Model_ResultBody Class Reference
The body (shape) result of a feature. More...
#include <Model_ResultBody.h>
Inheritance diagram for Model_ResultBody:
enum  ConnectedTopologyFlag { ConnectionNotComputed , IsConnected , IsNotConnected }
 Internal enumeration for storage the information of connected topology flag. More...
virtual ~Model_ResultBody ()
 Removes the stored builders. More...
 Request for initialization of data model of the result body: adding all attributes. More...
virtual bool generated (const GeomShapePtr &theNewShape, const std::string &theName, const bool theCheckIsInResult=true) override
 Records the subshape newShape which was generated during a topological construction. More...
virtual void loadGeneratedShapes (const std::shared_ptr< GeomAlgoAPI_MakeShape > &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const std::string &theName="", const bool theSaveOldIfNotInTree=false) override
 load generated shapes More...
virtual void loadModifiedShapes (const std::shared_ptr< GeomAlgoAPI_MakeShape > &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const std::string &theName="") override
 load modified shapes for sub-objects More...
virtual void loadFirstLevel (GeomShapePtr theShape, const std::string &theName)
 load shapes of the first level (to be used during shape import) More...
virtual int numberOfSubs (bool forTree=false) const
 Returns the number of sub-elements. More...
virtual ResultBodyPtr subResult (const int theIndex, bool forTree=false) const
 Returns the sub-result by zero-base index. More...
virtual bool isSub (ObjectPtr theObject, int &theIndex) const
 Returns true if feature or result belong to this composite feature as subs Returns theIndex - zero based index of sub if found. More...
virtual void colorConfigInfo (std::string &theSection, std::string &theName, std::string &theDefault)
 Returns the parameters of color definition in the resources configuration manager. More...
virtual bool setDisabled (std::shared_ptr< ModelAPI_Result > theThis, const bool theFlag)
 Disables the result body: keeps the resulting shape as selection, but erases the underlying naming data structure if theFlag if false. More...
virtual bool isConcealed ()
 The compsolid is concealed if at least one of the sub is concealed. More...
virtual void setIsConcealed (const bool theValue, const bool theForced=false)
 Sets all subs as concealed in the data tree (referenced by other objects) More...
virtual bool isConnectedTopology ()
 Returns true is the topology is connected. More...
virtual void cleanCash () override
 Cleans cash related to the already stored elements. More...
virtual bool hasTexture () override
 sets the texture file More...
virtual const std::vector< int > & findShapeColor (const std::wstring &theShapeName)
 Find the imported color by the construction name of a shape. More...
virtual void setSubShapeColorIfAny (const std::shared_ptr< ModelAPI_Result > theResult, const std::shared_ptr< GeomAPI_Shape > theShape)
 Add color to sub shape. More...
virtual void store (const GeomShapePtr &theShape, const bool theIsStoreSameShapes=true)
 Stores the shape (called by the execution method). More...
virtual void storeGenerated (const GeomShapePtr &theFromShape, const GeomShapePtr &theToShape)
 Stores the generated shape (called by the execution method). More...
virtual void storeGenerated (const std::list< GeomShapePtr > &theFromShapes, const GeomShapePtr &theToShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape)
 Stores the root modified shapes (called by the execution method). More...
virtual void storeModified (const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const bool theIsCleanStored=true)
 Stores the modified shape (called by the execution method). More...
virtual void storeModified (const std::list< GeomShapePtr > &theOldShapes, const GeomShapePtr &theNewShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape)
virtual GeomShapePtr shape ()
 Returns the shape-result produced by this feature. More...
virtual void generated (const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const std::string &theName="")
 Records the shape newShape which was generated from the shape oldShape during a topological construction. More...
virtual void modified (const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const std::string &theName="")
 Records the shape newShape which is a modification of the shape oldShape. More...
virtual void loadDeletedShapes (const std::shared_ptr< GeomAlgoAPI_MakeShape > &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const GeomShapePtr &theShapesToExclude=GeomShapePtr())
 load deleted shapes More...
 Set displayed flag to the result and all sub results. More...
virtual bool isDisabled ()
 Returns the result is disabled or not. More...
 Returns all the vertices of this result. More...
 Returns all the edges of this result. More...
 Returns all the wires of this result. More...
 Returns all the faces of this result. More...
 Returns all the shells of this result. More...
 Returns all the solids of this result. More...
