A macro feature which manages list of parameters in the current document. More...
#include <ParametersPlugin_ParametersMgr.h>
| ParametersPlugin_ParametersMgr () | |
| virtual | ~ParametersPlugin_ParametersMgr () |
| Destructor. More... | |
| Returns the unique kind of a feature. More... | |
| virtual void | execute () |
| virtual bool | isMacro () const |
| Reimplemented from ModelAPI_Feature::isMacro(). Returns true. More... | |
| virtual bool | isPreviewNeeded () const |
| Reimplemented from ModelAPI_Feature::isPreviewNeeded(). Returns false. More... | |
| std::wstring | name () |
| Feature kind. More... | |
| ParametersPlugin_ParametersMgr::ParametersPlugin_ParametersMgr | ( | ) |
inlinestatic |
Feature kind.
Implements ModelAPI_Object.
inlinevirtual |
Implements ModelAPI_Feature.
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
