DEFLECTION_ID ()
 Reference to the deflection of the result. More...
static const std::string & TRANSPARENCY_ID ()
 Reference to the transparency of the result. More...
static const std::string & ISO_LINES_ID ()
static const std::string & SHOW_ISO_LINES_ID ()
static const std::string & SHOW_EDGES_DIRECTION_ID ()
static const std::string & BRING_TO_FRONT_ID ()
 Reference to the BringToFront flag of the result. More...
 Model_ResultGroup (std::shared_ptr< ModelAPI_Data > theOwnerData)
 Makes a body on the given feature data. More...
virtual void init ()
virtual void erase ()
 removes all fields from this feature More...
bool myIsDisabled
 the result is disabled: removed for the user, but keeps the general info More...
Friends
class Model_Objects
The groups result.
Provides a compound of selected elements, without storage, one the fly.
◆ ~Model_ResultGroup()
virtual Model_ResultGroup::~Model_ResultGroup ( )
◆ Model_ResultGroup()
Model_ResultGroup::Model_ResultGroup ( std::shared_ptr< ModelAPI_Data >  theOwnerData)
◆ colorConfigInfo()
void Model_ResultGroup::colorConfigInfo ( std::string &  theSection,
std::string &  theName,
std::string &  theDefault
Returns the parameters of color definition in the resources config manager.
◆ shape()
std::shared_ptr< GeomAPI_Shape > Model_ResultGroup::shape ( )
Reimplemented from ModelAPI_Result.
◆ store()
void Model_ResultGroup::store ( const GeomShapePtr &  theShape)
Cleans the storage if empty shape is given. param[in] theShape shape to store.
Reimplemented from ModelAPI_ResultGroup.
◆ groupName()
std::string ModelAPI_ResultGroup::groupName ( )
Implements ModelAPI_Object.
◆ group()
static std::string ModelAPI_ResultGroup::group ( )
inlinestaticinherited
◆ DEFAULT_COLOR()
static const std::string & ModelAPI_ResultGroup::DEFAULT_COLOR ( )
◆ COLOR_ID()
static const std::string & ModelAPI_Result::COLOR_ID ( )
The integer array is used. It contains three values for red, green and blue values. The values are in [0, 255] range
◆ DEFLECTION_ID()
static const std::string & ModelAPI_Result::DEFLECTION_ID ( )
The double value is used. The value is in [0, 1] range
◆ TRANSPARENCY_ID()
static const std::string & ModelAPI_Result::TRANSPARENCY_ID ( )
◆ ISO_LINES_ID()
static const std::string & ModelAPI_Result::ISO_LINES_ID ( )
◆ SHOW_ISO_LINES_ID()
static const std::string & ModelAPI_Result::SHOW_ISO_LINES_ID ( )
◆ SHOW_EDGES_DIRECTION_ID()
static const std::string & ModelAPI_Result::SHOW_EDGES_DIRECTION_ID ( )
◆ BRING_TO_FRONT_ID()
static const std::string & ModelAPI_Result::BRING_TO_FRONT_ID ( )
The bool value is used.
◆ isConcealed()
bool ModelAPI_Result::isConcealed ( )
◆ setIsConcealed()
void ModelAPI_Result::setIsConcealed ( const bool  theValue,
const bool  theForced = false
Reimplemented in Model_ResultBody, and Model_ResultConstruction.
◆ setDisabled()
bool ModelAPI_Result::setDisabled ( std::shared_ptr< ModelAPI_Result >  theThis,
const bool  theFlag
The disabled result does not participate in any calculation and visualization: like it was removed. But it keeps the general parameters: colors, visibility, etc.
theThispointer to this object, needed to generate all events if it is necessary
theFlagmakes disabled if it is true
Reimplemented in Model_ResultBody, and Model_ResultPart.
◆ isDisabled()
bool ModelAPI_Result::isDisabled ( )
◆ initAttributes()
void ModelAPI_Result::initAttributes ( )
Reimplemented in Model_ResultBody, Model_ResultParameter, Model_ResultPart, and ModelAPI_ResultParameter.
◆ vertices()
ListOfShape ModelAPI_Result::vertices ( const bool  theOnlyUnique = false)
◆ edges()
ListOfShape ModelAPI_Result::edges ( const bool  theOnlyUnique = false)
◆ wires()
ListOfShape ModelAPI_Result::wires ( const bool  theOnlyUnique = false)
◆ faces()
ListOfShape ModelAPI_Result::faces ( const bool  theOnlyUnique = false)
◆ shells()
ListOfShape ModelAPI_Result::shells ( const bool  theOnlyUnique = false)
◆ solids()
ListOfShape ModelAPI_Result::solids ( const bool  theOnlyUnique = false)
◆ attributeChanged()
void ModelAPI_Result::attributeChanged ( const std::string &  theID)
◆ init()
void ModelAPI_Result::init ( )
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ document()
std::shared_ptr< ModelAPI_Document > ModelAPI_Object::document ( ) const
Reimplemented in Model_ResultField::Model_FieldStep, and ModelAPI_Feature.
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
inlinevirtualinherited
◆ setData()
◆ setDoc()
◆ erase()
void ModelAPI_Object::erase ( )
◆ emptyFunction()
◆ myIsDisabled
bool ModelAPI_Result::myIsDisabled
