SketchPlugin_ConstraintAngle Class Reference
Feature for creation of a new constraint fix angle between two lines. More...
#include <SketchPlugin_ConstraintAngle.h>
Inheritance diagram for SketchPlugin_ConstraintAngle:
virtual void execute ()
virtual bool compute (const std::string &theAttributeId)
virtual void colorConfigInfo (std::string &theSection, std::string &theName, std::string &theDefault)
void setNumericValue (const double theValue) override
 Set numeric value to attribute ANGLE_VALUE_ID() More...
double getNumericValue () override
 Get numeric value of attribute MY_ANGLE_VALUE_ID() More...
virtual std::string processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Apply information of the message to current object. More...
 SketchPlugin_ConstraintAngle ()
virtual bool isInHistory ()
virtual bool isCopy () const
virtual bool isFixed ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Angle constraint kind. More...
static const std::string & TYPE_ID ()
 attribute name of operation type More...
static const std::string & PREV_TYPE_ID ()
 attribute name of previous value of operation type More...
static const std::string & ANGLE_VALUE_ID ()
static const std::string & ANGLE_REVERSED_FIRST_LINE_ID ()
 attribute name indicating the first line is reversed More...
static const std::string & ANGLE_REVERSED_SECOND_LINE_ID ()
 attribute name indicating the second line is reversed More...
static const std::string & LOCATION_TYPE_ID ()
 attribute name of dimension location type More...
static const std::string & SELECTED_FIRST_POINT_ID ()
 attribute name indicating the first point selected More...
static const std::string & SELECTED_SECOND_POINT_ID ()
 attribute name indicating the second point selected More...
static const std::string & VERSION_ID ()
 Attribute name of the version of Angle feature. More...
static std::string group ()
Static Public Attributes
static const int THE_VERSION_0 = 0
static const int THE_VERSION_1 = 20191210
void calculateAngle ()
 Calculate current value of the angle. More...
void calculateAnglePosition ()
 Compute the position of the angle presentation (the quarter selected by the user) More...
double getAngleForType (double theAngle, bool isReversed1=false, bool isReversed2=false)
 Converts the angle value according to the current angle type and sketch plane normal. More...
void updateAngleValue ()
 Update value of ANGLE_VALUE attribute according to the current type. More...
void updateVersion ()
 Update parameters of the Angle to meet requirements for the latest version. More...
void keepCurrentFeature ()
void restoreCurrentFeature ()
This constraint has two attributes: SketchPlugin_Constraint::ENTITY_A() and SketchPlugin_Constraint::ENTITY_B()
◆ SketchPlugin_ConstraintAngle()
SketchPlugin_ConstraintAngle::SketchPlugin_ConstraintAngle ( )
◆ ID()
static const std::string & SketchPlugin_ConstraintAngle::ID ( )
inlinestatic
◆ getKind()
virtual const std::string & SketchPlugin_ConstraintAngle::getKind ( )
Implements ModelAPI_Feature.
◆ TYPE_ID()
static const std::string & SketchPlugin_ConstraintAngle::TYPE_ID ( )
inlinestatic
◆ PREV_TYPE_ID()
static const std::string & SketchPlugin_ConstraintAngle::PREV_TYPE_ID ( )
inlinestatic
◆ ANGLE_VALUE_ID()
static const std::string & SketchPlugin_ConstraintAngle::ANGLE_VALUE_ID ( )
inlinestatic
◆ ANGLE_REVERSED_FIRST_LINE_ID()
static const std::string & SketchPlugin_ConstraintAngle::ANGLE_REVERSED_FIRST_LINE_ID ( )
inlinestatic
◆ ANGLE_REVERSED_SECOND_LINE_ID()
static const std::string & SketchPlugin_ConstraintAngle::ANGLE_REVERSED_SECOND_LINE_ID ( )
inlinestatic
◆ LOCATION_TYPE_ID()
static const std::string & SketchPlugin_ConstraintAngle::LOCATION_TYPE_ID ( )
inlinestatic
◆ SELECTED_FIRST_POINT_ID()
static const std::string & SketchPlugin_ConstraintAngle::SELECTED_FIRST_POINT_ID ( )
inlinestatic
◆ SELECTED_SECOND_POINT_ID()
static const std::string & SketchPlugin_ConstraintAngle::SELECTED_SECOND_POINT_ID ( )
inlinestatic
◆ VERSION_ID()
static const std::string & SketchPlugin_ConstraintAngle::VERSION_ID ( )
inlinestatic
◆ execute()
void SketchPlugin_ConstraintAngle::execute ( )
◆ compute()
bool SketchPlugin_ConstraintAngle::compute ( const std::string &  theAttributeId)
◆ initAttributes()
void SketchPlugin_ConstraintAngle::initAttributes ( )
Implements ModelAPI_Object.
◆ colorConfigInfo()
void SketchPlugin_ConstraintAngle::colorConfigInfo ( std::string &  theSection,
std::string &  theName,
std::string &  theDefault
Returns the parameters of color definition in the resources config manager.
◆ attributeChanged()
void SketchPlugin_ConstraintAngle::attributeChanged ( const std::string &  theID)
theIDidentifier of changed attribute
◆ getAISObject()
AISObjectPtr SketchPlugin_ConstraintAngle::getAISObject ( AISObjectPtr  thePrevious)
◆ setNumericValue()
void SketchPlugin_ConstraintAngle::setNumericValue ( const double  theValue)
overridevirtual
theValuenew set value
Reimplemented from SketchPlugin_Constraint.
◆ getNumericValue()
double SketchPlugin_ConstraintAngle::getNumericValue ( )
inlineoverridevirtual
◆ processEvent()
std::string SketchPlugin_ConstraintAngle::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
It fills selected point and the first object.
Implements ModelAPI_IReentrant.
◆ calculateAngle()
void SketchPlugin_ConstraintAngle::calculateAngle ( )
◆ calculateAnglePosition()
void SketchPlugin_ConstraintAngle::calculateAnglePosition ( )
◆ getAngleForType()
double SketchPlugin_ConstraintAngle::getAngleForType ( double  theAngle,
bool  isReversed1 = false,
bool  isReversed2 = false
The in/out angle is in degree.
theAnglea source for the calculated angle
adouble angle value
◆ updateAngleValue()
void SketchPlugin_ConstraintAngle::updateAngleValue ( )
◆ updateVersion()
void SketchPlugin_ConstraintAngle::updateVersion ( )
◆ VALUE()
inlinestaticinherited
◆ FLYOUT_VALUE_PNT()
◆ CONSTRAINT_ACTIVE()
◆ ENTITY_A()
◆ ENTITY_B()
◆ ENTITY_C()
◆ ENTITY_D()
◆ ATTRIBUTE()
◆ isZeroValueAllowed()
inlinevirtualinherited
◆ isInHistory()
◆ isExternal()
◆ isCopy()
◆ canBeDisplayed()
true
◆ isFixed()
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