 On change of attribute of the result update presentation of this result: for the current moment there are only presentation attributes assigned to results. More...
virtual bool isInHistory ()
virtual bool isDisplayed ()
static const std::string & IMAGE_ID ()
 Reference to the image attribute of the result body. More...
static std::string group ()
static const std::string & DEFAULT_COLOR ()
 default color for a result body More...
static const std::string DEFAULT_DEFLECTION ()
 default deflection for a result body More...
static const std::string & COLOR_ID ()
 Reference to the color of the result. More...
static const std::string & DEFLECTION_ID ()
 Reference to the deflection of the result. More...
static const std::string & TRANSPARENCY_ID ()
 Reference to the transparency of the result. More...
static const std::string & ISO_LINES_ID ()
static const std::string & SHOW_ISO_LINES_ID ()
static const std::string & SHOW_EDGES_DIRECTION_ID ()
static const std::string & BRING_TO_FRONT_ID ()
 Reference to the BringToFront flag of the result. More...
 Model_ResultBody ()
 Makes a body on the given feature. More...
void updateSubs (const std::shared_ptr< GeomAPI_Shape > &theThisShape, const bool theShapeChanged=true)
 Updates the sub-bodies if shape of this object is composite-solid. More...
void updateSubs (const GeomShapePtr &theThisShape, const std::list< GeomShapePtr > &theOlds, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, const bool isGenerated)
 Updates the sub-bodies in accordance to the algorithm history information. More...
void updateConcealment ()
 Checks the state of children and parents to send events of creation/erase when needed. More...
void computeOldForSub (const GeomShapePtr &theSub, const std::list< GeomShapePtr > &theAllOlds, std::list< GeomShapePtr > &theOldForSub)
 Adds to theOldForSub only old shapes that where used for theSub creation. More...
std::wstring addShapeName (std::shared_ptr< GeomAPI_Shape > theShape, const std::wstring &theName) override
 Add shape Name for read shape in step file. More...
void addShapeColor (const std::wstring &theName, std::vector< int > &theColor) override
 Add color for shape Name read shape in step file. More...
void setSubShapeColor (const std::shared_ptr< ModelAPI_Result > theResult, const std::shared_ptr< GeomAPI_Shape > theShape, const std::vector< int > &theColor)
void getSubShapeColor (const std::shared_ptr< ModelAPI_Result > theResult, const std::shared_ptr< GeomAPI_Shape > theShape, std::vector< int > &theColor)
 Get color from sub shape. More...
void getColoredSubShapes (const std::shared_ptr< ModelAPI_Result > theResult, std::map< std::shared_ptr< GeomAPI_Shape >, std::vector< int > > &theColoredShapes)
 Get colored shapes from result. More...
void removeSubShapeColors (const std::shared_ptr< ModelAPI_Result > theResult)
 Forget subshape colors. More...
void setShapeName (std::map< std::wstring, std::shared_ptr< GeomAPI_Shape > > &theShapeName, std::map< std::wstring, std::vector< int > > &theColorsShape) override
 Set the map of name and color read shape in step file. More...
virtual MODELAPI_EXPORT std::shared_ptr< ModelAPI_AttributeSelection > selection ()
 Return Attribute selection. More...
std::wstring findShapeName (std::shared_ptr< GeomAPI_Shape > theShape) override
 Find the name of shape read in step file. More...
void clearShapeNameAndColor () override
 Clear the map of name and color read shape in step file. More...
virtual void init ()
virtual void erase ()
 removes all fields from this feature More...
std::map< std::wstring, std::shared_ptr< GeomAPI_Shape > > myNamesOfShapes
 map with the name read in step file and shape More...
int myLastEmptyNameIndex
std::map< std::wstring, std::vector< int > > myColorsShape
 map from the construction name to the imported color More...
ConnectedTopologyFlag myConnect
 Keeps (not persistently) the connected topology flag. More...
ModelAPI_BodyBuilder * myBuilder
 provides the body processing in naming shape More...
bool myIsDisabled
 the result is disabled: removed for the user, but keeps the general info More...
Friends
class Model_Objects
Provides a shape that may be displayed in the viewer. May provide really huge results, so, working with this kind of result must be optimized. Also provides a container of sub-body result in case it is compound or compsolid.
◆ ConnectedTopologyFlag
not yet computed
IsConnected
IsNotConnected
◆ ~Model_ResultBody()
Model_ResultBody::~Model_ResultBody ( )
◆ Model_ResultBody()
Model_ResultBody::Model_ResultBody ( )
◆ initAttributes()
void Model_ResultBody::initAttributes ( )
Reimplemented from ModelAPI_Result.
◆ generated() [1/2]
bool Model_ResultBody::generated ( const GeomShapePtr &  theNewShape,
const std::string &  theName,
const bool  theCheckIsInResult = true
overridevirtual
As an example, consider the case of a face generated in construction of a box.
Implements ModelAPI_ResultBody.
