Feature for import the structure of Part into the current document. More...
#include <ExchangePlugin_ImportPart.h>
| ExchangePlugin_ImportPart () | |
| virtual EXCHANGEPLUGIN_EXPORT const std::string & | getKind () |
| Returns the unique kind of a feature. More... | |
| virtual EXCHANGEPLUGIN_EXPORT void | initAttributes () |
| virtual EXCHANGEPLUGIN_EXPORT void | attributeChanged (const std::string &theID) |
| virtual EXCHANGEPLUGIN_EXPORT void | execute () |
| virtual EXCHANGEPLUGIN_EXPORT bool | isMacro () const |
| virtual EXCHANGEPLUGIN_EXPORT bool | isPreviewNeeded () const |
| Reimplemented from ModelAPI_Feature::isPreviewNeeded(). Returns false. More... | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | FILE_PATH_ID () |
| attribute name of file path More... | |
| static const std::string & | TARGET_PART_ID () |
| attribute name of target part More... | |
| static const std::string & | TARGET_PARTS_LIST_ID () |
| attribute name of list of target parts More... | |
| ExchangePlugin_ImportPart::ExchangePlugin_ImportPart | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinevirtual |
inlinevirtual |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
