FeaturesPlugin_RemoveSubShapes Class Reference
Feature for removing sub-shapes from collections(wire, shell, compsolid, compound). More...
#include <FeaturesPlugin_RemoveSubShapes.h>
Inheritance diagram for FeaturesPlugin_RemoveSubShapes:
 FeaturesPlugin_RemoveSubShapes ()
virtual void execute ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Feature kind. More...
static const std::string & BASE_SHAPE_ID ()
 Attribute name of base shape. More...
static const std::string & CREATION_METHOD ()
 Attribute name for creation method. More...
static const std::string & CREATION_METHOD_BY_KEEP_SUBSHAPES ()
static const std::string & CREATION_METHOD_BY_REMOVE_SUBSHAPES ()
static const std::string & SUBSHAPES_TO_KEEP_ID ()
 Attribute name of sub-shapes to keep. More...
static const std::string & SUBSHAPES_TO_REMOVE_ID ()
 Attribute name of sub-shapes to remove. More...
static std::string group ()
◆ FeaturesPlugin_RemoveSubShapes()
FeaturesPlugin_RemoveSubShapes::FeaturesPlugin_RemoveSubShapes ( )
◆ ID()
static const std::string & FeaturesPlugin_RemoveSubShapes::ID ( )
inlinestatic
Feature kind.
◆ BASE_SHAPE_ID()
static const std::string & FeaturesPlugin_RemoveSubShapes::BASE_SHAPE_ID ( )
inlinestatic
◆ CREATION_METHOD()
static const std::string & FeaturesPlugin_RemoveSubShapes::CREATION_METHOD ( )
inlinestatic
◆ CREATION_METHOD_BY_KEEP_SUBSHAPES()
static const std::string & FeaturesPlugin_RemoveSubShapes::CREATION_METHOD_BY_KEEP_SUBSHAPES ( )
inlinestatic
◆ CREATION_METHOD_BY_REMOVE_SUBSHAPES()
static const std::string & FeaturesPlugin_RemoveSubShapes::CREATION_METHOD_BY_REMOVE_SUBSHAPES ( )
inlinestatic
◆ SUBSHAPES_TO_KEEP_ID()
static const std::string & FeaturesPlugin_RemoveSubShapes::SUBSHAPES_TO_KEEP_ID ( )
inlinestatic
◆ SUBSHAPES_TO_REMOVE_ID()
static const std::string & FeaturesPlugin_RemoveSubShapes::SUBSHAPES_TO_REMOVE_ID ( )
inlinestatic
◆ getKind()
virtual const std::string & FeaturesPlugin_RemoveSubShapes::getKind ( )
the kind of a feature.
Implements ModelAPI_Feature.
◆ initAttributes()
void FeaturesPlugin_RemoveSubShapes::initAttributes ( )
Implements ModelAPI_Object.
◆ attributeChanged()
void FeaturesPlugin_RemoveSubShapes::attributeChanged ( const std::string &  theID)
[in]theIDidentifier of changed attribute.
◆ execute()
void FeaturesPlugin_RemoveSubShapes::execute ( )
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