◆ loadGeneratedShapes()
void Model_ResultBody::loadGeneratedShapes ( const std::shared_ptr< GeomAlgoAPI_MakeShape > &  theAlgo,
const GeomShapePtr &  theOldShape,
const std::string &  theName = "",
const bool  theSaveOldIfNotInTree = false
overridevirtual
◆ loadModifiedShapes()
void Model_ResultBody::loadModifiedShapes ( const std::shared_ptr< GeomAlgoAPI_MakeShape > &  theAlgo,
overridevirtual
◆ loadFirstLevel()
void Model_ResultBody::loadFirstLevel ( GeomShapePtr  theShape,
◆ numberOfSubs()
int Model_ResultBody::numberOfSubs ( bool  forTree = false) const
◆ subResult()
ResultBodyPtr Model_ResultBody::subResult ( const int  theIndex,
◆ isSub()
bool Model_ResultBody::isSub ( ObjectPtr  theObject,
int &  theIndex
◆ colorConfigInfo()
void Model_ResultBody::colorConfigInfo ( std::string &  theSection,
std::string &  theDefault
◆ setDisabled()
bool Model_ResultBody::setDisabled ( std::shared_ptr< ModelAPI_Result >  theThis,
const bool  theFlag
Or restores every thing on theFlag is true.
◆ isConcealed()
bool Model_ResultBody::isConcealed ( )
◆ setIsConcealed()
void Model_ResultBody::setIsConcealed ( const bool  theValue,
const bool  theForced = false
◆ isConnectedTopology()
bool Model_ResultBody::isConnectedTopology ( )
◆ cleanCash()
void Model_ResultBody::cleanCash ( )
overridevirtual
◆ hasTexture()
bool Model_ResultBody::hasTexture ( )
overridevirtual
◆ findShapeColor()
const std::vector< int > & Model_ResultBody::findShapeColor ( const std::wstring &  theShapeName)
Returns empty vector if not found.
◆ setSubShapeColorIfAny()
void Model_ResultBody::setSubShapeColorIfAny ( const std::shared_ptr< ModelAPI_Result >  theResult,
◆ updateSubs() [1/2]
void Model_ResultBody::updateSubs ( const std::shared_ptr< GeomAPI_Shape > &  theThisShape,
const bool  theShapeChanged = true
◆ updateSubs() [2/2]
void Model_ResultBody::updateSubs ( const GeomShapePtr &  theThisShape,
const std::list< GeomShapePtr > &  theOlds,
◆ updateConcealment()
void Model_ResultBody::updateConcealment ( )
◆ computeOldForSub()
void Model_ResultBody::computeOldForSub ( const GeomShapePtr &  theSub,
const std::list< GeomShapePtr > &  theAllOlds,
std::list< GeomShapePtr > &  theOldForSub
◆ addShapeName()
std::wstring Model_ResultBody::addShapeName ( std::shared_ptr< GeomAPI_Shape >  theShape,
const std::wstring &  theName
overrideprotectedvirtual
◆ addShapeColor()
void Model_ResultBody::addShapeColor ( const std::wstring &  theName,
std::vector< int > &  theColor
◆ setSubShapeColor()
void Model_ResultBody::setSubShapeColor ( const std::shared_ptr< ModelAPI_Result >  theResult,
const std::vector< int > &  theColor
◆ getSubShapeColor()
void Model_ResultBody::getSubShapeColor ( const std::shared_ptr< ModelAPI_Result >  theResult,
◆ getColoredSubShapes()
void Model_ResultBody::getColoredSubShapes ( const std::shared_ptr< ModelAPI_Result >  theResult,
std::map< std::shared_ptr< GeomAPI_Shape >, std::vector< int > > &  theColoredShapes
◆ removeSubShapeColors()
void Model_ResultBody::removeSubShapeColors ( const std::shared_ptr< ModelAPI_Result >  theResult)
◆ setShapeName()
void Model_ResultBody::setShapeName ( std::map< std::wstring, std::shared_ptr< GeomAPI_Shape > > &  theShapeName,
std::map< std::wstring, std::vector< int > > &  theColorsShape
◆ selection()
std::shared_ptr< ModelAPI_AttributeSelection > Model_ResultBody::selection ( )
◆ findShapeName()
std::wstring Model_ResultBody::findShapeName ( std::shared_ptr< GeomAPI_Shape >  theShape)
◆ clearShapeNameAndColor()
void Model_ResultBody::clearShapeNameAndColor ( )
◆ IMAGE_ID()
static const std::string & ModelAPI_ResultBody::IMAGE_ID ( )
inlinestaticinherited
◆ groupName()
std::string ModelAPI_ResultBody::groupName ( )
Implements ModelAPI_Object.
