Feature for creation of the new B-spline curve in sketch as an interpolation or an approximation of a list of points. More...
#include <SketchPlugin_CurveFitting.h>
| virtual SKETCHPLUGIN_EXPORT const std::string & | getKind () |
| virtual AISObjectPtr | getAISObject (AISObjectPtr thePrevious) |
| Returns the AIS preview. More... | |
| virtual SKETCHPLUGIN_EXPORT void | execute () |
| virtual SKETCHPLUGIN_EXPORT bool | isMacro () const |
| Reimplemented from ModelAPI_Feature::isMacro(). More... | |
| virtual SKETCHPLUGIN_EXPORT bool | isPreviewNeeded () const |
| virtual SKETCHPLUGIN_EXPORT bool | customAction (const std::string &theActionId) |
| Performs some functionality by action id. More... | |
| SketchPlugin_CurveFitting () | |
| virtual bool | isExternal () const |
| Returns true of the feature is created basing on the external shape of not-this-sketch object. More... | |
| virtual bool | isCopy () const |
| Returns true of the feature is a copy of other feature. More... | |
| Returns true if this feature must be displayed in the history (top level of Part tree) More... | |
| virtual bool | canBeDisplayed () const |
| Returns true if the feature and the feature results can be displayed. More... | |
| virtual bool | isFixed () |
| Returns true is sketch element is under the rigid constraint. More... | |
| SketchPlugin_Sketch * | sketch () |
| Returns the sketch of this feature. More... | |
| std::wstring | name () |
| Interpolation macro feature kind. More... | |
| static const std::string & | POINTS_ID () |
| list of selected points More... | |
| static const std::string & | PERIODIC_ID () |
| attribute for the periodic flag More... | |
| static const std::string & | CLOSED_ID () |
| attribute for the closed flag More... | |
| static const std::string & | NEED_CONTROL_POLYGON_ID () |
| attribute for the flag of creation a control polygon More... | |
| static const std::string & | TYPE_ID () |
| attribute for the type of the operation More... | |
| static const std::string & | TYPE_INTERPOLATION_ID () |
| value for the type of operation More... | |
| static const std::string & | TYPE_APPROXIMATION_ID () |
| static const std::string & | PRECISION_ID () |
| attribute for the precision of the approximation More... | |
| static const std::string & | REORDER_POINTS_ACTION_ID () |
| static const std::string & | AUXILIARY_ID () |
| Reference to the construction type of the feature. More... | |
| static const std::string & | EXTERNAL_ID () |
| Reference to the external edge or vertex as a AttributeSelection. More... | |
| static const std::string & | COPY_ID () |
| Reference to the copy type of the feature. More... | |
| static const std::string & | PARENT_ID () |
| Reference to the parent feature if exist. More... | |
| static const int | SKETCH_LINE_WIDTH_AUXILIARY () |
| Width of the auxiliary line. More... | |
| static const int | SKETCH_LINE_WIDTH () |
| Width of the line. More... | |
| static const int | SKETCH_LINE_STYLE_AUXILIARY () |
| Style of the auxiliary line. More... | |
| static const int | SKETCH_LINE_STYLE () |
| Style of the line. More... | |
| virtual void | initDerivedClassAttributes () |
| Initializes attributes of derived class. More... | |
| virtual void | initDerivedClassAttributes2 () |
| Initializes attributes of derived class which were added recently. More... | |
| void | setSketch (SketchPlugin_Sketch *theSketch) |
| Sets the higher-level feature for the sub-feature (sketch for line) More... | |
| void | keepCurrentFeature () |
| Store current feature of the document if it is not the sub-feature of the current sketch. More... | |
| void | restoreCurrentFeature () |
| Restore current feature of the document after adding new feature to the sketch. More... | |
| SketchPlugin_CurveFitting::SketchPlugin_CurveFitting | ( | ) |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
inlinevirtual |
inlinevirtual |
| [in] | theAttributeId | action key id. |
protectedvirtual |
Reimplemented from SketchPlugin_SketchEntity.
inlinestaticinherited |
Width of the line.
Style of the line.
Implements ModelAPI_Object.
Reimplemented in SketchPlugin_Fillet, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, and SketchPlugin_MacroEllipticArc.
inlinevirtualinherited |
Reimplemented from SketchPlugin_Feature.
Reimplemented in SketchPlugin_Projection.
Reimplemented in SketchPlugin_Arc, SketchPlugin_BSplineBase, SketchPlugin_Circle, SketchPlugin_Ellipse, SketchPlugin_EllipticArc, SketchPlugin_IntersectionPoint, SketchPlugin_Line, SketchPlugin_Point, and SketchPlugin_Projection.
inlineprotectedinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
