SketchPlugin_Projection Class Reference
Feature for creation of external feature as a projection onto the sketch plane. More...
#include <SketchPlugin_Projection.h>
Inheritance diagram for SketchPlugin_Projection:
virtual bool isFixed ()
 Returns true because projected feature is always external. More...
virtual void execute ()
 Called on change of any argument-attribute of this object: for external point. More...
virtual bool isMacro () const
 SketchPlugin_Projection ()
virtual bool isCopy () const
 Returns true of the feature is a copy of other feature. More...
virtual bool isInHistory ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Projection feature kind. More...
static const std::string & EXTERNAL_FEATURE_ID ()
static const std::string & PROJECTED_FEATURE_ID ()
static const std::string & INCLUDE_INTO_RESULT ()
static const std::string & KEEP_REFERENCE_ID ()
static const std::string & MAKE_FIXED ()
static const std::string & FIXED_CONSTRAINT_ID ()
static const std::string & AUXILIARY_ID ()
 Reference to the construction type of the feature. More...
static const std::string & EXTERNAL_ID ()
 Reference to the external edge or vertex as a AttributeSelection. More...
static const std::string & COPY_ID ()
 Reference to the copy type of the feature. More...
static const std::string & PARENT_ID ()
 Reference to the parent feature if exist. More...
static const int SKETCH_LINE_WIDTH_AUXILIARY ()
 Width of the auxiliary line. More...
static const int SKETCH_LINE_WIDTH ()
 Width of the line. More...
static const int SKETCH_LINE_STYLE_AUXILIARY ()
 Style of the auxiliary line. More...
static const int SKETCH_LINE_STYLE ()
 Style of the line. More...
static std::string group ()
virtual void initDerivedClassAttributes ()
 Initializes attributes of derived class. More...
virtual void initDerivedClassAttributes2 ()
 Initializes attributes of keeping the reference to the original shape. More...
void keepCurrentFeature ()
void restoreCurrentFeature ()
◆ SketchPlugin_Projection()
SketchPlugin_Projection::SketchPlugin_Projection ( )
◆ ID()
static const std::string & SketchPlugin_Projection::ID ( )
inlinestatic
◆ getKind()
virtual const std::string & SketchPlugin_Projection::getKind ( )
Implements ModelAPI_Feature.
◆ isFixed()
virtual bool SketchPlugin_Projection::isFixed ( )
Reimplemented from SketchPlugin_Feature.
◆ canBeDisplayed()
virtual bool SketchPlugin_Projection::canBeDisplayed ( ) const
false
◆ execute()
void SketchPlugin_Projection::execute ( )
◆ attributeChanged()
void SketchPlugin_Projection::attributeChanged ( const std::string &  theID)
◆ isMacro()
bool SketchPlugin_Projection::isMacro ( ) const
Returns true if this feature is used as macro: creates other features and then removed.
This feature may change its macro-state according to selected item.
false by default
◆ initDerivedClassAttributes()
void SketchPlugin_Projection::initDerivedClassAttributes ( )
Reimplemented from SketchPlugin_SketchEntity.
◆ initDerivedClassAttributes2()
void SketchPlugin_Projection::initDerivedClassAttributes2 ( )
◆ AUXILIARY_ID()
static const std::string & SketchPlugin_SketchEntity::AUXILIARY_ID ( )
inlinestaticinherited
◆ EXTERNAL_ID()
static const std::string & SketchPlugin_SketchEntity::EXTERNAL_ID ( )
◆ COPY_ID()
static const std::string & SketchPlugin_SketchEntity::COPY_ID ( )
◆ PARENT_ID()
static const std::string & SketchPlugin_SketchEntity::PARENT_ID ( )
◆ SKETCH_LINE_WIDTH_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH_AUXILIARY ( )
◆ SKETCH_LINE_WIDTH()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH ( )
Width of the line.
◆ SKETCH_LINE_STYLE_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE_AUXILIARY ( )
◆ SKETCH_LINE_STYLE()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE ( )
Style of the line.
◆ initAttributes()
void SketchPlugin_SketchEntity::initAttributes ( )
Implements ModelAPI_Object.
Reimplemented in SketchPlugin_Fillet, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, and SketchPlugin_MacroEllipticArc.
◆ isExternal()
virtual bool SketchPlugin_SketchEntity::isExternal ( ) const
inlinevirtualinherited
◆ isCopy()
virtual bool SketchPlugin_SketchEntity::isCopy ( ) const
◆ isInHistory()
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
