ExchangePlugin_Dump Class Reference
Store full model as a Python script. More...
#include <ExchangePlugin_Dump.h>
Inheritance diagram for ExchangePlugin_Dump:
EXCHANGEPLUGIN_EXPORT ExchangePlugin_Dump ()
 Default constructor. More...
virtual EXCHANGEPLUGIN_EXPORT ~ExchangePlugin_Dump ()
 Default destructor. More...
virtual EXCHANGEPLUGIN_EXPORT const std::string & getKind ()
 Returns the unique kind of a feature. More...
virtual EXCHANGEPLUGIN_EXPORT void initAttributes ()
virtual EXCHANGEPLUGIN_EXPORT void execute ()
 Computes or recomputes the results. More...
virtual EXCHANGEPLUGIN_EXPORT bool isMacro () const
 Reimplemented from ModelAPI_Feature::isMacro(). Returns true. More...
virtual EXCHANGEPLUGIN_EXPORT bool isPreviewNeeded () const
 Reimplemented from ModelAPI_Feature::isPreviewNeeded(). Returns false. More...
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Feature kind. More...
static const std::string & DUMP_DIR_ID ()
 attribute name of true dumping directory More...
static const std::string & FILE_PATH_ID ()
 attribute name of file path More...
static const std::string & FILE_FORMAT_ID ()
 attribute name of file format More...
static const std::string & TOPOLOGICAL_NAMING_DUMP_ID ()
 attribute name of dumping by topological naming More...
static const std::string & GEOMETRIC_DUMP_ID ()
 attribute name of dumping by geometric selection More...
static const std::string & WEAK_NAMING_DUMP_ID ()
 attribute name of dumping by using weak naming identifiers of selection More...
static const std::string & EXPORT_VARIABLES_ID ()
 attribute name for boolean flag to export variable names correspondence to another module More...
static const std::string & MULTIFILE_ID ()
 attribute name for multifile dump More...
static std::string group ()
EXCHANGEPLUGIN_EXPORT void dump (const std::string &theFileName)
 Performs dump to the file. More...
◆ ExchangePlugin_Dump()
ExchangePlugin_Dump::ExchangePlugin_Dump ( )
◆ ~ExchangePlugin_Dump()
ExchangePlugin_Dump::~ExchangePlugin_Dump ( )
Default destructor.
◆ ID()
static const std::string & ExchangePlugin_Dump::ID ( )
inlinestatic
Feature kind.
◆ DUMP_DIR_ID()
static const std::string & ExchangePlugin_Dump::DUMP_DIR_ID ( )
inlinestatic
◆ FILE_PATH_ID()
static const std::string & ExchangePlugin_Dump::FILE_PATH_ID ( )
inlinestatic
◆ FILE_FORMAT_ID()
static const std::string & ExchangePlugin_Dump::FILE_FORMAT_ID ( )
inlinestatic
◆ TOPOLOGICAL_NAMING_DUMP_ID()
static const std::string & ExchangePlugin_Dump::TOPOLOGICAL_NAMING_DUMP_ID ( )
inlinestatic
◆ GEOMETRIC_DUMP_ID()
static const std::string & ExchangePlugin_Dump::GEOMETRIC_DUMP_ID ( )
inlinestatic
◆ WEAK_NAMING_DUMP_ID()
static const std::string & ExchangePlugin_Dump::WEAK_NAMING_DUMP_ID ( )
inlinestatic
◆ EXPORT_VARIABLES_ID()
static const std::string & ExchangePlugin_Dump::EXPORT_VARIABLES_ID ( )
inlinestatic
◆ MULTIFILE_ID()
static const std::string & ExchangePlugin_Dump::MULTIFILE_ID ( )
inlinestatic
◆ getKind()
virtual EXCHANGEPLUGIN_EXPORT const std::string & ExchangePlugin_Dump::getKind ( )
Implements ModelAPI_Feature.
◆ initAttributes()
void ExchangePlugin_Dump::initAttributes ( )
Implements ModelAPI_Object.
◆ execute()
void ExchangePlugin_Dump::execute ( )
◆ isMacro()
virtual EXCHANGEPLUGIN_EXPORT bool ExchangePlugin_Dump::isMacro ( ) const
◆ isPreviewNeeded()
virtual EXCHANGEPLUGIN_EXPORT bool ExchangePlugin_Dump::isPreviewNeeded ( ) const
◆ dump()
void ExchangePlugin_Dump::dump ( const std::string &  theFileName)
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
