SketchPlugin_MacroBSpline Class Reference
Feature for creation of the new B-spline in Sketch. More...
#include <SketchPlugin_MacroBSpline.h>
Inheritance diagram for SketchPlugin_MacroBSpline:
virtual void execute ()
virtual bool isMacro () const
 Reimplemented from ModelAPI_Feature::isMacro(). More...
virtual bool isPreviewNeeded () const
 SketchPlugin_MacroBSpline ()
virtual bool isCopy () const
 Returns true of the feature is a copy of other feature. More...
virtual bool isInHistory ()
virtual bool isFixed ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 B-spline macro feature kind. More...
static const std::string & POLES_ID ()
 list of B-spline poles More...
static const std::string & REF_POLES_ID ()
 list of references of B-spline poles More...
static const std::string & WEIGHTS_ID ()
 list of B-spline weights More...
static const std::string & CONTROL_POLYGON_ID ()
 flag attribute whether control polygon is need to be created More...
static const std::string & AUXILIARY_ID ()
 Reference to the construction type of the feature. More...
static const std::string & EXTERNAL_ID ()
 Reference to the external edge or vertex as a AttributeSelection. More...
static const std::string & COPY_ID ()
 Reference to the copy type of the feature. More...
static const std::string & PARENT_ID ()
 Reference to the parent feature if exist. More...
static const int SKETCH_LINE_WIDTH_AUXILIARY ()
 Width of the auxiliary line. More...
static const int SKETCH_LINE_WIDTH ()
 Width of the line. More...
static const int SKETCH_LINE_STYLE_AUXILIARY ()
 Style of the auxiliary line. More...
static const int SKETCH_LINE_STYLE ()
 Style of the line. More...
static std::string group ()
 SketchPlugin_MacroBSpline (bool isPeriodic)
virtual void initDerivedClassAttributes ()
 Initializes attributes of derived class. More...
virtual void initDerivedClassAttributes2 ()
 Initializes attributes of derived class which were added recently. More...
void keepCurrentFeature ()
void restoreCurrentFeature ()
Friends
class SketchPlugin_BSplineBase
class SketchPlugin_CurveFitting
◆ SketchPlugin_MacroBSpline()
SketchPlugin_MacroBSpline::SketchPlugin_MacroBSpline ( )
◆ ID()
static const std::string & SketchPlugin_MacroBSpline::ID ( )
inlinestatic
◆ POLES_ID()
static const std::string & SketchPlugin_MacroBSpline::POLES_ID ( )
inlinestatic
◆ REF_POLES_ID()
static const std::string & SketchPlugin_MacroBSpline::REF_POLES_ID ( )
inlinestatic
◆ WEIGHTS_ID()
static const std::string & SketchPlugin_MacroBSpline::WEIGHTS_ID ( )
inlinestatic
◆ CONTROL_POLYGON_ID()
static const std::string & SketchPlugin_MacroBSpline::CONTROL_POLYGON_ID ( )
inlinestatic
◆ getKind()
virtual const std::string & SketchPlugin_MacroBSpline::getKind ( )
Implements ModelAPI_Feature.
Reimplemented in SketchPlugin_MacroBSplinePeriodic.
◆ initAttributes()
void SketchPlugin_MacroBSpline::initAttributes ( )
Reimplemented from SketchPlugin_SketchEntity.
◆ getAISObject()
AISObjectPtr SketchPlugin_MacroBSpline::getAISObject ( AISObjectPtr  thePrevious)
◆ execute()
void SketchPlugin_MacroBSpline::execute ( )
◆ isMacro()
virtual bool SketchPlugin_MacroBSpline::isMacro ( ) const
true
◆ isPreviewNeeded()
virtual bool SketchPlugin_MacroBSpline::isPreviewNeeded ( ) const
Returns true if preview update during the edition needed.
true by default
◆ AUXILIARY_ID()
static const std::string & SketchPlugin_SketchEntity::AUXILIARY_ID ( )
inlinestaticinherited
◆ EXTERNAL_ID()
static const std::string & SketchPlugin_SketchEntity::EXTERNAL_ID ( )
◆ COPY_ID()
static const std::string & SketchPlugin_SketchEntity::COPY_ID ( )
◆ PARENT_ID()
static const std::string & SketchPlugin_SketchEntity::PARENT_ID ( )
◆ SKETCH_LINE_WIDTH_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH_AUXILIARY ( )
◆ SKETCH_LINE_WIDTH()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH ( )
Width of the line.
◆ SKETCH_LINE_STYLE_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE_AUXILIARY ( )
◆ SKETCH_LINE_STYLE()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE ( )
Style of the line.
◆ isExternal()
virtual bool SketchPlugin_SketchEntity::isExternal ( ) const
inlinevirtualinherited
Reimplemented from SketchPlugin_Feature.
◆ isCopy()
virtual bool SketchPlugin_SketchEntity::isCopy ( ) const
◆ initDerivedClassAttributes()
virtual void SketchPlugin_SketchEntity::initDerivedClassAttributes ( )
◆ initDerivedClassAttributes2()
virtual void SketchPlugin_SketchEntity::initDerivedClassAttributes2 ( )
Reimplemented in SketchPlugin_Projection.
◆ isInHistory()
◆ canBeDisplayed()
true
◆ isFixed()
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
Implements ModelAPI_Object.
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
