Feature for creation of the new elliptic arc in Sketch. More...
#include <SketchPlugin_EllipticArc.h>
| virtual SKETCHPLUGIN_EXPORT const std::string & | getKind () |
| virtual SKETCHPLUGIN_EXPORT bool | isFixed () |
| Returns true is sketch element is under the rigid constraint. More... | |
| virtual SKETCHPLUGIN_EXPORT void | attributeChanged (const std::string &theID) |
| virtual SKETCHPLUGIN_EXPORT void | execute () |
| SketchPlugin_EllipticArc () | |
| virtual bool | isExternal () const |
| Returns true of the feature is created basing on the external shape of not-this-sketch object. More... | |
| virtual bool | isCopy () const |
| Returns true of the feature is a copy of other feature. More... | |
| Returns true if this feature must be displayed in the history (top level of Part tree) More... | |
| virtual bool | canBeDisplayed () const |
| Returns true if the feature and the feature results can be displayed. More... | |
| SketchPlugin_Sketch * | sketch () |
| Returns the sketch of this feature. More... | |
| std::wstring | name () |
| Ellipse feature kind. More... | |
| static const std::string & | CENTER_ID () |
| 2D point - center of the ellipse More... | |
| static const std::string & | START_POINT_ID () |
| 2D point - start point of elliptic arc More... | |
| static const std::string & | END_POINT_ID () |
| 2D point - end point of elliptic arc More... | |
| static const std::string & | FIRST_FOCUS_ID () |
| 2D point - focus of the ellipse More... | |
| static const std::string & | SECOND_FOCUS_ID () |
| 2D point - second focus of the ellipse More... | |
| static const std::string & | MAJOR_AXIS_START_ID () |
| 2D point - start point of major axis More... | |
| static const std::string & | MAJOR_AXIS_END_ID () |
| 2D point - end point of major axis More... | |
| static const std::string & | MINOR_AXIS_START_ID () |
| 2D point - start point of minor axis More... | |
| static const std::string & | MINOR_AXIS_END_ID () |
| 2D point - end point of minor axis More... | |
| static const std::string & | MAJOR_RADIUS_ID () |
| Major radius of the ellipse. More... | |
| static const std::string & | MINOR_RADIUS_ID () |
| Minor radius of the ellipse. More... | |
| static const std::string & | REVERSED_ID () |
| Flag the arc is reversed. More... | |
| static const std::string & | AUXILIARY_ID () |
| Reference to the construction type of the feature. More... | |
| static const std::string & | EXTERNAL_ID () |
| Reference to the external edge or vertex as a AttributeSelection. More... | |
| static const std::string & | COPY_ID () |
| Reference to the copy type of the feature. More... | |
| static const std::string & | PARENT_ID () |
| Reference to the parent feature if exist. More... | |
| static const int | SKETCH_LINE_WIDTH_AUXILIARY () |
| Width of the auxiliary line. More... | |
| static const int | SKETCH_LINE_WIDTH () |
| Width of the line. More... | |
| static const int | SKETCH_LINE_STYLE_AUXILIARY () |
| Style of the auxiliary line. More... | |
| static const int | SKETCH_LINE_STYLE () |
| Style of the line. More... | |
| virtual void | initDerivedClassAttributes () |
| Initializes attributes of derived class. More... | |
| virtual void | initDerivedClassAttributes2 () |
| Initializes attributes of derived class which were added recently. More... | |
| void | setSketch (SketchPlugin_Sketch *theSketch) |
| Sets the higher-level feature for the sub-feature (sketch for line) More... | |
| void | keepCurrentFeature () |
| Store current feature of the document if it is not the sub-feature of the current sketch. More... | |
| void | restoreCurrentFeature () |
| Restore current feature of the document after adding new feature to the sketch. More... | |
| SketchPlugin_EllipticArc::SketchPlugin_EllipticArc | ( | ) |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Reimplemented from SketchPlugin_Feature.
protectedvirtual |
Reimplemented from SketchPlugin_SketchEntity.
inlinestaticinherited |
Width of the line.
Style of the line.
Implements ModelAPI_Object.
Reimplemented in SketchPlugin_Fillet, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, and SketchPlugin_MacroEllipticArc.
inlinevirtualinherited |
Reimplemented in SketchPlugin_Projection.
inlineprotectedinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
