Feature for creation of wire from sketch edges or existing wires. More...
#include <BuildPlugin_Wire.h>
| BuildPlugin_Wire () | |
| virtual void | execute () |
| virtual bool | customAction (const std::string &theActionId) |
| Performs some functionality by action id. More... | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | BASE_OBJECTS_ID () |
| Attribute name of base objects. More... | |
| static const std::string & | ADD_CONTOUR_ACTION_ID () |
| static const std::string & | INTERSECT_ID () |
| Attribute name of "Compute intersections" checkbox. More... | |
| BuildPlugin_Wire::BuildPlugin_Wire | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
| [in] | theAttributeId | action key id. |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
