Feature for copy of a sketch and all its sub-features to the same plane. More...
#include <SketchPlugin_SketchCopy.h>
| SketchPlugin_SketchCopy () | |
| A constructor. More... | |
| virtual void | execute () |
| Creates a new sketch. More... | |
| virtual bool | isMacro () const |
| Means that feature is removed on apply. More... | |
| virtual bool | isPreviewNeeded () const |
| No preview is generated until it is applied. More... | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | BASE_ID () |
| Attribute name of the base sketch selected. More... | |
| SketchPlugin_SketchCopy::SketchPlugin_SketchCopy | ( | ) |
A constructor.
inlinestatic |
Feature kind.
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinevirtual |
inlinevirtual |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
