| ExchangePlugin_ImportFeatureBase ()=default | |
| virtual | ~ExchangePlugin_ImportFeatureBase ()=default |
| Default destructor. More... | |
| virtual const std::string & | getKind ()=0 |
| Returns the unique kind of a feature. More... | |
| virtual void | execute ()=0 |
| virtual bool | isPreviewNeeded () const |
| Reimplemented from ModelAPI_Feature::isPreviewNeeded(). Returns false. More... | |
| virtual std::shared_ptr< ModelAPI_Feature > | addFeature (std::string theID) |
| Reimplemented from ModelAPI_CompositeFeature::addFeature() More... | |
| virtual int | numberOfSubs (bool forTree=false) const |
| Reimplemented from ModelAPI_CompositeFeature::numberOfSubs() More... | |
| virtual std::shared_ptr< ModelAPI_Feature > | subFeature (const int theIndex, bool forTree=false) |
| Reimplemented from ModelAPI_CompositeFeature::subFeature() More... | |
| virtual int | subFeatureId (const int theIndex) const |
| Reimplemented from ModelAPI_CompositeFeature::subFeatureId() More... | |
| virtual bool | isSub (ObjectPtr theObject) const |
| Reimplemented from ModelAPI_CompositeFeature::isSub() More... | |
| virtual void | removeFeature (std::shared_ptr< ModelAPI_Feature > theFeature) |
| Reimplemented from ModelAPI_CompositeFeature::removeFeature() More... | |
| virtual void | erase () |
| in addition removes all subs More... | |
| std::wstring | name () |
| static const std::string & | FILE_PATH_ID () |
| attribute name of file path More... | |
| static const std::string & | FEATURES_ID () |
| All features (list of references) More... | |
| static const std::string & | TARGET_PART_ID () |
| attribute name of target part More... | |
| virtual void | importFile (const std::string &theFileName)=0 |
| Performs the import of the file. More... | |
| std::shared_ptr< ModelAPI_ResultBody > | createResultBody (std::shared_ptr< GeomAPI_Shape > aGeomShape) |
| Creates and prepares a result body from the shape. More... | |
| void | loadNamingDS (std::shared_ptr< GeomAPI_Shape > theGeomShape, std::shared_ptr< ModelAPI_ResultBody > theResultBody) |
| Loads Naming data structure to the document. More... | |
default |
virtualdefault |
Default destructor.
inlinestatic |
inlinestatic |
inlinestatic |
pure virtual |
Implements ModelAPI_Feature.
Implemented in ExchangePlugin_ImportFeature, and ExchangePlugin_Import_ImageFeature.
Implements ModelAPI_Object.
pure virtual |
inlinevirtual |
Implements ModelAPI_CompositeFeature.
protectedpure virtual |
protected |
protected |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
