AN internal, hidden feature for results removal. More...
#include <FeaturesPlugin_RemoveResults.h>
| FeaturesPlugin_RemoveResults () | |
| virtual void | execute () |
| Does nothing, has no results. More... | |
| Hidden from the user. More... | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | RESULTS_ID () |
| Attribute name of removed shapes selector. More... | |
| FeaturesPlugin_RemoveResults::FeaturesPlugin_RemoveResults | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinevirtual |
inlinevirtual |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