◆ group()
static std::string ModelAPI_ResultBody::group ( )
◆ DEFAULT_COLOR()
static const std::string & ModelAPI_ResultBody::DEFAULT_COLOR ( )
◆ DEFAULT_DEFLECTION()
static const std::string ModelAPI_ResultBody::DEFAULT_DEFLECTION ( )
◆ store()
void ModelAPI_ResultBody::store ( const GeomShapePtr &  theShape,
const bool  theIsStoreSameShapes = true
param[in] theShape shape to store. param[in] theIsStoreSameShapes if false stores reference to the same shape if it is already in document.
◆ storeGenerated() [1/2]
void ModelAPI_ResultBody::storeGenerated ( const GeomShapePtr &  theFromShape,
const GeomShapePtr &  theToShape
◆ storeGenerated() [2/2]
void ModelAPI_ResultBody::storeGenerated ( const std::list< GeomShapePtr > &  theFromShapes,
const GeomShapePtr &  theToShape,
◆ storeModified() [1/2]
void ModelAPI_ResultBody::storeModified ( const GeomShapePtr &  theOldShape,
const bool  theIsCleanStored = true
◆ storeModified() [2/2]
void ModelAPI_ResultBody::storeModified ( const std::list< GeomShapePtr > &  theOldShapes,
◆ shape()
GeomShapePtr ModelAPI_ResultBody::shape ( )
◆ generated() [2/2]
void ModelAPI_ResultBody::generated ( const GeomShapePtr &  theOldShape,
As an example, consider the case of a face generated from an edge in construction of a prism.
◆ modified()
void ModelAPI_ResultBody::modified ( const GeomShapePtr &  theOldShape,
As an example, consider the case of a face split or merged in a Boolean operation.
◆ loadDeletedShapes()
void ModelAPI_ResultBody::loadDeletedShapes ( const std::shared_ptr< GeomAlgoAPI_MakeShape > &  theAlgo,
const GeomShapePtr &  theShapesToExclude = GeomShapePtr()
load deleted shapes
◆ setDisplayed()
void ModelAPI_ResultBody::setDisplayed ( const bool  theDisplay)
theDisplaya boolean value
◆ COLOR_ID()
static const std::string & ModelAPI_Result::COLOR_ID ( )
The integer array is used. It contains three values for red, green and blue values. The values are in [0, 255] range
◆ DEFLECTION_ID()
static const std::string & ModelAPI_Result::DEFLECTION_ID ( )
The double value is used. The value is in [0, 1] range
◆ TRANSPARENCY_ID()
static const std::string & ModelAPI_Result::TRANSPARENCY_ID ( )
◆ ISO_LINES_ID()
static const std::string & ModelAPI_Result::ISO_LINES_ID ( )
◆ SHOW_ISO_LINES_ID()
static const std::string & ModelAPI_Result::SHOW_ISO_LINES_ID ( )
◆ SHOW_EDGES_DIRECTION_ID()
static const std::string & ModelAPI_Result::SHOW_EDGES_DIRECTION_ID ( )
◆ BRING_TO_FRONT_ID()
static const std::string & ModelAPI_Result::BRING_TO_FRONT_ID ( )
The bool value is used.
◆ isDisabled()
bool ModelAPI_Result::isDisabled ( )
◆ vertices()
ListOfShape ModelAPI_Result::vertices ( const bool  theOnlyUnique = false)
◆ edges()
ListOfShape ModelAPI_Result::edges ( const bool  theOnlyUnique = false)
◆ wires()
ListOfShape ModelAPI_Result::wires ( const bool  theOnlyUnique = false)
◆ faces()
ListOfShape ModelAPI_Result::faces ( const bool  theOnlyUnique = false)
◆ shells()
ListOfShape ModelAPI_Result::shells ( const bool  theOnlyUnique = false)
◆ solids()
ListOfShape ModelAPI_Result::solids ( const bool  theOnlyUnique = false)
◆ attributeChanged()
void ModelAPI_Result::attributeChanged ( const std::string &  theID)
◆ init()
void ModelAPI_Result::init ( )
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ document()
std::shared_ptr< ModelAPI_Document > ModelAPI_Object::document ( ) const
Reimplemented in Model_ResultField::Model_FieldStep, and ModelAPI_Feature.
◆ isDisplayed()
◆ setData()
◆ setDoc()
◆ erase()
void ModelAPI_Object::erase ( )
◆ emptyFunction()
inlinevirtualinherited
◆ myNamesOfShapes
std::map< std::wstring, std::shared_ptr<GeomAPI_Shape> > Model_ResultBody::myNamesOfShapes
◆ myColorsShape
std::map< std::wstring, std::vector<int> > Model_ResultBody::myColorsShape
◆ myConnect
ConnectedTopologyFlag ModelAPI_ResultBody::myConnect
◆ myBuilder
ModelAPI_BodyBuilder* ModelAPI_ResultBody::myBuilder
◆ myIsDisabled
bool ModelAPI_Result::myIsDisabled
