SketchPlugin_Ellipse Class Reference
Feature for creation of the new ellipse in Sketch. More...
#include <SketchPlugin_Ellipse.h>
Inheritance diagram for SketchPlugin_Ellipse:
virtual SKETCHPLUGIN_EXPORT const std::string & getKind ()
virtual SKETCHPLUGIN_EXPORT bool isFixed ()
virtual SKETCHPLUGIN_EXPORT void attributeChanged (const std::string &theID)
virtual SKETCHPLUGIN_EXPORT void execute ()
 SketchPlugin_Ellipse ()
virtual bool isCopy () const
 Returns true of the feature is a copy of other feature. More...
virtual bool isInHistory ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Ellipse feature kind. More...
static const std::string & CENTER_ID ()
 2D point - center of the ellipse More...
static const std::string & FIRST_FOCUS_ID ()
 2D point - focus of the ellipse More...
static const std::string & SECOND_FOCUS_ID ()
 2D point - second focus of the ellipse More...
static const std::string & MAJOR_AXIS_START_ID ()
 2D point - start point of major axis More...
static const std::string & MAJOR_AXIS_END_ID ()
 2D point - end point of major axis More...
static const std::string & MINOR_AXIS_START_ID ()
 2D point - start point of minor axis More...
static const std::string & MINOR_AXIS_END_ID ()
 2D point - end point of minor axis More...
static const std::string & MAJOR_RADIUS_ID ()
 Major radius of the ellipse. More...
static const std::string & MINOR_RADIUS_ID ()
 Minor radius of the ellipse. More...
static const std::string & AUXILIARY_ID ()
 Reference to the construction type of the feature. More...
static const std::string & EXTERNAL_ID ()
 Reference to the external edge or vertex as a AttributeSelection. More...
static const std::string & COPY_ID ()
 Reference to the copy type of the feature. More...
static const std::string & PARENT_ID ()
 Reference to the parent feature if exist. More...
static const int SKETCH_LINE_WIDTH_AUXILIARY ()
 Width of the auxiliary line. More...
static const int SKETCH_LINE_WIDTH ()
 Width of the line. More...
static const int SKETCH_LINE_STYLE_AUXILIARY ()
 Style of the auxiliary line. More...
static const int SKETCH_LINE_STYLE ()
 Style of the line. More...
static std::string group ()
virtual void initDerivedClassAttributes ()
 Initializes attributes of derived class. More...
virtual void initDerivedClassAttributes2 ()
 Initializes attributes of derived class which were added recently. More...
void keepCurrentFeature ()
void restoreCurrentFeature ()
◆ SketchPlugin_Ellipse()
SketchPlugin_Ellipse::SketchPlugin_Ellipse ( )
◆ ID()
static const std::string & SketchPlugin_Ellipse::ID ( )
inlinestatic
◆ CENTER_ID()
static const std::string & SketchPlugin_Ellipse::CENTER_ID ( )
inlinestatic
◆ FIRST_FOCUS_ID()
static const std::string & SketchPlugin_Ellipse::FIRST_FOCUS_ID ( )
inlinestatic
◆ SECOND_FOCUS_ID()
static const std::string & SketchPlugin_Ellipse::SECOND_FOCUS_ID ( )
inlinestatic
◆ MAJOR_AXIS_START_ID()
static const std::string & SketchPlugin_Ellipse::MAJOR_AXIS_START_ID ( )
inlinestatic
◆ MAJOR_AXIS_END_ID()
static const std::string & SketchPlugin_Ellipse::MAJOR_AXIS_END_ID ( )
inlinestatic
◆ MINOR_AXIS_START_ID()
static const std::string & SketchPlugin_Ellipse::MINOR_AXIS_START_ID ( )
inlinestatic
◆ MINOR_AXIS_END_ID()
static const std::string & SketchPlugin_Ellipse::MINOR_AXIS_END_ID ( )
inlinestatic
◆ MAJOR_RADIUS_ID()
static const std::string & SketchPlugin_Ellipse::MAJOR_RADIUS_ID ( )
inlinestatic
◆ MINOR_RADIUS_ID()
static const std::string & SketchPlugin_Ellipse::MINOR_RADIUS_ID ( )
inlinestatic
◆ getKind()
virtual SKETCHPLUGIN_EXPORT const std::string & SketchPlugin_Ellipse::getKind ( )
Implements ModelAPI_Feature.
◆ isFixed()
bool SketchPlugin_Ellipse::isFixed ( )
Reimplemented from SketchPlugin_Feature.
◆ attributeChanged()
void SketchPlugin_Ellipse::attributeChanged ( const std::string &  theID)
◆ execute()
void SketchPlugin_Ellipse::execute ( )
◆ initDerivedClassAttributes()
void SketchPlugin_Ellipse::initDerivedClassAttributes ( )
Reimplemented from SketchPlugin_SketchEntity.
◆ AUXILIARY_ID()
static const std::string & SketchPlugin_SketchEntity::AUXILIARY_ID ( )
inlinestaticinherited
◆ EXTERNAL_ID()
static const std::string & SketchPlugin_SketchEntity::EXTERNAL_ID ( )
◆ COPY_ID()
static const std::string & SketchPlugin_SketchEntity::COPY_ID ( )
◆ PARENT_ID()
static const std::string & SketchPlugin_SketchEntity::PARENT_ID ( )
◆ SKETCH_LINE_WIDTH_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH_AUXILIARY ( )
◆ SKETCH_LINE_WIDTH()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH ( )
Width of the line.
◆ SKETCH_LINE_STYLE_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE_AUXILIARY ( )
◆ SKETCH_LINE_STYLE()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE ( )
Style of the line.
◆ initAttributes()
void SketchPlugin_SketchEntity::initAttributes ( )
Implements ModelAPI_Object.
Reimplemented in SketchPlugin_Fillet, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, and SketchPlugin_MacroEllipticArc.
◆ isExternal()
virtual bool SketchPlugin_SketchEntity::isExternal ( ) const
inlinevirtualinherited
◆ isCopy()
virtual bool SketchPlugin_SketchEntity::isCopy ( ) const
◆ initDerivedClassAttributes2()
virtual void SketchPlugin_SketchEntity::initDerivedClassAttributes2 ( )
Reimplemented in SketchPlugin_Projection.
◆ isInHistory()
◆ canBeDisplayed()
true
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
