SketchPlugin_Line Class Reference
Feature for creation of the new part in PartSet. More...
#include <SketchPlugin_Line.h>
Inheritance diagram for SketchPlugin_Line:
virtual bool isFixed ()
virtual void execute ()
virtual std::string processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Apply information of the message to current object. More...
 SketchPlugin_Line ()
virtual bool isCopy () const
 Returns true of the feature is a copy of other feature. More...
virtual bool isInHistory ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Arc feature kind. More...
static const std::string & START_ID ()
 Start 2D point of the line. More...
static const std::string & END_ID ()
 End 2D point of the line. More...
static const std::string & LENGTH_ID ()
 Line length. More...
static const std::string & AUXILIARY_ID ()
 Reference to the construction type of the feature. More...
static const std::string & EXTERNAL_ID ()
 Reference to the external edge or vertex as a AttributeSelection. More...
static const std::string & COPY_ID ()
 Reference to the copy type of the feature. More...
static const std::string & PARENT_ID ()
 Reference to the parent feature if exist. More...
static const int SKETCH_LINE_WIDTH_AUXILIARY ()
 Width of the auxiliary line. More...
static const int SKETCH_LINE_WIDTH ()
 Width of the line. More...
static const int SKETCH_LINE_STYLE_AUXILIARY ()
 Style of the auxiliary line. More...
static const int SKETCH_LINE_STYLE ()
 Style of the line. More...
static std::string group ()
virtual void initDerivedClassAttributes ()
 Initializes attributes of derived class. More...
virtual void initDerivedClassAttributes2 ()
 Initializes attributes of derived class which were added recently. More...
void keepCurrentFeature ()
void restoreCurrentFeature ()
◆ SketchPlugin_Line()
SketchPlugin_Line::SketchPlugin_Line ( )
◆ ID()
static const std::string & SketchPlugin_Line::ID ( )
inlinestatic
Arc feature kind.
◆ START_ID()
static const std::string & SketchPlugin_Line::START_ID ( )
inlinestatic
◆ END_ID()
static const std::string & SketchPlugin_Line::END_ID ( )
inlinestatic
◆ LENGTH_ID()
static const std::string & SketchPlugin_Line::LENGTH_ID ( )
inlinestatic
Line length.
◆ getKind()
const std::string & SketchPlugin_Line::getKind ( )
Implements ModelAPI_Feature.
◆ isFixed()
bool SketchPlugin_Line::isFixed ( )
Reimplemented from SketchPlugin_Feature.
◆ initAttributes()
void SketchPlugin_Line::initAttributes ( )
new attributes should be added to end of the feature in order to provide correct attribute values in previous saved studies
Reimplemented from SketchPlugin_SketchEntity.
◆ execute()
void SketchPlugin_Line::execute ( )
◆ processEvent()
std::string SketchPlugin_Line::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
It fills start attribute of the current feature by last attribute of the message feature, build coincidence if message has selected object
Implements ModelAPI_IReentrant.
◆ attributeChanged()
void SketchPlugin_Line::attributeChanged ( const std::string &  theID)
◆ initDerivedClassAttributes()
void SketchPlugin_Line::initDerivedClassAttributes ( )
◆ AUXILIARY_ID()
static const std::string & SketchPlugin_SketchEntity::AUXILIARY_ID ( )
inlinestaticinherited
◆ EXTERNAL_ID()
static const std::string & SketchPlugin_SketchEntity::EXTERNAL_ID ( )
◆ COPY_ID()
static const std::string & SketchPlugin_SketchEntity::COPY_ID ( )
◆ PARENT_ID()
static const std::string & SketchPlugin_SketchEntity::PARENT_ID ( )
◆ SKETCH_LINE_WIDTH_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH_AUXILIARY ( )
◆ SKETCH_LINE_WIDTH()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH ( )
Width of the line.
◆ SKETCH_LINE_STYLE_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE_AUXILIARY ( )
◆ SKETCH_LINE_STYLE()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE ( )
Style of the line.
◆ isExternal()
virtual bool SketchPlugin_SketchEntity::isExternal ( ) const
inlinevirtualinherited
◆ isCopy()
virtual bool SketchPlugin_SketchEntity::isCopy ( ) const
◆ initDerivedClassAttributes2()
virtual void SketchPlugin_SketchEntity::initDerivedClassAttributes2 ( )
Reimplemented in SketchPlugin_Projection.
◆ isInHistory()
◆ canBeDisplayed()
true
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
Implements ModelAPI_Object.
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
